| Fortgeschrittenes Mitglied Modell: Samsung Galaxy Nexus Registriert seit: 09.01.2011
Abgegebene Danke: 27
Erhielt 119 Danke für 72 Beiträge
| [ROM] AOSP 4.0.4 Android Open Kang Project Code: Beta 37 - 24. Mai
fixed navbar glow resetting on reboot
fixed hide navbar for tablets
fixed back button disappearing on tablets
auto-brightness fixes
added more SwagPapers
added volume adjust sound preference
fixed memory leak with lockscreen code
fixed auto-rotate toggle
systemui will not restart on changing themes to avoid any potential errors
navbar background is now set through XML to allow theming
added aokp clock widgets
reverted sd/emmc switch for Galaxy S devices
fixed otter build
navigation bar app icons now scale better
fixed bug in native Email app that would cause wakelocks
Support GSM AT commands for SMS over bluetooth
raised volume level on maguro/tuna
updated nova to 1.1.4
as always, tons of framework/device fixes
Beta 36 - 15. Mai
fixed MTP not being enabled by default (yet once more)
added Galaxy Tab 2 7" (espressowifi)
moved tablet clock to the far right of the statusbar
updated tuna kernel to faux 17m
added Transformer Prime (tf201)
updated Nova Launcher to 1.1.2
fixed potential weather service FC
updated p4 devices
added more padding to statusbar buttons
updated Mms emoji code from CM
added delayed ring feature to Phone
fixed a bug when hiding sender information, photo would still show
default ICS wallpapers have returned
added SwagPapers (AOKP Wallpapers)
updated theme engine from CM
wifi icon cut off has been fixed on tablets
fixed volume slider showing incorrect volume in a voice call (making it look like it wasn't full)
added USB Tether toggle to devices that support it
Beta 35 - 09. Mai
removed Facebook sync (this had to happen. it was a hack and breaking Picasa sync. FB needs to fix this, not ROMs)
Added ability to hide sender and/or message body in notification'
Added dock battery display for tablets
Added Browser tab settings (max tab limit/whether to restore tabs on browser restart)
Added CM9 T-Mobile theme manager
Added Sense 4 style Task switcher (you have the option of choosing from stock/web os/sense 4 now)
Added ability to play boot sound (disabled by default)
increased default nav bar glow speeds for better user experience out of the box
tons of device specific updates and fixes. check here to see all of the latest code we've merged
updated p5/p5wifi device trees from GalaxianSoup.
added toroplus (data will not work after flashing, just flash ANY other kernel after flashing b35. we're working on it
Goo Manager won't be able to detect an upgrade this build
Milestone 5 - 28. April
updated to IMM76I
differences between IMM76D and IMM76I are ALL in the Galaxy Nexus kernel
we updated the Galaxy Nexus kernel to Faux’s 16m kernel by default, which incorporates the fixes from IMM76I
fixed long press home on navbar being on by default
fixed volume zoom playing sounds with video camera
made flash-off indicator visible in camera
AVRCP: fixed soft reboots with certain players
fixed brightness slider jumping when toggling auto-brightness
sped up opening of init.d tweaks in RC
added description to LED setting on RC to be clearer on what it does
it only changes the DEFAULT LED color. Apps may override it, and most do.
attempted to fix freezing clock yet again
fixed wifi icon being cut off
fixed color multipliers being doubled
new gamma ranges from -100 to 100 defaulting to 0
your kernel (if it supports gamma tuning) might have a different default, so just keep that in mind (60 was the previous default)
fixed small icons when airplane mode & wifi are enabled
added shortcuts to toggle torch & toggle navbar
that means you can add these to nav bar as regular actions or long press actions, click “Custom app”, scroll down to “System UI”, toggle nav bar & torch should be there.
You can also add these shortcuts to your desktop. They do NOT work correctly from the lockscreen, yet.
Fixed decrease lights in custom backlight settings
a500 renamed to picasso and updated
everything should work now except slow GPS lock times
Build 34 - 24. April
fixed mobile data toggle not updating for serious
fix navigation buttons for tablets
long press home options added to General Interface for phones that have hardware buttons
fix icon transparency being applied to right-side buttons (BT, etc)
updated NovaLauncher to 1.1.1
Add BT MAP Profile
fix font sizing in statusbar
fixed volume sliders not updating when volumes are linked
many fixes for ColorPicker in ROM Control
gradient showing properly
color picker should fit in all screens now
show color preview before opening dialog (in-line)
fixed sound playing when volume zoom is enabled in camera
last.fm AVRCP crash fixed
contact pictures now displaying properly in notifications when receiving new sms
many other things!
20.04.12 Build 33
Bug fixes:
- Bluetooth: Fixed memory leak and file handles leak
- Nav bar & tablet status bar FCs fixed
- Fixed some init.d scripts not running due to lack of bash
- Changing brightness by sliding on the top of the statusbar (if enabled) shouldn’t FC anymore
- Fixed Data toggle not updating properly
- Torch should be acting normally again
- ROM Control: Fixed scrolling cache not setting properly
- Weather will refresh whenever SystemUI starts instead of when the phone boots (so if it gets restarted, it should fetch weather again, it didn’t before)
- Lockscrens: Added lockscreen wallpapers to pin & pattern unlock screens
- Settings: fixed link mute states always being checked
- supersonic: Updated files (thanks to evervolv), should boot! I’ve also included a “camera hack” so it should work, Video camera will FC, so will panorama mode. It is what it is Bild
New features:
- Added another ROM Control shortcut that opens ROM Control
- Added ability to translate weather conditions (only German is translated for now I think)
- Mms: added ability to strip unicode (CM)
- Mms: added emoji icons (CM)
- Mms: added quick emoji button to left of input (option you must enable)
- Added warnings to fast charge (will notify you if it’s enabled on boot)
- Hide navbar feature for tablets
- More music players supported for AVRCP 1.3
16.04.12 Build 32
Fixes:
- Fix NavBar showing up in landscape lockscreen
- Fix long-press resetting custom NavBar icons
- Fix incorrect bluetooth address on some devices
- Fix lockscreen events showing up 1 day before
- Fix quickunlock not allowing passwords longer than 8 chars
- Fix centered clock not showing the correct time
- Other small fixes
New Features:
- Camera: Pinch and Volume Zoom (CyanogenMod, Whitehawkx)
- General UI: Customizable rotation delay is back! (roman)
- Bluetooth: AVRCP 1.3+ support (CyanogenMod, MarcLandis)
- Lockscreen/NavBar: Allow shortcuts to specify their own icons
- NavBar: Allow tablets to use “hide NavBar” feature (Zaphod-Beeble)
- NavBar: Custom NavBar is now available for tablets as well! (Zaphod-Beeble)
- NavBar: Customizable glow color (roman)
- Quiet Hours: Configure the hours your device should be quiet and/or still (sethyx and thanks to CyanogenMod)
- Statusbar: Added ability to WeatherPanel to start a custom app (MarcLandis)
- Statusbar: Added ability to hide signal bars (hillbillyhacker)
- Statusbar: Customizable font size (Zaphod-Beeble)
- Statusbar: Customizable icon transparency (sethyx)
09.04.12 Build 31
- Fixed long pressing home button not working on capacitive buttons
- Fixed FC when clearing market data through the LCD density changer in RC
- Fixed lockscreen icons not setting properly
- Fixed devices not having MTP checked by default (for Galaxy Nexus amongst others)
- Fixed battery bar showing incorrect battery percentages and not showing in the proper orientation
- Fixed Calendar FC in ROM Control
- Added donate link for Khas Mek (you should really click this)
- Changed back to stock framework animation speed as the faster ones weren't properly configured and made things "stutter"
07.04.12 Build 30- Fixed T9 Dialer
- Fixed ROM Control issues with saving images (should be fixed for ALL devices)
- Navigation bar overhaul (ability to set custom actions/icons and long-press actions)
- Sped up default animation speeds
- Removed OpenWnn from builds (Japanese IME)
- Added option to disable camera sounds (Settings -> Sound)
- toro/maguro: including faux 14m(ainline) kernel by default
29.03.12 Build 29- Updated to Android 4.0.4 (IMM76D)
- Added Honeycomb lockscreen
- Mediascanner improvements
- Lockscreen calendar improvements
- Probably tons of other stuff I didn't see because of the merge
20.03.12 Build 28
- Added lockscreen color changer
- Added 'traditional' toggle layout [where the toggles are on the very top] (Stevepear426) -- find in RC > Statusbar General > Layout
- Added AOSP lockscreen style (Whitehawkx)
- Added extra volume slider options (Stevepear426, tmoskowite on gummy)
- Added lockscreen calendar options (!!!) (sethyx)
- Removed any trackball support the ROM had, was only throwing errors, not properly implemented
- Improved brightness slider under toggles, doesn't jump anymore
- Improved brightness slider (when sliding your finger across the statusbar if enabled). MUCH more responsive now
- Added fast charge toggle for maguro/toro for kernels that support it (Zaphod-Beeble)
- Added ability to set custom lockscreen image for targets. Click picture in RC to set.
- Also increased size of custom lockscreen images to more match the normal icons
- Improved
- Including AppWidgetPicker to help organize widgets
- Added digital clock widget to desk clock
- battery bar should no longer disappear when in the navigation bar
08.03.12 Milestone 4
- new more compact layout that fits at the top of your screen
- Weather panel updates (sethyx, Zaph, tgwaste, and many more!)
- ability to hide it in your statusbar
- added lockscreen weather to tablets
- Added statusbar transparency (rob43)
- Added alternate notification drawer layout (toggles/date on bottom instead of top)
- Added day of the week before clock style option (rob43)
- Signal text reading improvements (Zaph)
- Added option to show lockscreen before secure unlock
- Simplified nav bar hide/show code => should be working on all devices properly
- Added PhaseBeam alongside UnicornPorn
- Fixed all weird tablet FCs (was caused by that messy nav bar code
- p4: 3G should now be working on the 3G 10.1" tab samsung tab
- stingray: Data should be working now! Thanks travp for helping me debug this
- added fascinatemtd
- added a500
- vzwtab renamed to galaxytab7c, also now using MTD instead of BML. No m4 for it yet.
29.2.12 Build 27
- New weather panel in dropdown! (Zaphod the beast)
- Shows more info.
- Click to refresh.
- You have a choice of that one, or the text above the carrier
- Next release you'll be able to hide both (so you can still have lockscreen weather, impossible to only have it right now I think)
- New power menu navigation bar controls when hidden (Zaphod the beast)
- so you can still control your phone when it's hidden
- Added ability to show navigation bar on devices that don't have it on by default
- Added ability to change navigation bar sizes
- Fixed boot animation sizes on xhdpi devices
- If you don't have music controls enabled AND you have volume wake enabled, your device will now wake when playing music
- Fixed faceunlock and music control layouts on lockscreens
- Themers: toggles use on/off state images, so you can theme them and have them be different in off/on states. By default they're the same
- Swagger toggle will make your device leak butter. Exclusive on certain devices for now.
26.2.12 Build 26
- Added weather information to lockscreen (sethyx)
- the weather information is now pulled from Yahoo! and should provide information for more cities
- Re-added boot animation for devices that didn't have it from b25
- should've fixed all incompatibility issues with Chrome with all devices supported
- cleaner RC images & signal icon
- fixed setting alarm from voice not activating properly
21.2.12 Build 25
- added optional dBm text display which will replace your signal bars
- added hide nav bar option (be careful on devices that don't have a navbar, untested and may break stuff! more stability fixes for those devices later)
- added special unicorn porn (don't worry, SFW)
- added warning to weather when no location can be found
- added trackball alert
- torch code improvements
- small airplane mode visiblity improvement
- crespo/hdpi: should've fixed all issues causing reboots and such
- p4: 3G *should* be working as it was before. If it's not, please let me know
19.2.12 Build 24
- Added lockscreen wallpapers
- It seems that there is an interesting bug with Lockscreen wallpapers. Every once in a blue moon, your device may do a 'soft-reboot'. I can go into the technical details of why this happens, but basically it comes down to displaying a large 'picture' and Java/Android not correctly cleaning up the references to it, thus creating a memory leak. This is extremely rare it happens, and I've only noticed it happen while the device is NOT being used. If you're concerned, please just remove the lockscreen wallpaper and it will never happen to you. I'm trying to find a way to make this 100% stable.
- Added torch toggle to power menu
- Added airplane mode toggle to power menu
- Added 'about' page in ROM Control
- Addd new LCD density wizard to help keep your device from being 'not supported' by certain market apps
- fixed music widget on octo lock
- fixed reboots happening when trying to show power dialog more than once
- fixed notification-unlink logic (won't toch other sound-volumes now)
- fixed MTP devices not being recognized by default (Gnex, etc)
- I believe that's it!
- toro: removed SDM.apk
13.2.12 Build 23
- Added a quick-torch! (Enable in RC > Lockscreen first!)
- While your phone screen is off, you can long-press the power button and the torch will automagically turn on. Let go and it will turn off :)
- Zaphod-Beeble is the man behind this one, thank him.
- Added end call button to notification bar while in call (Also Zaphod-Beeble!)
- Added ability to add ROM Control shortcuts to your desktop (Long press desktop > Shortcuts)
- Power Menu should update instantly now with the options of your choosing (sometimes it did not update instantly)
- Updated scrolling-cache code
- Should've fixed clock not updating for realz this time.
- Fixed weather location not being checked properly in RC
- tablets: Added weather display
- tablets: Added clock options
- tablets: should display "Reboot tablet" now instead of phone
- tablets: enabled more keys on keyboard
08.2.12 Build 22
- Toggles on by default, disabled auto-hide by default
- Added a hide USB debugging icon toggle
- Added power key shutter for camera (Daneesh)
- Added 'Always show lockscreen battery %' toggle (syaoran12)
- Added option to disable scrolling cache (pawitp, AndroidON)
- Added ability to slide statusbar to change brightness (Danesh)
- Removed off state of alternate toggles (they're always white now, so it's easier to see)
- Updated brightness slider code to be consistent with brightness changes
- Updated sync toggle to keep it's state updated
- Initial implementation of weather display (currently ONLY available above your carrier text in the drop down, more to come later)
- Added ability to set custom DPI
- Fixed weird phone layouts
- Long click on a link now allows you to choose between opening in incognito/regular tab (Danesh)
- Added a "Link mute states" check box in volume settings in case you don't want your notifications being muted when putting your phone in mute
Milestone 3
posted an hour ago by Roman Birg [ updated an hour ago ]
The long awaited Milestone 3 is here! We tried to squash as many bugs as we could in this release and really give it that "Milestone" feel. If any bugs should be discovered that are semi-serious there will likely be a follow-up M3.1 release or something of the sort.
There's also a bunch of goodies in M3 not available in build 21! Check out the change log:
- Added LCD density switcher to ROM Control
- Added quick pin unlock (source)
- Added two new battery styles -- CircleMOD and Text (sethyx)
- Added a 'Reset Nav Bar' button to RC which will reset your color and opacity to default settings (as some of you requested)
- Added ability to change ROM Control language to English if you're using another language
- Added HDPI/MDPI toggle images, so they should show up correctly on tablets/Nexus S phones
- Added a toggle toggle for tablets (and removed a few redundant settings)
- Added ability to unlink ringtone and notification volumes (!!!)
- Added white SMS Icon back to lockscreen (goes to stock Mms for now, will be configurable later)
- Added link to T9 settings (so you can disable T9 if it freezes for you)
- Added new phone options - Zaphod-Beeble!
- Enable landscape
- Status bar while in call
- Exit to home (actually exists to most recent activity)
- Disable lights out on nav bar
- Removed hide nav bar function for now (it was causing unresponsive screen on incoming phone calls)
- Fixed RC icon sizes
- Fixed lockscreen icons not being set properly by default
- Fixed wrong string for Emergency dialer on setup screen (#intent blah blah)
- Fixed Power Saver being grayed on in RC even after enabling it
- Fixed volume music controls conflicting with apps that take over volume button
- Fixed landscape lockscreen layout
- Fixed default toggles having Data (removed for devices that don't have data)
- Fixed lockscreen rotation setting overriding system-wide rotation setting (system-rotation takes priority)
build 21- January 26
- quad lockscreen now uses awesome layout from b19
- slight ROM Control overhaul -- new icons from kwesley snipes and included some descriptions
- added ability to change nav bar button transparency
- added ability to change nav bar glow animation time (quick glow mod as some people call it)
- added option for large menu button (originally seen in RootzBoat, thanks xoomdev!)
- you can also remove the original menu buttons on the left/right, be sure to do that, it's in Menu location
- nav buttons should space out better on higher LCD densities, while still looking good on stock (also sizes now same as stock)
- should have fixed the hide nav bar option (let me know if it's still broken, works great for me)
- lockscreen should be quick again
- lockscreen will have default camera/unlock shortcuts IF YOU HAVENT SET THEM BEFORE
- fixed nasty volume bug some people were experiencing -- also improved stability of hold to skip while screen off (won't wake your screen anymore)
- horizontal task switcher layout updated
- Power Saver shouldn't touch anything while you're on a phone call now
- misc fixes (clock not updating, hopefully, battery bar disappearing in nav bar, etc)
- using CM squisher with build now, adds about 21024 the amount of butter we had previously
- optimizes all APKs/images
- enabled full hardware acceleration in galaxy nexus builds to fix quardrantlololololololol
- updated Contacts app (including all latest T9 fixes from CM)
- updated Nova Launcher to b13
- tablets: including Trebuchet launcher instead of Nova for you guys
- p4wifi: removed device assert when compiling from source (easier for me, easier for you)
build 20- January 23
- new customizable lockscreen shortcuts
- pick your apps/shortcuts from ROM Control
- shows app icon on lockscreen
- long press on toggles to bring up settings menu (on the buttons, not text)
- new on/off icons for toggles/correctly spaced
- battery bar revamp
- animations while charging
- mirrored-center style for OCD folks
- ability to place it on your nav bar
- WebOS recents window toggle
- fixed volume wake and volume skip controls not playing to gether nicely
- ROM Control app revamped for tablets (no real affect for phones, but it looks nicer!)
- init.d scripts removed (init.d support still there)
- increased stock browser tab limit to 64
- added ability to disable boot animation
- added ability to disable bugmailer
build 19- January 17 [OCD Edition]
- fix nav bar alignment with 4 buttons enabled
- really fix recents button sometimes not working
- init.d scripts disabled by default
- fixed octo/quad lockscreens not working with Lightflow
- don't show torch activity in recents window after using it
build 18 - January 17
- bug fix: recents key sometimes not working
- bug fix: toggles will restore original state on reboot (if they don't auto-hide)
- bug fix: torch revamp, works great now! (Zaphod-Beeble)
- bug fix: alternate layout will now center if there's nothing to scroll (Zaphod-Beeble)
- bug fix: added mdpi & hdpi images for lockscreens (should fix crespo reboots) (Whitehawkx)
- bug fix: nav bar not being spread apart like stock
- bug fix: volume wake not always working
- bug fix: camera effects should be working
- added: battery bar with charging animtation and color option (CM and a little me!)
- added: option to disable battery icon
- added: sync toggle
- added: octo lock screen (with 3 configurable apps) (Whitehawkx)
- added: option to enable 180 degree rotation (CM)
- added: ability to hide nav bar on lockscreen
- added: google dns servers by default
- added: built in performance/init.d configuration (thanks to Kejar & company)
- includes awesome init.d settings
build 17- January 13
- fixed bluetooth drainage bug
- fixed lockscreen bootloop
- new long press home action in ROM Control currently does nothing!
- disabled landscape to avoid FCs in ROM Control for now
- added some padding for toggles (layout was slightly off before, yw OCD people)
- updated gapps package (includes updated G+ and stops my keyboard from being overwritten with Google's) - be sure to use the updated one
personal note: Although I've fixed the wakelock issue with bluetooth, it seems my device is still keeping a wake lock. I've narrowed it down to DRM Content Provider. I'm not sure if something on my SD is messed up (which could be causing the issue) or there's something else at play here. Lots have reported proper deep sleeping so I'm releasing this anyways. Download CpuSpy from the market and test it out for yourself. After disabling the DRM Content Provider app my phone appears to be deep sleeping perfectly again, but I'm sure there are some repercussions. I'll investigate. You should too if you can  .
build 16 - January 12 - WIPE REQUIRED WITH THIS BUILD DON'T COMPLAIN JUST DO IT
- YOU MUST ALSO FLASH THE GAPPS PACKAGE!
- Freshly re-written navigation buttons, completely re-arranglable/toggle-able!
- New toggle-able quad lock screen option
- Lock screen's SMS shortcut can be customized to an app of your choice (defaults to stock sms app)
- Added volume wake option
- Added volume long press to skip option
- Added LED torch toggle
- shortened nav bar animations a little
- updated alternate toggle layout
- tons of butter butter butter yes!
- 16a: include superuser
- 16a: smaller size due to not including files that are being flashed with gapps
milestone 2 - January 10 - Added toggle icons (thanks to MDJ & Virtuous)
- Added custom hex input when picking a color for anything in RC
- Added scrolling toggles for the alternate button style (thanks to ZB!)
- Changed the way the statusbar drag handle works slightly so it is still centered when you lower your LCD density
- Fixed init.d
- Fixed clock not being allowed to be pure white
build 15 - January 9 - Bug fix: Center clock should function just like the right clock now (ie be pretty when you get messages, etc)
- Bug fix: gps toggle not being updated on reboot
- update long-press back to kill code (no haptic feedback on the virtual button, maybe I'll add it later)
- Add a custom color tint picker for your nav bar buttons
- Add rotation animation delay options (how long it will take before it rotates)
- Add new toggle style - Zaphod-Beeble's buttons!
- ---- there are no toggle images included with the ROM at the moment, so in ROM Control if you select image for the toggle style it will NOT show, you need to flash his mod for now.
- new Power Saver icons in power menu, thanks to mdeejay and Virtuous
- ROM Control translations for many languages (thanks to all who submitted translations!)
- Added tethering toggle
- Added silent toggle
- Added vibrate toggle
build 14 - January 6 - Added Toggle Customziation (brightness location, enable/disable each toggle)
- Added 2G toggle
- Added init.d support (you need to create the folder yourself)
- Added a new nav bar layout > Back - Home - Tasks - Search
- Bug fix: duplicate sounds should be gone
- Bug fix: fixed center clock not animating properly
- Bug fix: fixed phone not reading NFC tags
- Power Saver: should be more stable for CDMA (!!! needs testing, unconfirmed
- Crespo4G WiMax fix
- so much butt3r, it's sticky
build 12 - December 31 - Added clock options (hide clock, am/pm styles)
- Recoded how the system chooses navbar layouts and made it more "correct." Hopefully this fixes the disappearing buttons issue.
- Added screenshot & power menu options to the power menu. You can show/hide them from ROM control
- More code cleanup for the BT toggle (let me know if it still shows the incorrect state)
build 11 - December 29 - initial implementation of LED light picker (I plan on making it be ON while picking it to be able to see the color)
- Added 4.0.3 Tag.apk from Google. Let me know if this fixes reading NFC tags. I have no tags to test on so you guys have to let me know
- Keyboard: volume keys will act as a cursor while typing -- disable in keyboard options
- Power Saver: won't turn on if Google Music is playing, won't turn on if phone is charging
- Power Saver: added some checks to make sure it's switching to a proper network mode to help with CDMA devices
- Power Saver: added 1x (CDMA) toggle for CDMA devices, now comes with a warning when you turn it on! If you have time, please test this. Make a nandroid before.
- Nav Bar: added new layout (thanks brucekey for the idea!) Back - Home - Search. Long press home to get recent apps
- Toro: attempted (!!) to disable VZW tethering and enable native tethering. Please let me know if this works.
Milestone 1 - December 27
Milestone releases are meant to be for those who don't want to flash everyday. They are targetted towards fixing ALL the bugs we can fix and making it as clean as possible. However, we are all human, some things slip through and there may be a bug or two. In the rare event this DOES happen expect a fix ASAP. - Added Google Calendar 4.0.3
- Search navbar layout fixes (long press in landscape, spacing, new matching icon)
- Added adjusted autobrightness values back
- Fixed bluetooth toggle not showing proper states
- Fixed Google Earth FC
build X
- I advise you wipe /data and start fresh on this build. Lots of changes, many room for errors without wiping! I did.
- Settings: added mod version in settings
- Settings: removed System Update
- Nav bar: fixed spacing for status buttons
- Nav bar: added new option: stock menu button behavior/visibility, except show invisible buttons when there are no menus to be shown
- Nav bar: fixed disappearing navigation buttons (I think, haven't been able to recreate it since modifying it)
- Nav bar: added long press to search button layout!
- Nav bar: search icon from people app
- Status bar: added center battery style
- Status bar: added GPS toggle in quick toggles
- Status bar: added Bluetooth toggle in quick toggles
- Status bar: fixed auto rotate toggle not updating
- Status bar: option to change behavior of setting button in dropdown (ie change quick toggles to longpress)
- Status bar: added toggle to not hide quick toggles after collapse
- Status bar: lowered brightness on brightness toggle
- Status bar: fixed autobrightness text not showing up
- Added Facebook contact sync integration (must wipe to get this)
- Power Saver: won't start if phone is charging
- Power Saver: fix CDMA data off setting
- Power Saver: will attempt to turn LTE off on 2G setting (experimental for now!)
- Crespo4G: Mms fix
- Included Gapps with ROM package - read new installation instructions!
build 9
- Added T9 dialer from CM9
- add ability to change when/how the menu is visible -> always visible, always visible with invisible menu buttons, system controlled (default behavior)
- screen off (by user) timeout override -> by default android only uses a timeout when the screen times out by itself. this lets you force android to use the same timeout for when you turn the screen off yourself
- added lock screen unlock by menu key toggle
- added option to customize carrier text (useful for you VZW people who don't have it showing properly!)
- Toro only: added warning when selecting 2G screen-off toggle. This should weed down the phone FCs people are getting and not knowing how they got em.
- Toro only: attempted to fix 2G data off again!
- finally added proper ICS sounds. And they're glorious
build 8
- Added Team Kang boot animation, thanks to @rascarlo
- fixed video camera face effects FCing and such
- brand new (giant) gapps package. Should include all the Google goodies you need, including Google Wallet!
- Still no ICS sounds
- Fixed power saver bug that would turn data back on even if power saver was disabled (TORO owners: 2G screen off in Power Saver is still untested, but might be fixed! Please test and be ready to wipe if it doesn't work! Please report me your results)
- adjusted autobrightness values (thanks to Thyrus)
- TORO ONLY: updated a few VZW specific APKs with signed versions (also thanks to pete!)
build 7
- fixed resetting data setting when it's not supposed to (for VZW/CDMA devices)
- added an alternate nav bar layout with a search button! (huge props to @kwes1020 for making the icon)
- removed old music app from compilation, included musicfx again
- added missing LWPs to build
- added initial LED pulse settings (can configure LED time on/off)
- color customization later
- added battery text option (shows over the battery icon)
- more color customization later
next on the agenda: get ICS sounds to be included with the build properly!
NEMEA2012 : Autobright-Patches fuer die OpenKang von RomanBB Ver 7
(ab Build 8 enthalten)
build 6
- started fresh, rebased code to Android 4.0.3 (IML74K) now
- added IME switcher toggle
- added ics ringtones/notification sounds
- updated superuser apk/binary to work with 4.0.3
- updated market build id to 4.0.2
- quick toggles now hide after collapsing the statusbar
- gapps with google wallet
- removed CM9 launcher for now
- mostly a rebase to 4.0.3
build 5
- greatly improved stability/functionality of powersaver
- now attempts to restore your data state if your phone crashes or if you hard rebooton boot up
- by default, syncing will use the data state you had prior to turning the screen off (will be configurable later)
- wifi shouldn't be touched (yet, gain will be configurable)
- fixed error with scheduling screen-off data mode after turning screen off
- screen on delay is set to 5 seconds for now (how long it will take for your data to restore to it's previous value if it was changed) will be configurable later as well
- improved layout of ROM Control
- added a CRT-Off Animation toggle (CRT on will NOT work for some reason, will dig more into it later)
- fixed Wifi toggle in drop down
- bugfix version: fixed power manager from turning WiFi on when it was off
- bugfix version: app navigation menu icons no longer disappear after unlocking phone
remember: always do a nandroid!
build 4
build 4 - December 13
Added initial implementation of power saver!
- only a few settings for now in ROM Control (now found through Settings)
- it likely does not work full YET, please keep in mind it's beta, don't rely on it.
- that said, I need you to find the bugs!
- from my personal experience, the options in ROM Control seem to work. let me know if otherwise
- modified menu unlock code a little -- toggle it in RC to the option you want, then reboot. it should show/hide. I'll get this toggling instantly later
- some more code for crt on/off, no toggles for them yet though, look for them in build 5
- added spiffy ROM Control icons
- I highly recommend a /data wipe for this build. I've changed core system services
Changelog
build 3
- Fixed Bluetooth & GPS not turning on (other HW related issues should be fixed as well)
- changed settings button click to pull up my customization menu, long-press will open settings
- added auto rotation toggle to customization menu
- added wifi toggle to customization menu
- added an option to hide folder names in Launcher2
- added first implementation of ROM Control
- no icon yet, taking any help with this!
- new option to change position of legacy menu button - left/right/both
Geändert von gknnn (24.05.2012 um 16:26 Uhr)
