[AOSP-ROM][JellyBean] *31.10.13* [4.3.1] ParanoidAndroid 3.99 HybridMode Unofficial
Pr0TuRk38
Pr0TuRk38
Dauergast
1.551
Die ROM befindet sich im frühen Anfangsstadium von daher können noch Fehler vorhanden sein!
Weder ich, noch Android-Hilfe.de, oder sonst irgendwer gibt Euch Garantie für Schäden oder sonstiges an Eurem Gerät, seit Euch dessen bitte bewusst!!!
Bugs:
Bugs sind die gleichen wie bei CM 10.2
Installation:
0. BackUp der aktuellen Rom anlegen
1. Neustarten in das Recovery-Menü
2. Wipe Data / Factory Reset
2. Wipe Cache
3. Wipe Dalvik Cache
4. Format Data
5. Format Cache
6. Format System
7. Paranoid Android Rom.zip flashen
8. Gapps flashen
9. Neustarten
Changelog
Build 31.10.2013
- Merged 4.3.1
- latest commits from cm and PA
- HALO colors feature
- User selecting bug is fixed so you can change user
Downloads
Paranoid Android 3.99 Build 31.10.2013
Paranoid Android 3.99 Build 12.10.2013
Paranoid Android 3.99 Build 08.10.2013
Google Apps:
Google Apps vom 13.08.2013
PER-APP-DPI/LAYOUT. This is not tablet mode! Hybrid engine allows you to target apps individually. You get to pick their actual layouts which can tranform content drastically. Keep in mind, this has nothing to do with build.prop hacks or DPI changes. We list all layouts an app brings, you choose one, its as easy as that. It does not matter if your device runs itself in Phone-, Phablet or Tablet-UI, your apps will always look as you like. On top of that you can scale apps, to fit your screen, that way you can even bring full fledged tablet apps and make them run perfectly. Nothing will break, nothing will shrink, your market will be fine. Additionally we have rewritten many parts of the android framework and fixed countless of AOSP bugs to make way for these modifications - our "tablet mode" runs better on a phone than on a real tablet, that is guaranteed.
PER-APP-COLOR, Paranoidandroids newest invention. Define apps in your regular hybrid panel. See your phone fade into the color definition of your current app, press home or go elsewhere and it fades back. Create as many combinations you like, you can even dabble with opacity. This feature is made possible by our hybrid engine, which is unique to this rom.
Credits
PARANOIDANDROID TEAM
CYANOGENMOD TEAM
codeworkx
XpLoDWilD
molesarecoming
D4rKn3sSyS
And many other peoples
Quelle:
Originaler XDA-Thread
Reaktionen: j1gga84, Drielander, fsi09 und 21 andere
Ehemaliger TE.
  • RECOVERY: FACTORY RESET IF YOU WERE USING ANOTHER ROM!
  • RECOVERY: Install Rom: Download
  • RECOVERY: Install Gapps, ALWAYS-EVEN FOR UPDATES: Download (find the latest one that carries the "jb" tag)
  • RECOVERY: Wipe Cache Partition
  • RECOVERY: Wipe Dalvik Cache
  • Reboot and enjoy
  • If you have an issue and you want to call our attention, here's what you do:
  • 1. Try everything you can, find solutions for yourself. Wipe caches, revert all your settings you have made, go back to your stock Kernel, factory reset if you have to or reflash the rom. Assume that the issue is on your side and try your best to isolate it.
  • 2. Search this thread and Cyanogenmods aswell (its our base) for possible reoccurences of your issue and hopefully solutions that may have come up.
  • 3. If you think the issue is important enough that we should cease our work and look into it, post your issue, BUT ...
  • ... stay friendly, do not demand anything, do not threaten
  • ... explain your issue as precise as you can, name the exact apps and conditions that cause trouble, help us to replicate the issue right away. If we can't there's no way we can fix it and your post will simply clutter the thread
  • ... collect evidence, keep in mind this is a developer thread so even if you are not one, do us the favor and research how to record logcat. logcat is the single most important help you can give us to resolve your issue.
Special Thanks
  • Teamhacksung, For their awesome work all this time on CyanogenMod team, and a solid base for our device tree.
  • slade87 , For teaching me about android programming. You're the man.
  • To every single person that helped on this project, I can't keep the track because they are a lot!
VERY Special thanks to all the donators!, you support me for making a better work each day!
Reaktionen: Pr0TuRk38, fsi09, phreakkk und 6 andere
Na gut - es ist ja Osterwochenende. Da kann man ja alles Neue mal flashen. Aber auch hier wieder ein ROM im "Blaumann".
Hab's mir gerade mal geflasht. Sieht soweit ganz gut aus.
Laeuft nun knapp eine Std. - die ersten Apps wurden schon installiert bzw. von GB mit Titanium wiederhergestellt.
Ist mein erstes ICS-Rom, deshalb sind folgende Fragen evtl. fuer den Ein oder Anderen ueberfluessig,...
- Beim Scrollen, zB. in den Einstellungen, "zittert" das jeweilige Menue, wenn ich unten bzw. oben angekommen bin?!
- Ebenfalls beim schnellen Scrollen "hackt" das so ab. Bin's von GB gewohnt, dass es dann weiterscrollt. Also schnell bis zum Ende, wenn ich schnell rueberwische. Kann man das einstellen?
- Wo bzw. kann ich ueberhaupt die Lautstaerke fuer die Systemtoene - u.A. die des Klicks - einstellen?
- Die Sensortasten leuchten dauerhaft - einstellbar?
- Das haptische Feedback bei den Sensortasten vibriert manchmal laenger als "normal" - quasi Doppelfeedback-Vibration - einstellbar?
- Der Hintergrund ist nur noch ueber die komplette Anzahl an vorhandenen Bildschirme "streckbar" und kein Scrollen ohne Hintergrundverschiebung moeglich?! Aber hierbei schau' ich nochmal, ich glaube, ich hab' die Option vorhin geseh'n.
Weiss nicht, ob das was mit dem ROM zutun hat, aber wenn sich 'ne Benachrichtigung aktualisiert - bspw. die von BeautifulWidgets - ist der Text in des ausgezogenen Benachrichtigungsleiste danach nicht mehr lesbar, bzw. nicht mal mehr vorhanden, sondern nur noch das Icon?! (Siehe Screenshot!)
Werd' mir jetzt erstmal den NEAK-Kernel flashen. Der mitinstallierte Syah ist in seiner Version (rc2) veraltet. Den Trebuchet-Launcher hab' ich mit dem Apex ersetzt. In der Standard-Konfiguration hab' ich nun immerhin schon 'ne Displayzeit von 57 Minuten und "nur" 14% verloren. Bei GB war's wesentlich mehr, hab' ich das Gefuehl.
MfG
Benny.
EDIT:
GPS funktioniert gar nicht erst! So fuer mich leider unbrauchbar. Werd' nun erstmal mein GB-Backup wieder einspielen... Schade drum.
Für Gps gibt es einen Fix , den hab ich aber gerade nicht parat ... sollte damit aber gehen ...
Also ich hab die Rom auch drauf, nach HydrOG3N und Sakaschi bin ich mi der Rom äußerst zufrieden und siyah rc2 läuft auch sehr gut, hab dir noch den Gpx-FIX im Anhang
Bei HydrOG3N und auch Sakaschi, sowie bei dieser Rom (glaub alle CM9) hab ich das mit Scroolen... Ist glaub ist so gewollt, was ich nicht verstehe... Ich will auch wie beim Stock das butterweiche Scrollen :(
Was mir an dieser Rom gefällt, irgendwie läuft der Siyah auch wenn noch rc2 hier ohne Probleme, kein Freeze kein Neustart, akku auch vollkommen okay. Und hab die jetzt 2 Tage :) mal schauen wie lange noch ;)
8h Laufzeit noch 80% Akku, davon war der Display 35min an, was für mich ganz okay ist, sonst läuft auch alles, wie Sync usw. nichts abgestellt. Also kann man sicher auch mehr rausholen, was ich aber persöhnlich nicht brauche, was bringt mir 3 Tage laufzeit mit vielen Beschränkungen?
  • GPS_patch_CM9.zip
Reaktionen: Scoty, Benny1988, Masta_Gee81 und eine weitere Person
Erster Post Aktuell ... Neues Update!!!
greetz M@sta
Reaktionen: Simuur95
Also das Rom gefällt mir sehr gut. Einzig was bei mir nicht zu finden ist sind die Battery Mods. Die OTA App hat bei mir die Version 3.0 aber wenn ich auf das Update klicke wird mir gesagt ich hätte eine ältere Version und es wird mir dann aber eine 2.13 angeboten. Wenn ich diese installiere wird mir aber nach wie vor 3.0 angezeigt. Desweiteren und das dürfte wohl auch ein Bug sein, wenn ich auf "Enable Reloaded IU Mod" klicke und diese installiere ist die Statusbar komplett weg. Das einzige was dann hilft ist das Rom neu installieren. Bis auf die genannten Sachen läuft das Rom aber sehr gut und vor allem sehr smooth.
Der von dir vermeintlich genannte "Bug" mit der verschwundenen Statusbar ist kein Bug. Ist doch logisch, dass Diese dann erst mal verschwindet, da nach dem Reboot doch eine komplett andere / "modifizierte" Statusbar dort ist. Deswegen empfiehlt sich bei den meisten Theme-Einstellungen auch ein Reboot, damit das Theme komplett - wie eingestellt - geladen werden kann.
PS: Danke fuer den GPS-Fix, allerdings zeigt u.A. Maps danach bei mir an, dass ich ganz woanders waere. Der Standort-Punkt ist richtig gesetzt, jedoch soll mein Wohnort so heissen, wie ein Ort, der knappe 50km von hier entfernt liegt?! Hab' mir Faster Fix aus'm Market installiert und den Server auf Germany geaendert. Danach alles super. (Allerdings mittlerweile 'ne andere ROM.)
MfG
Benny.
Reboot wird automatisch gemacht. Flashe ja nicht zum ersten mal und die Statusbar bleibt weg!
Ah, das war so nicht ersichtlich. Okay, dann hab' ich nichts gesagt. Allerdings kann ich deinen Bug dann nicht bestaetigen. Bei mir kam die Bar wieder, allerdings dann erstmal in 'nem haesslichen Blau. :D
MfG
Benny.
So inzwischen läuft das Rom extrem gut bei mir daher hat der Macher eine kleine Spende bekommen wie es sich gehört.
also ich find die Rom super aber: wenn ich in die CWM app geh und ein backup machen will krieg ich nen FC und (seeeeeeehr seltsam) wenn ich mit der Musik app Musik höre dann krieg ich nur bei einem bestimmen Titel einen FC.
Außerdem wäre der empfangsbalken in blau ganz nett sowie ein paar mehr einstellungsmöglichkeiten ganz super ;) sonst super Rom :thumbup:
EDIT: sry empfangsbalken ist doch blau ;)
Sent from my GT-I9100 with D4Rom CM9 based
Kann mir jemand mitteilen, woher ich das Uhr-Widget im oberen rechten Homescreen herkriege?
Neues Update .... Infos, Changelog und Download im ersten Post ...
[ROM][4.0.4][OTA Kitchen] D4 Rom i9100 v4.0 - Taste The Real Sandwich [10/04/12]
Reaktionen: Chris1996 und Scoty
Ist denn hier die D4 themes schon eingebaut? Wo findet mann denn die? Ich finde die nähmlich nicht!
So weit ich das sehe noch nicht.
Hey,
Hab jetzt die D4rom drauf aber immer wenn ich beim musik player runterscrolle friert mein bildschirm ein und ich mus gezwungernermaßen den akku rausnehmen und neu booten...
Mfg Canberk
Canberk schrieb:
Hey,
Mfg Canberk
installier dir mal nen anderen player ;)
dj3d
karu2003
j1gga84
vonharold
vonharold
j1gga84
Nick Knight
Nick Knight
