Scum
Moderator
Teammitglied
- 6.364
[ROM][ARC] TeamXperia | LeWa Os 2.3.7 | Full Port [29/04] V1.0 | Speed & Eyecandy - xda-developers
Installation Guide
- Unlock Bootloader (There are plenty of threads with how to do this...)
- Download and place TeamXperia Lewa VX.X on Sdcard
- Download and flash Kernel or just use FXP newest cm7 Kernel (117 is the kernel we use)
- Enter Recovery By pressing vol down when LED is on when the splash screen is displayed
- Full wipe/factory reset (in recovery)
- Install zip from SD and choose the Rom then flash Lewa Gapps
- Reboot and enjoy
-If WiFi doesn't work/turn on then install applicable WiFi Modules from that specific Kernel you are using
Credits
-FXP Team for their tiresome work which is always appreciated
-blindndumb for the Desire HD rom and his website helped me on a thing or 2
-LeWa for the lovely rom
-the rest of TeamXperia
-=Downloads=-
-=TeamXperia LeWa V1.0=-
-=TeamXperia LeWa V1.0=- (Mirror)
-=CM7 Kernel=-
-=LewaOS Gapps=-
Bugs
-Torch FC (Already on it)
-A ICS lockscreen theme from the online LeWa sever in the themes app
-Lockscreen is odd at the bottom when you pull it to the bottom of the screen (You'll know what I mean if you try it)
TeamXperia Presents LeWa Os V1.1
Hello fellow Xperia Arc users recently we've been on other forums and found a wonderful rom called LeWa Os. It is similar to MIUI in terms of initial looks but I promise you it's not the same
We have made a full port to our phones and wanted to share it... It's based on FXP 120 CM7.2 and v880 LeWa so most credits to FXP LeWa & of course TeamXperia. Android 2.3.7 & Awesome eyecandy & fluid performance
Working
-Almost evertything
Working
-Almost evertything
Installation Guide
- Reboot and enjoy
Credits
-=Downloads=-
-=CM7 Kernel=-
-=LewaOS Gapps=-
Bugs
