Scum
Moderator
Teammitglied
- 6.429
[ROM][ARC][4.0.4]MooDeD AOKP V1.0 [HD-Quality][xAROMA][xFast Engine 1.0]>Supreme AOKP - xda-developers
MooDeD AOKP 1.0 Version | Full AROMA Installer 147 MB. {Fast Server @ 1Gbit! Download} [ Link Working ] Updated ROM at [5/12]
MooDeD AOKP v1.0 + 0% Redraws + Stable { AROMA }
AROMA Installer :
Miscellaneous Area:
Working HD Games:
Tested and working:
- 9MM HD
- Asphalt 5
- Asphalt 6 HD
- BackStab HD
- GT Racing HD
- Real Football 2011 HD
- Shrek Karting HD
- UNO HD
- Dead Space
- Reckless Racing 2
- Modern Combat 3
- World of Goo
- Let's Golf 1
- GSM => working
- 3G/DATA => working
- SMS => working
- SENSORS => working
- USB Connection => working (MTP mode)
- AUDIO => working
- VIDEO => working
- VIBRATION => working
- MIC => bug with Recorder app
- GPS => working
- ANT+ => working
- Bluetooth => working
- WIFI => working
- camera => working
- camcorder => working
- flashlight => working
- USB tethering => working
- USB Mount in Recovery ==> working
Fixes :
Report If Error 6 [ Script Error
] Happens Cause I Am Not Using ICS Im In GB...
Themes : Cheers Coming Soon..
[Cooming SOON!]
By: ChaosFirZen XDA
Special Thanks To:
StockDroid ~ For HSDPA Limiting category
XtremePeople ~ For All In One Tweak
cobrato ~ For ICS Stock Kernel And USB Fixes
krabappel2548 ~ For UI And Many More Thank Yo HIM...
WasabiWa83 ~ For Making Poster He Is The Best Poster Maker.. [2012]
DooMLord ~ For Many Things Like Kernel And WiFi Modules
Doom151 ~ As Using His Aroma As A Reference
TheFrankenstain ~ For PowerSave,System Tweak And Other =)
Supervenom~For AOKP
Andriod MooDeD AOKP v1.0 [ROM]
New Version:
Want Latest Updates Of My ROM Follow Me On Twitter:
AROMA Installer :
Installation Instructions :
Transfer the zip file you downloaded above to your internal sdcard (not the external micro SD).
Turn off the phone, then boot into recovery mode. For this, press and hold Menu Button Until CWM screen shows up: Volume Button.
Phone will boot into CWM recovery. Use volume keys to scroll up and down between options and power/home key to select an option.
Perform a wipe:
Select wipe data/factory reset. Then select Yes on next screen to confirm. (This will not touch your SD cards so dont worry).
Go to advanced and then select wipe dalvik cache, then select Yes on next screen. Now, go back to main screen of recovery.
Select mounts and storage, then select format system. Select Yes on next screen to confirm. Go back to main recovery menu after system format is complete.
Then, select install zip from sdcard, then select choose zip from sdcard. Then, browse to the file you transferred to the sdcard in step 2 and select it.
Confirm installation on the next screen by selecting the option Yes Install MooDeD ICS.zip. The ROM will now start installing.
After installation is complete, select go back then select reboot system now to reboot the phone.
Perform a wipe:
Why To Choose My ROM?
Cause This ROM Is The Fastest And Light No-Redraws 96% And 100% Daily Update
FAQ :
Q: I can't find my ext sdcard!
A: using file manager go to /emmc
Q: I Keep On FC.
A: Delete All Init.d Tweaks.
Q: when I connect the phone to PC I cannot mount my sdcard!
A: It Really DOESNT HAPPEN 100%
Q: I Have A Lag Or The ROM Is Slow ...
A: Just Request to me Remove Application So Some Bloatware Will Be Remove
Q: gallery is too slow!
A: give it some time to scan or download quikpic free from market
Q: I have too many force closes and bugs not found on this thread!
A: relate to installation instruction in OP
Q: I Keep On FC.
About the ROM :
Base : 4.0.3 ICS : FULL ICS BASE FROM SOURCE ICS ftf by Sony ( Thanks To HIM
What can you expect? Well, Basically the sames bugs as ICS, and the Full ICS user experience, with all their awesome mods.
It's has been tested by my Recognized Tester (Duvel999 Etc.... !)
It's Rockstable, nothing more nothing less. It's Blazing fast.
It contains Light Gapps. If you're missing some apps that are related to Google, go on and flash latest ICS Gapps. It has now the ICS Settings, from CM9 !
'Bout the recovery. Stock, not touch. Some users don't understand how it works, and freak out because they can't use it or restore their beloved Sony ROMs() , so it's stock.
Next Update Day:
N/A
Miscellaneous Area:
Working HD Games:
Tested and working:
- 9MM HD
- Asphalt 5
- Asphalt 6 HD
- BackStab HD
- GT Racing HD
- Shrek Karting HD
- UNO HD
- Dead Space
- Reckless Racing 2
- Modern Combat 3
- World of Goo
- Let's Golf 1
- GSM => working
- SMS => working
- AUDIO => working
- VIDEO => working
- GPS => working
- ANT+ => working
- WIFI => working
- camera => working
Fixes And HotFix Download Area:
Fixes :
Screenshots:
[Cooming SOON!]
By: ChaosFirZen XDA
Special Thanks To:
Supervenom~For AOKP
