[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
j1gga84
j1gga84
Ehrenmitglied
6.259
I9100 CyanogenMod 13.0
Powered with: Linaro and SaberMod!
In brightest day, in blackest night, no lag shall escape my sight. Let those who worship Apple's might, beware my power, Green Lantern's light!
cm-13.0-20161001-MARKOX89-i9100 ist da!
Download
-> Hier im jeweiligen Monatsordner schauen
AFH berechnet die md5sum für jede build: bitte diese immer vor dem Flashen überprüfen!
Alte Versionen
Alte Downloads (CM12.1) - Letzte Version vom 11.03.2016
Download
Alte Downloads (CM11)
Download Ordner auf AndroidFileHost
Highlights der Hauptmerkmale:
Changelog:
  • DownloadProvider: add to support pause/resume download by manual --> CyanogenMod/android_packages_providers_DownloadProvider
  • Adding metrics related to Ridesharing --> CyanogenMod/android_packages_apps_Messaging
  • CMFileManager: remove shortcut option for secure folders --> CyanogenMod/android_packages_apps_CMFileManager
  • MediaPicker: Check for NPE --> CyanogenMod/android_packages_apps_Messaging
  • Avoid NPE --> CyanogenMod/android_packages_apps_Eleven
  • Eleven: Do not uppercase unnecessarily --> CyanogenMod/android_packages_apps_Eleven
  • Snap: Add picture resolutions for Axon 7 --> CyanogenMod/android_packages_apps_Snap
  • Revert "envsetup: Always look up JAVA_HOME path" --> CyanogenMod/android_build
  • bootanimation: Fix preload of shutdown & themed animations --> CyanogenMod/android_frameworks_base
  • cm: Minor config reorganization --> CyanogenMod/android_vendor_cm
  • Contributors: Add maintainer for Alcatel Idol 3 --> CyanogenMod/android_vendor_cm
  • Added contributors for vegetalte --> CyanogenMod/android_vendor_cm
  • fastboot: Add Alcatel's USB vendor id --> CyanogenMod/android_system_core
  • themes: Relabel theme dir after creation --> CyanogenMod/cm_platform_sdk
  • themes: allow system_server to relabel them dir --> CyanogenMod/android_vendor_cm
  • CdmaServiceStateTracker: Load CarrierConfig for NV Subscription --> CyanogenMod/android_frameworks_opt_telephony
  • Add dest length parameter to utf16_to_utf8 --> CyanogenMod/android_external_mm-dash
  • Settings: Fix possible NPE --> CyanogenMod/android_packages_apps_Settings
  • Settings: Notification light: Fix for app customization --> CyanogenMod/android_packages_apps_Settings
  • Fix tracking Apply Update dialog visibility --> CyanogenMod/android_packages_apps_CMUpdater
  • DevelopmentSettings: Add an opt-out for recovery updater --> CyanogenMod/android_packages_apps_Settings
  • DataUsageProvider: Fix possible NPE --> CyanogenMod/android_packages_providers_DataUsageProvider
  • AudioFX: Fix possible NPE --> CyanogenMod/android_packages_apps_AudioFX
  • Gello artifact v37 --> CyanogenMod/android_vendor_cm
  • Add permissions for ridesharing --> CyanogenMod/android_packages_apps_Messaging
  • Fix eject SD card icon being too dark --> CyanogenMod/android_packages_themes_HexoLibre
  • CMUpdater: Vector drawables --> CyanogenMod/android_packages_apps_CMUpdater
  • Update device settings theme and theme CMUpdater --> CyanogenMod/android_packages_themes_HexoLibre
  • Theme new Theme Chooser icon --> CyanogenMod/android_packages_themes_HexoLibre
  • Contributors: Add maintainers for BQ Aquaris M5 (piccolo) --> CyanogenMod/android_vendor_cm
  • SysUI: Don't set panel bar to null and avoid NPEs --> CyanogenMod/android_frameworks_base
  • Don't unboundedly enqueue transition messages. --> CyanogenMod/cm_platform_sdk
  • Adjust map and map bar UX --> CyanogenMod/android_packages_apps_Messaging
  • Fix getProviderInfo compile error after api change --> CyanogenMod/android_packages_apps_Messaging
  • Add don't optimize flag in proguard to avoid build error --> CyanogenMod/android_packages_apps_Messaging
  • Add maps preview for addresses and integrate ridesharing request into Messaging --> CyanogenMod/android_packages_apps_Messaging
  • increment ambientsdk version --> CyanogenMod/android_vendor_cm
  • Don't crash while entering in DevelopmentSettings --> CyanogenMod/android_packages_apps_Settings
  • Trebuchet: fix potential NPE when info is null --> CyanogenMod/android_packages_apps_Trebuchet
  • Trebuchet: STK app rename customization for latam region. --> CyanogenMod/android_packages_apps_Trebuchet
  • More...
Installation von CyanogenMod 13.0 auf dem Galaxy S II:
  • Kopiere CM13.0 Zip und ein kleines GApps Paket auf deine interne oder externe SD Karte;
  • Vergewissere dich einen Kernel OHNE den MMC-Superbrick-Bug und eine Marshmallow kompatible Recovery zu verwenden;
  • Falls du unsicher bist, flashe die CWM 6.0.4.5 (s. unten) über deine aktuelle Recovery;
  • Boote in die Recovery;
  • Flashe CM13.0 zip;
  • Flashe GApps;
  • Falls du von einer anderen, nicht CyanogenMod, ROM kommst mache einen Data Wipe / Factory Reset (ansonsten wird dein Gerät beim Booten hängen bleiben);
  • Reboote.
Downloads:
Buildbot:
  • CPU: Intel Core 2 Quad Q8300 2.50 GHz
  • MotherBoard: ASUS P5K
  • RAM: 4 GB Corsair DDR2 667 MHz
  • Main HD: SanDisk SSD SDSSDP-128G 128 GB SATA 6 GB/s
  • ccache HD: Western Digital Raptor WD1500ADFD 150 GB SATA 1.5 GB/s
  • OS: Linux Lubuntu 16.04 "Xenial Xerus" x64
  • Kernel version: 4.4.0
Spenden:
Wenn dir die Arbeit von Markox89 gefällt kannst du dir überlegen einen kleinen Betrag zu spenden indem du diesem Link folgst.
Spezieller Dank:
    • CyanogenMod Dev Team
    • Linaro Dev Team
    • sparksco and the whole SaberMod Dev Team
    • IAmTheOneTheyCallNeo
    • Lysergic Acid
    • JustArchi
    • fusionjack
    • tuxafgmur
    • Android-Andi
    • Infected_
    • -Grift-
    • prace86
    • jamal2367
XDA-DevDB Information
[ROM][I9100][MM][6.0.1][Linaro][SaberMod] CyanogenMod 13.0, ROM for the Samsung Galaxy S II
Mitwirkende
Markox89
Quellcode: CyanogenMod · GitHub
ROM OS Version: 6.0.x Marshmallow
ROM Kernel: Linux 3.0.x
Notwendige ROM Firmware: CWM Recovery
Basierend auf: CyanogenMod
Reaktionen: pjozsef54, reklovd, hrjde und 15 andere
Ich finde diese Rom von allen anderen einfach an besten!Mit dieser Rom gibt es keine Experimente!Kein schnick schnack eingebaut(somit werden Fehler vermieden!)!Diese Rom wird von Infected 1:1 umgesetzt!Heißt man setzt die Vorgaben von CM 100% um!Am besten man macht sich einfach selbst ein Bild und testet sie!Ich habe hier schon etliche Roms getestet und finde diese Rom einfach an besten!
Wenn ich lese,dass etliche User mit anderen Roms immer wieder Probleme haben,dann schüttle ich immer mit dem Kopf!Weil sie einfach nicht auf die Idee kommen,dass es auch bessere Roms gibt!Und diese Rom ist einfach besser als alle anderen Roms!Aber es soll einfach jeder selber seine Erfahrungen machen!
Diese Rom ist Stabil und vor allem inoffiziell von CM!Und ja,sie ist Alltagstauglich;)
Dies sollte jetzt keine Werbung sein!Sondern ist meine Persönliche Meinung!
Und ich hoffe,dieser Kommentar wird nicht gelöscht!
Wünsche allen Usern hier ein frohes Weihnachtsfest!
Reaktionen: TeilchenD, Muhtant und ->TopAZ<-
Androidflash schrieb:
... 3. Checke ob deine Recovery aktuell ist. Wenn nicht, muss eine geflashed werden. Die .zip Datei für eine ältere Recovery kann hier downgeloadet werden. Die .tar Datei für Odin kann hier gedownloadet werden.
Guten Morgen,
was bedeutet aktuell? Funktioniert es mit CWM 6.0.3.6 oder ist eine neuere erforderlich?
Mfg Ice
@Ice-Only
Wenn du eine Version unter 6.0.x.x hast,dann bricht die Installation ab!Ich würde dir schon empfehlen,den genannten Kernel zu installieren!
hab die rom seit gestern drauf, läuft ganz gut
ein paar kleinere bugs, z. b. übernimmt das clock widget auf dem sperrbildschirm die einstellungen für fettschrift der uhrzeit nicht
Ice-Only schrieb:
..... Funktioniert es mit CWM 6.0.3.6 oder ist eine neuere erforderlich?
Es empfiehlt sich, die aktuelle CWM-Version 6.0.4.5 zu nehmen (hier http://goo.gl/u8oTbD )
Ein Kernel-Flash ist gar nicht notwendig (mit Kernel-Flashen sollte man sowieso zurückhaltend sein, solange man die Folgen nicht einschätzen kann) - obige CWM via Odin geflasht reicht.
Reaktionen: craxxx25 und ->TopAZ<-
Muss sagen, ich finde diese ROM-Version ein ganz kleines bisschen (für mich persönlich gesehen) - "besser" als die von Wayland - stammen ja beide sozusagen aus den selben Quellen-Pool :)
Aber dadurch das die Updates öfters kommen, war diese Version meine 1.Wahl.
Großartige Unterschiede von der Geschwindigkeit konnte ich bei beiden Versionen nicht wirklich in der Benutzung feststellen, trotz der Sabber&LinaroModifikation.
Aber gerade da hier die inoffiziellen Nightlys rauskommen, war die Entscheidung daher sozusagen mein kleines KO-Kriterium.
Nutze den Kernel von gustavo und bin soweit sehr zufrieden mit den Versionen :)
Was ich leider in beiden Versionen für das S2 schade finde, ist das der LowMemory-Mode sich nicht einschalten lässt (oder ich finde einfach die Option nicht) - da dies nochmal wahrscheinlich ein Geschwindigkeits-Plus geben sollte.
Leider funktionieren mit der "offiziellen" /Inoffiziellen CWM, wie auch mit der von gustavo das USB-Mounting in der Recovery noch nicht - habe aber festgestellt, das dies bei der letzten CM10.1 und CM10.2 auch nicht mehr funktioniert (mit Philz Recovery funktionierte das irgendwie noch).
Mal schauen was so die Zukunft bringt, ansonsten bin ich sehr begeistert von der Arbeit der beiden Devs und dem CM-Team. Absolute Lieblings-KK-Rom derzeitig für mich :)
Reaktionen: pjozsef54 und ->TopAZ<-
Hi zusammen,
nur nochmal fürs Verständnis:
Wenn ich die Nightlys aktualisiere reicht es aus wenn ich:
1. Neuste ZIP hier runterlade: My Files
2. diese auf die SD Karte schiebe
3. diese übers CWM installiere.
4. unter advance- > wipe dalvik ausführen
5. reboot
6 fertig
was vergessen?
gruß und schöne Weihnachten
mrkaterkarlo
Ich bitte Androidflash darum, den Thread den Richtlinien anzupassen.
[OFFURL]https://www.android-hilfe.de/samsung-firmware-basierende-custom-roms-fuer-samsung-galaxy-note-2/499259-richtlinien-zur-gestaltung-von-rom-threads.html[/OFFURL]
Bei Titeländerung mir eine PN hinterlassen.
Mit freundlichen Grüßen,
Pr0TuRk38
Reaktionen: ->TopAZ<-
gibt es einen passenden kernel? der Gustavo geht ja mal gar nicht :/ 60% in nur 1 1/2 stunde ist doch unmöglich! gibt es einen anderen Kernel der nicht nur zum Akku saugen da ist?
wow danke... nur das ich schon in threads war und sogar fragen gestellt habe wie dies und jenes für eine Akkuleistung hat, gab es keine antwort also im ernst...
Pr0TuRk38
Ich hab doch den Titel nicht mal geändert. Das war ein Moderator.
Threads in Deutsch:
wir sind ein deutschsprachiges Forum. Zu uns kommen also auch oft Leute, die andere Sprachen nicht oder nur eingeschränkt verstehen. Und wer würde schon damit rechnen, wenn er auf deutsch etwas sucht, daß er Englisch, Italienisch oder Spanisch lernen muß?
Hab ich ja übersetzt
Kein Copy & Paste aus anderen Foren
wenn ihr ein gutes Rom in einem anderen Forum entdeckt habt, verzichtet darauf den kompletten Text einfach hier her zu kopieren. Dafür reicht es doch aus, wenn man einen Link auf das jeweilige Forum setzt. (siehe auch erster Punkt). Beschreibt doch in eigenen Worten das Rom, seine Stärken und Schwächen, eventuelle Besonderheiten.
Es ist natürlich keiner Böse, wenn einzelne Passagen zitiert werden (z.B. Feature-List)
Ist damit gemeint das die ROM mit Linaro kompiliert wurde?
Keine großen Bilder:
unsere Nutzer sind mit vielfältigen Geräten hier unterwegs. Oft sieht man dann eingebettete Bilder, die die Anzeigemöglichkeit von den Geräten übersteigt. Wenn ihr Bilder nutzt die Größer als 800pixel (Höhe oder Breite) haben, beschränkt euch daher darauf diese nur als Anhang anzufügen. Das macht das ganze wesentlich übersichtlicher und erspart Scroll-Orgien.
Bilder hab ich keine
Nicht zu bunt und auffällig
Geht mit Farben, Schriftgröße und Sonderzeichen sparsam um. In der AH-App werden z.B. die Größenangaben ohnehin ignoriert. Und wenn es zu bunt wird, führt es leicht dazu daß man sich vom Thread abgestoßen fühlt. Und bedenkt, daß Sonderzeichen (z.B. ~|µ²³) nur selten in der Suche genutzt werden und den Threadtitel doch seltsam aussehen lassen
Ich hab alles vermutlich in 1 Schrift geschrieben also keine Sonderzeichen oder sowas
Der Threadtitel ohne Sonderzeichen
Es geht im Titel um Information und nicht darum möglichst tolle Sonderzeichen zu verwenden. Weiterhin gibt es damit immer Darstellungsprobleme in den Forum-Apps.
Falls Klammern Sonderzeichen sind hat der andere Moderator das ganze eh schon geändert. Wann die Änderungen übernommen werden weiß ich nicht
@patsem
Wie oft soll ich dich noch auf deine Rechtschreibung hinweisen? Bitte!!!
Wegen Akku: Wenn du eine ROM neu flasht ist es völlig normal, dass der Akkuverbrauch erst mal steigt. Wenn es nach einem Tag immer noch ist, dann stimmt was nicht. Oftmals liegt es am unsauberen flashen. Dafür haben wir aber Scripte.
  1. Script: Script zum WIPEN über CWMR vor Flash einer neuen Software
  2. Script: Ultimate Kernel Cleaning Script
Außerdem hat jeder einen anderen Akkuverbrauch und wir haben extra für Akkufragen eigene Threads, die sogar unterteilt sind in SAMMY und AOSP/CM.
Der ursprüngliche Beitrag von 16:48 Uhr wurde um 16:52 Uhr ergänzt:
Ja. Habe ich geändert. Wo ist das Problem? Habe ich was falsch gemacht?
Original:
CM11 4.4.2 Linaro/Sabermod [Nightly Builds]
geändert: [CM11][4.4.2] Linaro/Sabermod [Nightly Builds]
Für mich ist der Threadtitel ok aber ein anderer Mod meinte ja das der neue Titel nicht den Threadrichtlinien entspricht.
Hat er auch nicht Unrecht. Es fehlt im Gegensatz zu den ganzen anderen Titeln ein wenig "Info". Schau es dir mal bitte an und kannst es ja noch ändern.
Und bitte keine Direktzitate.
Kurze Frage:
Kann ich eigentlich vom aktuellem CM 10.2 Nightly auf die Linaro updaten oder muss ich komplett neu aufsetzen ?
Danke.. :thumbsup:
Kannst Du - ein bißchen Durchwischen hilft u. U.! ;)
Mach vorher ein Nandroid Backup Deiner CM10.2.
Reaktionen: tino.bino
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
