[AOSP/SAMMY-KERNEL][ICS] *20.07.12* N.E.A.K. - [v2.1.1x] !!WARNUNG BEACHTEN!!
pro.aggro
pro.aggro
Ikone
3.413
!!!!!ACHTUNG!!!!!
DIE NEUSTE VERSION ENTHÄLT KEINE RECOVERY! FLASHEN AUF EIGENES RISIKO!
The lightest kernel for I9100 ever made!!
ONLY FOR INTERNATIONAL I9100!!
- Based on sammy update6 sources, updated to 3.0.37
- Touch CWM Recovery 5.5.0.4 NEAK Modded
- Governors: Ondemand, LulzactiveV2(default), Performance, Conservative (module), Lazy (module)
- Schedulers: BFQv3-R2, Noop, SIO, VR (default)
- Using JRCU (++smoothness, ++responsiveness)
- XZ Compression only for KERNEL (+speed, --size)
- Built-In support for Voodoo Louder!
- Fully compatible with: Voodoo Louder, Tegrak's 2nd Core, Tegrak's Lulzactive app, Voltage Control, SetCPU, CWM Manager
INITRAMFS AND MISC:
- Manual Rooting via NEAK Recovery Menu (3.0.7 + latest binary)
- Auto-install of modded BLN Liblights (for both versions)
- Init.d Support (auto creation of init.d folder via cwm)
- Bootanimation Support (system/media & data/local)
- Touch Move Support + Touchscreen Fix (5 - thx to vitalij)
- BLN v2 support (by Creams, thx to gm for the porting)
- Full BLN Breathing + Blinking support (thx to myfluxi for aosp and gm for sammy)
- CIFS, FUSE, CUSE Support (modules)
- Logger already enabled into the kernel
CPU/GPU:
- NO OC!!!! (100-1200Mhz)
- CPU frequency scaling bug fixes, no more freezes!! (thx to gm & entropy)
- CPU Undervolt support (thx to netarchy, rebased by me)
- Complete control of freqs/voltages with Voltage Control/SetCPU/NeakPro
- GPU Overclock/Undervolt (by netarchy)
- Charging current interface support (by GM - via Voltage Control)
- Speedmod Sharpness fix (thx to hardcore)
- Brightness Curve Mod (thx to GM)
- mDNIe and panel settings moddable (thx to myfluxi)
MEMORY & PERFORMACES:
- ARM CPU Topology + sched_mc (can be enabled via CWM, disabled by default)
- SLQB Allocator (better memory management)
- Improved memory management functions
- Allow CPU Unaligned access (++performaces)
- Disabled all the big debugging (++speed, --size)
- AFTR ARM Idle Mode (enable via neak app or recovery)(++battery)
CONNECTIVITY TWEAKS:
- M250S WiFi drivers + Upstream updates (+performances, -issues)
- Disabled debugging WiFi/BT
- TCP/IP Tweaks
- TCP buffer tweaks
OPTIMISATIONS:
- Dynamic Hotplug with tweaked thresholds (with Tegrak's 2nd Core support)
- 2nd CPU Core OFF when screen is locked (thx to arighi)
- ARM_ERRATA_743622 & ARM_ERRATA_754322 & ARM_ERRATA_754327
- Upstream patches and fixes from Linux 3.2/3/4 mainline kernel
- GPU UI Rendering
- Fixed fuelgauge wakelocks (by Entropy)
- Compiled with Linaro GCC 4.5-2012.03-dev + A lot of optimisation flags (including hard float and graphite)
- Optimised EXT4 filesystem
- Generally optimised code (removed useless functions and variables, fixed warnings)
and many others...
- Modded Recovery with N.E.A.K. Menu:
1) Remove voltage settings (Voltage control)
2) Create EFS Backup (in /sdcard/near)
3) Bus ASV Voltages Table Settings... ---> 7 voltage levels
4) Governors Menu...
- Enable/Disable Conservative Governor
- Enable/Disable Lazy Governor
- Enable/Disable Lionheart Tweaks (only with conservative gov)
- Enable/Disable Lagfree Governor
5) Misc Options Menu...
- Enable/Disable sched_mc power functions (++battery, - performance)
- Enable/Disable AFTR Idle Mode
6) Configurator PRO Menu...
- Various cleaning for scripts
- Cleaning neak folder
7) ROM TOOLS MENU (in main menu)
- Clear init.d folder
- Install/Reinstall Root
- NEAK CONFIGURATOR APP (also PRO)
- NO COMPRESSION for Initramfs
- Tweaked Ondemand, lulzactive and lazy governors
- Tweaked BFQ, SIO and VR Schedulers for NAND devices
v2.1.1x (AOSP & SAMMY+MIUI):
KERNEL:
- Re-Based on Samsung Update6 sources
- Updated to Linux 3.0.37
- Stock WiFi drivers from Update6 sources
- bcmdhd: Change packet filter settings to block multicast (thx to Entropy)
- Reverted original haptic feedback motor
v2.1x (AOSP & SAMMY+MIUI):
KERNEL:
- Updated to Linux 3.0.36 sources
- cpufreq: another change to stop Level not found issue (thx to Ktoonsez - should fix slow-mo issues)
- mach-exynos: cpufreq: Fix derpage that caused level not found errors
- cpufreq: reverting to original Entropy512's level-not-found fix
- max8997_vibrator: user configurable vibrator intensity (thx to Entropy512 & codeworkx)
- keyboard: cypress: Use standard voltage for constant/blinking bln
- keyboard: cypress: Ensure light is off, enable regulator only if needed
- mach-exynos: mshci-gpio: Small change from N7000 source drop
- wakelock: (tungstwenty's implementation) expanded deleted wakelocks
- wakelock: main_wake_lock fix by tungstwenty
- net: wireless: bcmdhd: Reduce priority for dhd_dpc and watchdog
MISC:
- Removed some more debug infos
v2.0.6x (AOSP & SAMMY+MIUI):
KERNEL:
- Updated to 3.0.33
- keyboard: cypress: Don't renew notification timeout option
- keyboard: cypress: Automatically enable BLN while charging (aosp)
- mach-u1: Fixing light sensor breakage
- vr: fifo_batch set to 1
- Various updates of WiFi driver
- sched_rt: fix SCHED_RR across cgroups
- ld9040: increase boot gamma level to original GAMMA_160CD level
- Updating sammy cypress driver from SiyahKernel
- max8997: Implement Accessory Charger Adapter support
- Patch the firmware of certain Samsung emmc parts to fix a bug
- mach-exynos: tmu: add tmu sysfs for temperature reading
- modem_if: update modem driver to update5 sources
- usb: gadget: composite: Fix corruption when changing configuration
- sched: fix cpu index check in get_cpu_nr_running funtion
- mali: Driver update from N7000 Update 3 sources
- USB Gadget updates
- mach-u1: Allow reduced GPU voltage
- fs: fat: fallocate support for fat driver (from n7000 sources)
- ext4: add missing save_error_info() to ext4_error()
- mc1n2: replace mdelay() with msleep() to be consistent with GB kernels
INITRAMFS:
- aosp: updated initramfs from latest cm9 nightly
THANKS TO MYFLUXI AND GOKHANMORAL FOR A LOT OF PATCHES!
v2.0.5x (AOSP & SAMMY+MIUI):
KERNEL:
- Updated to 3.0.31
- usb: disable parent hub tt detection to get HID devices working (gm)
- usb: otg: merges with sztupy's usb host mode build 5 (gm)
- u1-otg: disable irqs on dev when otg host is stopped (gm)
- cpufreq: fixing vdd_levels interface (gm)
- busfreq: added another asv table voltage step (lvl 7, heavy uv)
- mach-u1: raised movhysti to 4
- mach-exynos: clock-exynos4: sync clock related exynos4210 code with update5 sources (gm)
- tspdrv: Add adjustable vibrator levels (myfluxi)
- netfilter: xt_qtaguid: start tracking iface rx/tx at low level
- ld9040: reworked gamma values and settings from SiyahKernel (gm)
- touchscreen: mxt224_u1: Update touch values according to power state (myfluxi)
- touchscreen: mxt224_u1: Use mxt224_ta_probe instead of writing directly (myfluxi)
- keyboard: cypress: Add LED breathing effect (myfluxi+gm)
- keyboard: cypress: Use CMs original BLN timeout mechanism (myfluxi) - only aosp
- keyboard: cypress: Stop notification on low battery (myfluxi) - only aosp
- keyboard: cypress: Add LED button fade out effect option (myfluxi) - only aosp
- Add ACCESSORY_SET_AUDIO_MODE control request and ioctl
- USB: gadget: f_accessory: Add support for HID input devices
- USB: gadget: f_audio_source: New gadget driver for audio output
- net: wireless: bcmdhd: Check return value from dhd_dev_init_ioctl()
- net: wireless: bcmdhd: Ignore signal_pending() while waiting in IOCTL
- netfilter: xt_IDLETIMER: Use uevent instead of new netlink msg type
- net: check return value for dst_alloc
- ipv6: check return value for dst_alloc
INITRAMFS:
- using lvl 3 as default for bus asv voltages
- raised min_free_kbytes again for any kind of toggle issues
MISC:
- Reworked kernel name string
v2.0.4x (AOSP & SAMMY+MIUI):
KERNEL:
- Updated to Linux 3.0.30
- RCU: Joe's RCU
- Updated WiFi driver to M250S update5 sources (no more toggling issues)
- mach-exynos: busfreq: Add undervolt option using asv table (use neak menu from recovery to manage it) - thx to myfluxi
- sync: Add synchronization framework
- ld9040: Add adjustable gamma levels (thx to myfluxi)
- mDNIe: Add adjustable settings (thx to myfluxi)
- ld9040: increase number of gamma levels from 21 to 25 (thx to gm)
- cpufreq: removed smooth_scaling interface
- cpufreq: Separate speed target revalidate time and initial set time
- cpuidle: reverted to official samsung source drivers
- usb modifications to get HID working and fix OTG crashing (thx to gm)
- usb: final fix for crashing phone while using usb or charger
- ARM: smp: Align secondary_start_kernel with mainline
- ARM: SMP: use a timing out completion for cpu hotplug
- arm: vfp: Fix memory corruption on PM suspend
- ARM: vfp: only clear vfp state for current cpu in vfp_pm_suspend
- defconfig: removed RCU_BOOST feature
- defconfig: removed netfilter OWNER option (fixes BBS crashing)
- sched: Cleanup cpu_active madness
- Disabled GENTLE_FAIR_SLEEPERS (+responsiveness)
- usb: using 2 different modded drivers for aosp and sammy (to avoid usb issues)
- lowmemorykiller: upstream updates and improvements
- MAKEFILE: Removed asv-4x12.o and cpufreq-4x12.o
- Upstream updates for WiFi drivers
- Removed CUSE module
INITRAMFS:
- TOTAL RECOVERY RESTYLING (added clock, new headers, rom tools menu...)
- Fixed wrong path for sdcard into EFS Backup
- Updated samsung liblights, now perfectly working with brightness and bln (thx to gm)
- Using MTP as default on sammy roms
- Fixed ADB corrupted binary file into sammy initramfs
- Updated sammy init files
- Updated aosp init files from latest aokp build
- MANUAL ROOTING VIA RECOVERY NEAK MENU!
- recovery: using noop+ondemand while in recovery mode (faster backup/restore)
MISC:
- Official NEAK I777 support (into I777 forums)
- Enabled PANIC_TIMEOUT (so it reboots when SoDing)
- Re-tweaked XZ compression values (boots faster)
- Tweaked touch sensitivity
- Moving init.d folder to init.d-old while flashing
v2.0.3x (AOSP & SAMMY+MIUI):KERNEL:
- Updated to 3.0.28
- Updated WiFi drivers
- Fixed potential WiFi toggle issues (thx to wjchen)
- Fixed a lot of compiling warnings (thx to myfluxi)
- lulzactive: safety floor for up_sample_time
- Switching again to SHMEM (fixes flashing themes from cwm)
- net: now using Stochastic Fair Blue NET Scheduler (SFB)
- mach-exynos: Enable old s5pv310 pm-hotplug module (thx to myfluxi)
- Using hotplug thresholds from NEAK GB kernel
- power: lowered misc charge current
- cypress: using myfluxi's touchkey driver (for AOSP, with BLN)
- Touchkey timeout for AOSP roms set to 1s
- Tweaked smooth_scaling parameters (+responsiveness)
- Upstream and CM9 sources updates
- Netfilter upstream updates
- arm: SMP: Fix RCU stalls due to mis-backported upstream patch (thx to Entropy512)
INITRAMFS:
- More cleanup
- Modified Recovery UI (and fixed options issues)
- Corrected format for emmc (now external) and sdcard (now internal)
- Using original NET buffers
- Removed J4FS module (afaik doesn't work, neither if insmodded)
- FULL SUPPORT FOR OFFICIAL MIUI (using sammy version)
- Fixed WiFi into latest CM9 nightlies
- NO SWITCHED MOUNTS FOR SDCARDs YET!! (i want to wait)
- Using mass storage mode for both MIUI and Sammy roms
- Fixed USB Mount into CWM Recovery
MISC:
- A bit reduced kernel compression
- The ZIP file now clears INIT.D folder during flashing
- Using NEON for VFP
- More optimised CFLAGS
- Updated Linaro 4.5 toolchain to latest dev build
v2.0.2x (AOSP & SAMMY):
- Support for MIUI ROMs (only AOSP version of NEAK)
- Fixed lags into UI (removed CFS tweaks)
- Fixed DPI issues into AOSP ROMs
- Enabled CRC32 slice-by-8 algorithm
- exynos4: Disable SW downclock in cpuidle
- galaxys2: made google gadget code using 2 luns for aosp roms
- cpufreq: smooth scaling interface
- recovery: fixing switched mounts for both sdcards into mounts&storage menu
- ondemand: tweaking for responsiveness
- vr: a bit tweaking for a bit more throughput
- enabled mass storage mode for aosp roms (who supports it)
- sched: re-enabling GENTLE_FAIR_SLEEPERS
- TCP buffer tweaks
v2.0.1x (AOSP & SAMMY):
- Updated to Linux 3.0.27 kernel
- Fixed touch buttons and swype into Recovery (thx to gm)
- Tuned lulzactive parameters
- New lulzactive based on newest interactive (thx to gm)
- Added pegasusq governor (for who wants it...)
- Added J4FS module (but seems not working fine)
- mali: more aggressive GPU thresholds (++3d performance)
- cm3663: set initial state of proximity sensor to "far" (codeworkx)
- stand-hotplug: Don't ever hotplug out cpu 0 (thx to Entropy512)
- mach-exynos: stand-hotplug: Improve CPU0 turnoff protection logic (thx to Entropy512)
- Tweaked hotplug thresholds (+responsiveness)
- No more lags at all in any kind of rom!
v2.0x (AOSP & SAMMY):
- Based on samsung update4 sources
- Patched up to 3.0.26 (thx to linaro)
- Modded CWM Recovery Touch 5.5.0.4 (thx to sk8erwitskil) ---> touch broken, use normal buttons
- Frequency steps from 100 to 1200Mhz (default 200-1200)
- Governors same as GB version (default lulzactive)
- Schedulers same as GB version (default VR)
- GPU OC/UV interface (thx to gm, netarchy & myfluxi)
- Full compatibility with NEAK APP FREE/PRO (needs update for pro)
- Reworked lulzactiveV2 governor to use dec_load_cpu parameter (by simone201)
- Fixed sync issues with scaling (thx to entropy & gm)
- Supports: CWM Manager 3.15, Tegrak OC, 2nd Core, lulzactive app, touch move (needs update), Voodoo Louder, SetCPU & Voltage Control
- XZ Compression with optimisations
- Removed 3/4 of the debugging
- Fix for touchscreen sensitivity (thx to vitalij and myfluxi)
- Speedmod's Sharpness FIX (ported, thx to hardcore)
- ARM CPU Topology + sched_mc (thx to linaro)
- Undervolt interface (thx to netarchy, ported by me, gm & myfluxi)
- CGROUP_TIMER_SLACK, RCU_BOOST and many more performance improvements
- Various netfilter options enabled
- Brightness curve mod (thx to gm)
- SLQB memory allocator
- CIFS, TUN, FUSE & CUSE
- BLN v2 support in both AOSP and SAMMY roms (use bln app)
and many more things (check my repo for more infos)​
SOURCE CODE (2 branches, dev & master): Click Here
Credits:
- Samsung (original sources)
- Hardcore (screen patches + some scripts)
- Gokhanmoral (bus freq control + charging current + some scripts + a lot of help!)
- netarchy (GPU OC/UV + conservative patch)
- Entropy512 (many fixes & patches)
- Tegrak + Vitalij (lulzactive + 2nd core + touch move)
- Cattleprod (some fixes and patches)
- supercurio (voodoo + help)
- linaro (arm topology)
- 89luca89 (GingerMod Updater)
- myfluxi (many patches!)
and many others that have helped or supported me!
by Simone201
Original XDA Thread
  • N.E.A.K-2.0x-AOSP.zip
  • N.E.A.K-2.0x-SAMMY.zip
  • N.E.A.K-2.0.1x-AOSP.zip
  • N.E.A.K-2.0.1x-SAMMY.zip
  • N.E.A.K-2.0.2x-AOSP.zip
  • N.E.A.K-2.0.2x-SAMMY.zip
  • N.E.A.K-2.0.3x-AOSP.zip
  • N.E.A.K-2.0.3x-SAMMY.zip
  • N.E.A.K-2.0.4x-AOSP.zip
  • N.E.A.K-2.0.4x-SAMMY.zip
  • N.E.A.K-2.0.5x-AOSP.zip
  • N.E.A.K-2.0.5x-SAMMY.zip
  • N.E.A.K-2.0.6x-AOSP.zip
  • N.E.A.K-2.0.6x-SAMMY.zip
  • N.E.A.K-2.1x-AOSP.zip
  • N.E.A.K-2.1x-SAMMY.zip
Reaktionen: spucky, S7rik3r, denyo81 und 26 andere
Platzhalter
Platzhalter.
Platzhalter..
langsam langsam bitte wichtig sauber laufen und bastelt neak kernel :D
Simone programmiert den Kernel? Ich dachte der Entwickler wäre männlich ;)
Sie wird es aber schwer haben gegen die Siyah Konkurrenz. Denn schon nach 24h läuft dieser schon sehr, sehr gut :)
Siyah läuft gut keine Frage. Aber ich finde schon das Recovery-Touch-Menü aus dem N.E.A.K. 1.4.2 viel besser als das vom 3er Siyah.
Abwarten :)
Klar, Konkurrenz belebt das Geschäft und ist ein Ansporn für jeden Entwickler seinen Kernel maximal zu optimieren :)
Ok, was ich etwas beim Siyah vermisse sind noch der eine oder andere Governor. Aufgelistet sind ja ein paar mehr als die der Siyah bietet. Mal sehen welche der NEAK bieten wird. Glaube da gab es eine andere Auswahl.
Wegen dem Touch Menü, auch beim Siyah nehme ich weiterhin die Tasten. Genau so wie ich die Bios Oberfläche beim PC für dieser EFI Oberfläche bevorzuge *zw*
In Italien ( Dev ist Italiener ) kann Simone auch ein Männer Name sein ;)
Syiah ist nicht schlecht muss ich echt sagen aber er enttäuscht mich ein wenig ich bin verwirrt von dem was er macht einmal das dann das ahhjaa & das währe dann auch noch super :D & zum Schluss kennt sich wieder keiner aus !
____________________
CheckRom V6 + Syiah 2.6.13
Die Sources gibt es seit gestern (oder vorgestern?)!!! Da ist ein bisschen Verwirrung und ein paar Probleme normal. Guck mal wie lange es die Gingerbread Sourcen gab und da gab es auch noch Probleme.
Auf Wunsch des TE wird dieser Thread vorerst geschlossen bis der neue NEAK raus ist...danke für euer Verständnis... ;)
Thread ist auf Wunsch des TE wieder eröffnet.
Eine Bitte, spammt den Thread nicht zu, denn sowohl der TE als auch das Forum wollen eine gewisse Ordnung und Sauberkeit bzgl. der Beiträge...danke für euer Verständnis... ;)
Reaktionen: Manu-1, Blackman1945, A.K und eine weitere Person
NEAK ICS 2.0x Beta1 (well alpha xD)
FOR SAMSUNG BASED FIRMWARES ONLY!!
Please report me asap a kinda feedback with: - ROM ur using - Based on which FW - Which Modem - frequencies and voltages set (please reset them first)
Zip file attached here
MIUI/AOSP/CM9/AOKP users = THIS IS NOT FOR YOU!!! THE AOSP BUILD ALREADY WORKS FINE!
I WON'T GIVE ANY KIND OF SUPPORT FOR THIS BUILD!! DO EVERYTHING AT YOUR OWN RISK!!!
Known issues (afaik for me): - Governor is set to ondemand as default when it should be lulzactive - Maybe issues with USB Mass Storage (it may depend on ur rom) - Low benchmarks scores (still need to figure out why) - Touch buttons in recovery do not work yet
THIS IS NOT INTENDED FOR A REAL RELEASE, IT IS STILL A WIP!
http://forum.xda-developers.com/attachment.php?attachmentid=966273&d=1332776975
Download @ Post #1
Bitte nur flashen, wenn ihr wisst, was ihr tut!!!
SGS II Lite'ning Rom Tapatalk
Also der neak läuft um Längen besser als der siyah!
Bringt er eine separate Version für AOKP Roms raus?
konkret?
Ist der Omega tauglich ?
Ja ist auch omega tauglich, ist einfach smoother und schneller und der Akku verbrauch ist auch besser. Rundum einfach besser.
Reaktionen: franzm19
Nein, so wie ich es verstanden habe wird der fertige Kernel beides unterstützen. Was auch besser so ist >> Dual Boot
SGS II Lite'ning Rom 2.2 Tapatalk
j1gga84
j1gga84
j1gga84
beicuxhaven
HCD
HCD
j1gga84
simplymad
