pro.aggro
Ikone
- 3.413
SpeedMod für ICS ist da!!
Für JellyBean siehe Post 2
ChangelogHi guys,
This is the SpeedMod kernel for Android ICS for the Samsung Galaxy S2 GT-I9100.
This kernel only works with Samsung ICS based ROMs.
SpeedMod's core features are:
- Super stable: No undervolting, overclocking or potentially unstable modifications
- Fast and smooth: Compiler and code optimizations
- Excellent battery life: Remove unecessary logging and debugging
>>> CLICK HERE for more info and the DOWNLOAD links.
>>> CLICK HERE for the Frequently Asked Questions list.
This is an early release with basic functionality only. No CWM yet.
Current features:
Root:
- Automatically installs root (su)
Screen and misc tweaks:
- init.d, TUN, CIFS, IPV6 Privacy support
Performance:
- CPU governor tweaks: increase responsiveness
- IO tweaks
- Read ahead tweaks
- Compiled with optimizations using Linaro GCC toolchain
- Switched to SLAB instead of SLUB
Turned off unnecessary logging for better smoothness and efficiency:
- Disabled Android Debug Logger / logcat
- Disabled Samsung debug
- Disabled various kernel debugging, statistics and tracing options
K3-31:
- Rebuilt using Codesourcery 2012.03 GCC 4.6.3 toolchain
- Minor tweaks to ondemand governor
- Minor tweaks to GPU DVFS driver
K3-30:
- Minor compiler flag changes
- Camera driver fixed for 4.0.4 ROMs
K3-28:
- Rebuilt on new GT-I9100_ICS_Opensource_Update7 source code
- Should be compatible with 4.0.4 ROMs
K3-26:
- Rebuilt on new GT-I9100_ICS_Opensource_Update6 source code
- sched_mc_power_savings set to 0 by default
K3-25:
- Changed to Linaro GCC 4.4 compiler for better stability
- Better MDNIE display settings to eliminate over-sharpening
K3-24:
- Rebuilt on newer source code GT-I9100_HK_IC_Opensource_Update1
- Hide boot partitions (TriangleAway 1.51+ still works)
- Changed some compiler settings to fix boot hangs
K3-21: - Updated mach-exynos cpufreq code from GT-N7000 sources - Updated root: Superuser.apk and su binary to latest versions
K3-20:
- Delayed min_free_kbytes adjustment a bit to prevent hanging at boot
- Enabled utf-8 support for CIFS
K3-19:
- Patched Wifi driver with "bcmdhd: Fix FW hang recovery"
K3-18:
- Slight change to min_free_kbytes to fix the problem of sometimes hanging at boot
K3-17:
- Reverted some compiler flags to fix the problem of sometimes hanging at boot logo
K3-16:
- Tweaks to touchscreen sensitivity
- Compiler flags updated
- min_free_kbytes increased to fix wifi toggling problem
K3-15:
- Tweaks to touchscreen sensitivity:
- - Movfilter for battery set to GB kernel values
K3-7:
- Minor update to IO tweaks
- MDNIE tuning for more natural color and sharpness
- GPU DVFS adjustments
K3-5:
- Minor update to IO read_ahead tweaks
K3-3:
- ARM CPU topology patch from Linaro
- SCHED_MC multi-core aware scheduler patch from Linaro
- Changed to DVFS based CPU hotplug policy
K3-2:
- Added CWM5
- Increased USB charging speed to same speed as AC charge
- max17042: Fix fuel alert wakelocks
- Touchscreen MOVHYST ("Vitalij fix") set to 10
K3-1:
- Initial release
Original XDA Thread
