			Ladylike871
Ehrenmitglied
- 20.270
Ich werde hier nach und nach einen Xposed +Module zusammenfassen und es später auch im Samsung Algemein Forum posten!!
Da es mittlerweile eine Menge Module gibt gebt mir Zeit das ganze zu erstellen!!
Some technical details:
I extended the /system/bin/app_process executable to load a JAR file on startup. The classes of this file will sit in every process (including the one for system services) and can act with their powers. And even more: I have implemented something that allows developers to replace any method in any class (may it be in the framework, systemui or a custom app). This makes Xposed very powerful. You can change parameters for the method call, modify the return value or skip the call to the method completely - it's all up to you! Also replacing or adding resources is easy.
Advantages:
•No need to modify any APKs. This means:•No need to decompile, change things in smali, compile, sign, ...
•It will work for odexed and deodexed ROMs.
•Your mod is not bound to a specific version of the ROM. Unless there is a major change in the methods called for a certain functionality, your mod will continue to work even when you upgrade your ROM. Hell, it will probably even work with different ROMs.
•Multiple mods can be installed at the same time, even if they change the same package. So you can use these battery icons and those quick toggles. Even hooking the same method twice is possible. Of course, this only works properly if the mods are not trying to do incompatible things.
•It does its magic at runtime. That means you can implement options to let the user decide if they prefer the bikeshed to be painted in red or blue. Or you can have some extra logic for certain ROMs without building different mod versions.
•It can be disabled easily without having to reflash.
•It's open source.
How to install:
First step for everything you do: Create a nandroid backup and make sure you know how to restore it!
I'm not responsible for anything you do with your phone/tablet/rice cooker.
There is also the risk to soft-brick your device. In such a case, restoring a backup is the easiest way to get rid of it (other possibilities mentioned below).
For the framework:
1.Download XposedInstaller.apk and install it
2.Launch the Xposed Installer and click on "Install/Update"
3.Reboot
4.Done!
For any modifications/modules you want to install:
1.Download <module>.apk and install it
2.Launch the Xposed Installer and go to the "Modules" tab (you will also get there if you click on the notification warning you that the module is not enabled yet)
3.Enable the module by checking the checkbox
4.Reboot
5.Done!
In case you get into a boot loop:
You can flash the attached Xposed-Disabler-CWM.zip by Tungstwenty. It will be copied to your (external) SD card when you install Xposed as well. The only thing it does is copying /system/bin/app_process.orig back to /system/bin/app_process, which you can also do yourself (e.g. with adb shell in recovery mode).
You could also create a file /data/xposed/disabled, which causes Xposed to be bypassed as well.
Modules&Download
There might also be other threads for modules. SITE IS CURRENTLY BROKEN - PLEASE CHECK AGAIN IN A FEW DAYS!
Temporary alternative with some of the modules: Index of /public/Android/Xposed
Please don't use this thread for problems with modules! Use the thread of the module instead.
Changelog: 1.0: Initial version
1.1: ???
1.2: Installer
1.5: Resource replacing
1.6: Some fixes and improvements [629 downloads]
2.0 rc2: Lots of thing redone. Supports (temporarily) replacing native libraries, lots of additions and changes for developers. [3234 downloads]
2.0: Removed the native library replacement again, support for 4.1 and 4.2, Instagram crash fixed, ... [631 downloads]
2.0.1: Fixed a crash when a module tries to hook a function with "long" or "double" parameters [930 downloads]
2.0.2: Fixed a problem which resulted in a boot loop [4310 downloads]
2.1: Various improvements, e.g. earlier callbacks for module loading. For details, see this post. [345 downloads]
2.1.1: Fixed a bug in drawable replacements [5421 downloads]
2.1.2: Small fixes, added Chinese and Russian translations [11415 downloads]
2.1.3: Reverted a change in 2.1.2 that caused bootloops; new translations and some more fixes [46803 downloads]
2.1.4: Support for Galaxy S4 and HTC One plus a few minor fixes/enhancements (details)
Webseite
http://repo.xposed.info/module/de.robv.android.xposed.installer
Source code:
https://github.com/rovo89/Xposed (the C++ part)
https://github.com/rovo89/XposedBridge (the Java part)
https://github.com/rovo89/XposedInstaller (Installer app)
Advantages:
•It's open source.
How to install:
For the framework:
3.Reboot
4.Done!
4.Reboot
5.Done!
Modules&Download
1.1: ???
1.2: Installer
Webseite
Source code:
