Fragen & Diskussion betreffend der Aktivierung des [Root-Accounts]
Apple-Manieren!?
Der Root ist doch nur ein April-Scherz, dachte ich?
Ja. Root Meldung war anscheinend ne Ente...
Bitte lesen:
Galaxy S4 probably not rooted
So, various Android, mobile, and tech news sites picked up that the S4 (I9500) was rooted today. It seems nobody has bothered checking anything out in depth in this case, and the news is premature at best.
All instances I can find point back to modified ROMs posted on XDA have the apk and su binary for Superuser or SuperSU pre-installed, but that nobody has tested.
With a lot of (Samsung) devices in the past that really has been all there is to rooting - just get the files in place somehow and voila - and flashing a modified stock firmware to do this is certainly a valid method for this.
However, I would like to point out that we've tried this trick with the I9505 weeks ago (and we actually tested it on a real device), and this time around, it is not a simple case of injecting the files. There is some further protection in the firmware that prevents the su binary (which is needed for root access) from functioning properly - without any known workaround at this time. No doubt somebody will quickly figure it out when they have the device in-hand though.
Now, I played with an I9505, which is not the same as an I9500, and the firmwares are weeks old by now, and a lot more disclaimery stuff - but so far nobody has actually posted anything resembling proof, or even a comment that they tried the root and it has worked.
As such, I would take any news that the S4 has been rooted with at least a spoonful of salt until somebody posts some convincing evidence ...
(please, don't actually eat a spoonful of salt, that's dangerous)
I'd love to be proved wrong, and no doubt the S4 will be rooted soon, but I remain extremely skeptical as to the current claims, without any further proof. Maybe we all got lucky and Samsung decided to drop this protection in the I9500 or all new S4 firmwares, but I somehow doubt it.
Von Chainfire
https://plus.google.com/+Chainfire/posts/PyT35tJHaqi
Reaktionen: Shaddix und MasterElwood
Leute das Gerät ist nicht mal erschienen, sicher wird es Root geben und das auch spätestens in der ersten Woche denke ich.
Lasst den ganzen Entwicklern erst mal das Teil in der Hand halten und es wird ein Wunder geschehen.
Reaktionen: susdiehl
+1
Saludos vom meinem Note am Meer
Genauso kann es ein Monat dauern. Oder 3.
Keiner weis es...
Die Einfachheit war immer ein Riesen Vorteil bei Samsung. Odin - fertig.
Wenn ich da an HTC denke mit ihren registrieren und Bootloader unlocking über die Homepage, dann noch das Kopfweh mit s- on und s- off, kein triangleaway und und und...
Und jetzt hängen wir in der Luft...
Ich habe nie behauptet, dass es nicht länger dauern kann.
Vielleicht haben wir auch Pech aber bis jetzt wurde doch so alles gerootet was nicht Niet- und Nagelfest ist oder? :D
Wenn ich an den Counter vom S2 denke und wie schnell man den auf 0 zurückstellen konnte, wenn erstmal die entsprechende Hürde beim S4 gefunden wurde wirds schon werden.
Viele Entwicklier hatten das ja noch nicht mal in der Hand.
Naja alles nur Spekulationen aber die Vergangenheit lässt hoffen, vielleicht hast du mit deinen Monaten ja Recht.
Ich drücke jedenfalls die Daumen, Root ist schon wichtig :)
Ja, zugegeben. Eine leichte Verunsicherung befällt einen, wenn man an die Struktur des S4 denkt und dann an das "KNOX".
Da das Knox in erster Linie auf Business-Anwender abzielt, habe ich als Privatperson keinen Bedarf an dieser übersteigerten (paranoiden) Sicherheitsbarriere.
Ich hoffe ganz stark, das man das Knox freiwillig, also als Option einstellen kann, aber nicht muß. Wenn das nicht der Fall ist, bleibt zu hoffen, das man das dann mit erfolgreichem Root-Zugang wegbekommen oder zumindestens deaktivieren kann.
Aber bislang ist (fast) alles schon gerootet worden, also warum nicht auch das S4. :biggrin:
Und aus diesem Grund mache ich hier zu.
Gesendet von meinem Samsung Galaxy S3 mit Tapatalk 2
Reaktionen: walda
Root fürs Galaxy S4, zumindest die 9505 mit S600 Snapdragon, ist nun vorhanden. Chainfire hats mal wieder geschafft. Er arbeitet auch schon an ner Version fürs I9500.
Allerdings sie nochmal drauf hingewiesen, dass die derzeitige Methode nur für das I9505 funktioniert!!
Edit: Root für die MDM Firmware ist.:wubwub: Installationshinweis beachten!*
Galaxy S4 GT-I9505 (Qualcomm LTE) rooted
To continue on with all this talk about the S4 and root, I've just rooted the XXUAMD2 firmware (dated April 2) for the I9505.
If you've followed the story so far, you know there has been trouble rooting the S4's until now. SEAndroid was set restrictive on some firmwares (easily circumvented) and aside from that we had the mystery reboots. You could have the su binary and apk's installed just fine, but once you used the su binary to gain root access, the device would reboot.
We've done nothing special for this firmware - SEAndroid was set to permissive on this firmware, and it doesn't suffer from that reboot issue. This is as plain a root as all the CF-Auto-Root's for any other Galaxy device, or other methods to inject root by flashing a custom kernel/recovery/system.
We simply don't know if this is the final retail firmware, so we don't know if this will work on final retail.
I do believe this is the first S4 root that was actually tested working, hurrah !
This root has been tested on the XXUAMD2 firmware and is found working. It will not work on older firmwares that that, and we'll just have to wait and see if it will work on newer ones ...
GT-I9505 only, this is the Qualcomm-based Galaxy S4 LTE !
Everyone playing with this right now knows the drill, for the rest of you this post will be updated with more information soon. So here's only the short instructions: flash the included .tar.md5 as PDA using Odin, and make sure repartition is not checked. You should see a red Android coming up, and your device will be rooted. If the device boots normally without the red Android, reboot into recovery manually to trigger the process.
Download
Wie installier CF-Root?
Datei runterladen, entpacken, S4 in den DL Mode bringen und per Odin die .tar.md5 Datei über PDA flashen. Wie es genau geht, kann man ausführlich auch hier mitverfolgen.
Alternativ steht ein Video-TUT bereit, siehe unten.
*Download CF-Root für FW XXUAMDM
Für Anfänger
Quelle
Quelle 2
Reaktionen: wuppi1, Lazy79, dabistduja und 4 andere
Servus Leute mein S4 ist grad frisch angekommen und ich würde es gerne rooten, jedoch hab ich nicht so den Durchblick.
Deswegen meine frage, könnte mir jemand bitte den Root-kit (?!) den ich für das
S4 gt-i9505 und basebandversion uamde schicken ?
mfg da siggi
Der ursprüngliche Beitrag von 16:09 Uhr wurde um 16:14 Uhr ergänzt:
CF-Root Download
ist das der richtige ?
Ich würde mit den Rooten warten und in den XDA Thread wird extra hingewiesen das es nur für eine Firmware ist und da gestern oder heute ein OTA kam wird dieser nicht mehr funktionieren. Warte bis die ersten Toolkits auskommen....
Die Admins,Mods können so langsam mal die unterforen erstellen.
Ok, dann werde ich mal deinem weisen Rat folgen
Verrat uns doch mal das Ergebnis von *#1234#
OXA? Open Europe version... Interessant.
Nobby1960
Nobby1960
Westpole
Westpole
Westpole
Revan335
  • Revan335
Revan335
Revan335
