[BATTERY DRAIN] Hintergrund und Lösungen
lynx2k50
Hallo.
So langsam kommt in dem AndroidOS Bug bisschen Leben und XDA werkelt auch fleissig daran.
Hard-Facts seitens XDA.
[THINKTANK] Fix Android OS Bug - xda-developers
Versuche hier in dem Thread auch Lösungen zu sammeln. Leider gibt es noch nicht viele.
Hier schreibt ein User, Factory reset hätte bei ihm geholfen.
  1. possible fix for battery drain
ACHTUNG: Alle Daten werden gelöscht.
POSSIBLE BATTERY DRAIN FIX
In addition, for those who are having huge battery drains from Android OS, I also had it. On original KDD firmware, no problem at all, but after updating to KE2 with KIES, I had it all afternoon. I did a hard reset, and the battery drain seemed to go away, but I can neither guarantee or give a 100% confirmation (considering the fact that the Android OS battery usage is based on %, so if I constantly use the phone, Display goes up to 54% and Android OS drops to 10%)
Did a hard reboot by the following method:
WARNING: Will delete apps and all data; phone will boot like new phone.
1. Make sure phone is root first if you want root, and both SU and BUSYBOX installed
2. Shut down phone
3. Hold on the "UP" and "HOME" key, and press the "POWER" button for 2-3 seconds to turn on the phone (make sure to release the "POWER" key after the phone turns on, but continue holding "UP" and "HOME")
4. Select "wipe data/factory reset" and then "wipe cache partition" to remove both.
5. "Reboot system"
6. Once phone has rebooted, Root stays if properly installed, and phone starts off like new.
7. I have been using the phone since for 7 hours now, and seems better.
Source: [HOWTO] Disable ALL camera sound AND possible fix for battery drain - xda-developers
Update 1:
Zu Lösung 1 gibt es positives Feedback.2 User berichten, dass ihr "drain" weg ist.
Durch das Factoryreset verliert ihr alle Daten, also wenn vorher ein Backup machen. Presseonkel berichtet hier auch von der Datei batterystats im Bezug auf das Update:
https://www.android-hilfe.de/forum/...ufzeit-thread.100574-page-5.html#post-1429348
Es könnte also auch der Zusammenhang herschen, dass durch den Factory reset, die batterystats Datei gelöscht wird und ihr dadurch kein drain mehr habt.
Proof 1: http://forum.xda-developers.com/showpost.php?p=13815726&postcount=13
Proof 2: http://forum.xda-developers.com/showpost.php?p=13817882&postcount=14
Proof 3: http://forum.xda-developers.com/showpost.php?p=13821986&postcount=15
[22.05.] Update 2:
Ich selber habe auch das Hard Reset ausprobiert. Mit Titanium Backup ist das halb so wild.
Unter KE2 habe ich das gemacht und es hat bei mir GAR KEINE Wirkung gezeigt.
Nun habe ich via Kies (Akku voll) auf KE7 geupdatet. Dann habe ich gerootet und dann einen Factory reset gemacht. Seit heute morgen tingelt AndroidOS nur noch bei ca. 1min und seit heute vormittag ist der Akku bei 89%.
Sieht also im Moment gut aus.
Natürlich kein garant das es irgendwo funktioniert.
Desweiteren ist eine neue Lösung bzgl. der höheren 3G Verbrauchs aufgekommen:
http://forum.xda-developers.com/showthread.php?t=1086599
Diese habe ich aber selbst nicht ausprobiert.
[23.05.] Update 3:
Alle Pferde wieder zurück. Ich hab weiter den hohen Akku Verbrauch jedoch nur wenn ich über 3G im Internet bin. Habe gestern viel gezockt und war im WLAN, alles wunderbar. Nach ca. 6h ohne Akku lag AndroidOS nur bei 2min. Dann habe ich irgendwann auf 3G gewechselt und AndroidOS ist hoch geschnellt. Ich denke, und werde es im Selbstversuch testen, dass der Drain nur an 3G liegt und das dann mit dem oberen Post (Update 2) korrespondiert.
Gerne können sich mehere den Versuch anschließen mal nur WLAN zu benutzen (kein Sleep, permanent an) und über ihre Erfahrungen posten.
[25.05.] Update 4:
Wohl erst mit 2.3.4 gefixt http://twitter.com/#!/eldarmurtazin/status/72930533776175104
[29.05.] Update 5:
Hab viel rumprobiert aber mit WLAN erfahre ich nun auch nicht erhoften Boost.
Es hat sich nun auch seitens google bestätigt, dass erst das Update auf 2.3.4 die Akku Probleme lösen wird.
http://mobile.downloadatoz.com/news...he-dual-core-smartphones-heating-problem.html
http://code.google.com/p/android/issues/detail?id=11126#makechanges
Seit März 2011 sind die notwendigen Änderungen im Kernel (AOSP) von 2.3.3 eingearbeitet aber Samsung nutzt wohl nicht die aktuellsten Änderungen (ist ja klar wegen den ganzen eigenständigen Optimierungen/Veränderungen).
Mit 2.3.4 werden wir wohl erst unsere wahre Akku Laufzeit kennen lernen. Wann es kommt weiß keiner.
[3.06.] Update 6:
Da mir der Akkuverbrauch echt auf den Kecks ging habe ich nun einiges mehr gewagt (bin am Anfang eher ein Stock Rom user). Habe mir statt TW mal GoLauncher EX draufgehauen und bin echt begeistert. Hat mir nun komplett TW ersetzt. Dann habe ich mit Titanium Backup alle unnötigen Sachen entfernt, welche ich nicht brauche. Das geht über den Samsung Software Updates über Samsung Account, alle Hubs und vieles mehr. Habe dann ein Reboot ausgefühgrt und tada, ganzen Tag 3G, paar Anrufe, bissel AngyBirds und ich stehe auf 76% am Ende des Tages. Habe das nun schon seit paar Tagen im Betrieb und erreiche nie weniger als 50% am Ende des Tages (~ 2,5h Display on). Inspiriert wurde ich durch:
http://forum.xda-developers.com/showthread.php?t=1105598
Dieser Thread könnte dann auch Leuten helfen:
http://forum.xda-developers.com/showthread.php?t=1108479
Desweiteren plant Pulser ein lite Rom, SuperVillain:
http://forum.xda-developers.com/showpost.php?p=14392378&postcount=1163
Letztendlich wird uns aber erst das Update auf Andoid 2.3.4 das wahre Potenzial vom SGS 2 entlocken. Dabei sollte aber bedacht werden, dass Samsung wohl ziemlich viel Kram installiert hat was von den meisten Usern gar nicht benötigt wird aber trotzdem im Hintergrund Akku zieht. Eine Entschlackungskur lohnt also je nach Anwender.
[6.06.] Update 7:
Wer "fast dormancy" (bitte vorherige Links durchlesen und googlen) ausschalten möchte, kann dieses einfachen Befehl benutzen:
- Telefonfunktion
- *#9900#
- Disable fast dormancy
Auch nach einem restart bleibt die Funktion deaktiviert.
Ich teste es zur Zeit.
Übersichtsliste alles APK (safe to remove): https://spreadsheets.google.com/spr...SENVeXlqUm5vV0E&single=true&gid=0&output=html
Credits: http://forum.xda-developers.com/showpost.php?p=14469791&postcount=153
[20.06.] Update 8:
So, lang ist es her. Habe grad schön den Post geschrieben und dann war es auf einmal weg… jetzt kriegt ihr nur einen abgespeckten Post :)
Also fast dormancy zu deaktivieren hat bei mir gar nichts gebracht.
Ich habe nun folgendes gemacht und bin sehr zufrieden:
1) VR 1.4 mit eigener light Version
2) Neuestes Radio/Phone/Modem
3) Tegrak Undervolting
Zu 1) Ich habe mich für VR entschieden, da es kein nerviges Theme hat und sonst auch sehr stock Rom like ist. Ich habe aber selbst folgende APKs gelöscht:
Code:
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SamsungWidget_WeatherClock.apk"]SamsungWidget_WeatherClock.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Dlna.apk"]Dlna.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/BuddiesNow.apk"]BuddiesNow.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/TwCalendarAppWidget.apk"]TwCalendarAppWidget.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/ChocoEUKor.apk"]ChocoEUKor.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/PressReader.apk"]PressReader.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/lcdtest.apk"]lcdtest.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsImageCache.apk"]SnsImageCache.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Days.apk"]Days.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Email.apk"]Email.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/EmailWidget.apk"]EmailWidget.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/FactoryTest.apk"]FactoryTest.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/GameHub.apk"]GameHub.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/HelvNeueLT.apk"]HelvNeueLT.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Protips.apk"]Protips.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SamsungIM.apk"]SamsungIM.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/IMEITracker.apk"]IMEITracker.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/KiesAir.apk"]KiesAir.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/kieswifi.apk"]kieswifi.apk[/URL][/FONT][/COLOR][/U]
[COLOR=black][FONT=Calibri]Kies.apk[/FONT][/COLOR]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Kobo.apk"]Kobo.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/PanningTryActually.apk"]PanningTryActually.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Microbesgl.apk"]Microbesgl.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MiniDiary.apk"]MiniDiary.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MobilePrint.apk"]MobilePrint.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MobileTrackerEngineTwo.apk"]MobileTrackerEngineTwo.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MusicPlayer.apk"]MusicPlayer.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MusicHub_U1.apk"]MusicHub_U1.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SecretWallpaper1.apk"]SecretWallpaper1.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SecretWallpaper1.apk"]SecretWallpaper2.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/PhotoRetouching.apk"]PhotoRetouching.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SamsungWidget_ProgramMonitor.apk"]SamsungWidget_ProgramMonitor.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/ReadersHub.apk"]ReadersHub.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/signin.apk"]signin.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/MMM_Smartphone_1.5.1_final.apk"]MMM_Smartphone_1.5.1_final.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Stk.apk"]Stk.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsProvider.apk"]SnsProvider.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsDisclaimer.apk"]SnsDisclaimer.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsAccountFb.apk"]SnsAccountFb.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsAccountMs.apk"]SnsAccountMs.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SnsAccountTw.apk"]SnsAccountTw.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SocialHub.apk"]SocialHub.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SevenEngine.apk"]SevenEngine.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/syncmldm.apk"]syncmldm.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Term.apk"]Term.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/TrimApp.apk"]TrimApp.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/VideoEditor.apk"]VideoEditor.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/VpnServices.apk"]VpnServices.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/FTS.apk"]FTS.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/FTM.apk"]FTM.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SecretWallpaper2.apk"]SecretWallpaper2.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/wipereceiver.apk"]wipereceiver.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/WlanTest.apk"]WlanTest.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/wssyncmlnps.apk"]wssyncmlnps.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/SamsungWidget_StockClock.apk"]SamsungWidget_StockClock.apk[/URL][/FONT][/COLOR][/U]
[U][COLOR=blue][FONT=Calibri][URL="http://www.contentsd.nl/apk/Zinio.apk"]Zinio.apk[/URL][/FONT][/COLOR][/U]
[COLOR=black][FONT=Calibri]Swype.apk[/FONT][/COLOR]
[COLOR=black][FONT=Calibri]TouchWiz30Launcher.apk[/FONT][/COLOR]
Dabei ist zu beachten, dass auch der TWLauncher weg ist. Den habe ich mit GoLauncher ersetzt. Auch KIES fehlt aber schaut selbst.
Falls jemand dieses Rom haben möchte, kann ich es hochladen. Bitte hier im Forum anfragen, falls Interesse.
Ich bin sehr zu Frieden mit dem Rom, gerade auch wegen VR Tweaks, das viele Tweaks einfach anwendet ohne Konsolenkentnisse oder so.
Hier mein Akkustand:
http://imageshack.us/g/846/sc20110620095330.jpg/
Dabei ist zu beachten, im Flugmodus über Nacht 0% Verlust. Vorher lag ich da bei 0,8% pro Stunde.
Zu 2) Mit dem KF2 Update kam auch ein neues Radio mit. Diese Art Treiberpaket, beinhaltet alle notwendigen Treiber usw. für das Kommunikation, d.h. z.B. WLAN Treiber usw. Durch dieses Update habe ich einen besseren Empfang aber was viel wichtiger ist, der Battery Drain ist nicht mehr so hoch. Eingespielt wird das über ODIN, mehr Infos hier:
http://www.villainrom.co.uk/forum/s...-S-II-XXKF2-Base?p=42028&viewfull=1#post42028
Dabei die Dateien einfach im Download Modus vom SGS 2 also „PHONE“ flashen.
Zu 3) Ich habe mir noch Tegrak angeschaut. Dabei war es mir wichtig, nicht das System zu übertakten sondern eher auf Batterieersparnis zu trimmen. Schnell ist es genug für mich. Tegrak muss man leider als Ultimate Version kaufen, damit man die Volteinstellungen sichern kann. Ich habe zurzeit diese Einstellungen:
Code:
      CPU Level 0 - 1232 Mhz
      Core Voltage : 1200mV
      Internal Voltage : 1075mV
      CPU Level 1 - 1000 Mhz
      Core Voltage : 1100mV
      Internal Voltage : 1050mV
      CPU Level 2 - 800 Mhz
      Core Voltage : 950mV
      Internal Voltage : 1025mV
      CPU Level 3 - 500 Mhz
      Core Voltage : 875mV
      Internal Voltage : 975mV
      CPU Level 4 - 200 Mhz
      Core Voltage : 800mV
      Internal Voltage : 950mV
Alles funktioniert einwandfrei mit diesen Einstellungen. Ich wollte einfach nicht über die voreingestellte Voltzahl gehen, daher habe ich leicht um +32mhZ übertaktet :D Hat man aber wenig von.
Noch als kleine Infos, KF3 wird diese Woche auch kommen:
http://forum.xda-developers.com/showpost.php?p=14877685&postcount=2
VR wird dann bestimmt aktualisiert aber dann braucht man kein wipe, d.h. alle Daten bleiben erhalten.
Falls Fragen sind, posten.
Reaktionen: doesdroid, Laberistikus, Kjetal und 11 andere
Moin,
schick mir ne PN wegen Titel-Änderung..:)
Update
Das Thema verfolge ich auch mit großem Interesse, hoffentlich gibt es bald eine wirklich funktionierende Lösung.
"Das Thema verfolge ich auch mit großem Interesse, hoffentlich gibt es bald eine wirklich funktionierende Lösung."
Na, der hard reset sollte doch helfen oder?
hatte deswegen vor zu rooten, mit titanum zu sichern und dann den hard resert vorzunehmen morgen früh?
Ich verstehe nur nicht, warum man rooten muss für den Factory Wipe - wird die /data-Partition, wo die batterystats.bin liegt, nicht beim Wipe gelöscht wenn man kein root hat?
Hm komische Sache, das muss wohl irgendeine Einstellung sein. Habe auch alles was von Anfang an drauf war, und ich habe den Bug z.B. nicht. Über Nacht hat es 5% Ladung verloren.
Hoffe das ihr bald Abhilfe bekommt.
so, über nacht über 30% an ladung verloren, in ca genau 8 stunden.. im flugmodus :(
Im Flugmodus hat mein Ace auch immer mehr verloren als ohne.
Einfach Wlan, 3G und GPS über Nacht aus und das SGS2 verliert nur 2-3 %
Ich habe das Teil heute morgen um 4 abgesteckt nachdem mich das Akku voll Signal aufgeweckt hat.....ich habe jetzt nach 6 Stunden noch 92% Akku, 3G immer an, einige Mails beantwortet, 10 min auf Xda verbracht..... naja seht selbst, ich denke das die Anzeige falsch ist.......
Gesendet von meinem GT-I9100 mit der Android-Hilfe.de-App
welche ist falsch, batterie oder die der tasks?
was is der da in der mitte am homescreen für ne anzeige?
Die der tasks......Battery Widget, findest im Market :)
Update (Proof 3).
Es scheint wohl soweit zu funktionieren. Hat das jemand hier im Forum mal ausprobiert und kann seine Erfahrungen schildern?
Ich überlege mich die nächste Woche daran zu setzen.
also hab mein SGS2 mit Kies auf KE2 upgedatet.
- Root nach Anleitung gemacht ([ROM + Guide]Official i9100XWKDD/KE1/KE2 download for Odin Flash and Root Guide. - xda-developers) und dann den KE1 Kernel wieder geflashed )KE2 wollte nicht mit dem Titanium, evtl diese ADB Problem mit KE2)
- Sicherung mir Titanium Backup gemacht
- Die Methode hier aus diesem Thread angewandt
- Mittels Titanium Sicherung eingespielt
Hatte ich vorher zw. 20% und 60% Androis OS habe ich nun immer unter 20%, das sollte dem Akku helfen ...
Da ich viel installed etc habe, kann ich noch keine genauen Auskünfte geben, was wo wie sich sich beim Akku gebesser hat
Habe nach dem Root den Stock KE2 Kernel geflasht und mit Titanium Backup - zumindest beim Erstellen eines Backups - keine Probleme. Restore habe ich noch keinen probiert.
Habe wie in der Anleitung wipe etc. gemacht, mit Titanium alle Apps zurückgesichert - und siehe da Android OS bei 9%.
Mal sehen ob das so bleibt.
hab meines jetz 24std an, akku bei 2% ...
davon 4.15 std display an, 1,5 std cpu nutzung ...
denke das ist ok oder?
über nacht hatte ich das ding 7 std in flight mode, hat 2% akku ausgemacht ...
erwähnenswert noch, dass ich bei 10% nen bild machen wollte und das dann wg des akkus nicht geht ...
android os war bis eben nie bei 20% meist so 15%, aktuell 20% und android sys ist bei 16% ...
werde wie in dem darky thread empfohlen dass ding ganz leer machen und dann voll aufladen lassen ..
gruss
ps: hoffen wir, dass 2.3.4 schnell kommt, dann hat das wohl alles ein ende ...
ok ne deutsche anleitung zum rooten habe ich hier im Forum gefunden.
Muss ich überhaupt rooten oder geht das auch ohne?
was geht ohne?
also du kannst die methode mit dem affengriff hier auch ohne root machen, den root hab ich mir nur gemacht, weil ich meine sicherungen mit titanium machen wollte, was wiederum root braucht ...
hast du noch nicht veil am handy gemacht und kannst alles wieder schnell herstellen, dann gehts auch logo ohne ...
Wieso braucht man Root für die im Startpost erwähne Lösung? Ich meine auch dass es ohne gehen sollte, ist ja nur ein Factory Reset.
BlackMatrix
Rocc44
DesasterSven
DesasterSven
DesasterSven
