Das Thema "RC92 Root Problem, I wish I got someone can help me in this Problem.." befindet sich unter Root / Hacking / Modding für T-Mobile G1 auf Android-Hilfe.de.
| | Themen-Optionen | Ansicht |
| | #1 (permalink) |
| Neuer Benutzer Registriert seit: 21.11.2010
Abgegebene Danke: 1
Erhielt 0 Danke für 0 Beiträge
| It's been three days searching to find a way how to root my G1 with RC92, and it's nothing. I saw that some people had the same problem, but no body of them wrote how he fix it. =( I tried the classical way and it didn't work (RC29 or RC7), not allow and sticked on the rainbow screen. I tried to make gold card but I couldn't. I couldn't get the CID,neither terminal emulator neither any other program. and the cat/sys/class/......neither I tried the new way by one touch rooting, with linda file manager, but when I want to backup recovery image, it says "could not run command", and it same when I want to flash it. Since some body got throw such problem, could please help to fix it up? or at least where i can find the answer? thanks in advance! =) Note: I bought this phone when I was doing internship at Germany, I post to Germans Forum, hoping that someone will help. Thank you. I do not really understand German. I even used google translate to register to this forum. Thank you. |
| | #2 (permalink) |
| Android Guru Modell: Milestone Root - Desire HD root Registriert seit: 21.08.2009
Abgegebene Danke: 344
Erhielt 406 Danke für 351 Beiträge
Use Google Translate to try this Way: Rooting RC92 without Goldcrad: 4.1.1 Rooten ohne Goldcard - Gurus G1 Site It´s a very simple way, but for me, it´s hard to translate.
__________________ [Gerät] Milestone -> [ROM] 2.3.3 OC/QWERTZ/LP+ ->[OR] GOT+Androidiani+SE+Standard [Gerät] Desire HD -> [ROM] unentschlossen -> [Recovery] EXT4 |
| | #3 (permalink) | |
Abgegebene Danke: 1
| Zitat:
I will try to follow the step. If I get stuck I will post it again soon. | |
| | #4 (permalink) | |
| Android Guru Modell: SG-Note + 1x LGO3D + 1x SGT + 3x G1 + (eGoT+Lavatube :-) Registriert seit: 09.05.2009
Abgegebene Danke: 179
Erhielt 834 Danke für 643 Beiträge
| Zitat:
__________________ Fragen gehören ins Forum und nicht in mein Postfach ! ![]() Einsteiger ? Probleme ? Unklarheiten ? >>> Android-FAQ.de bei G+ Ich und Android-FAQ.de | |
| | #5 (permalink) |
Abgegebene Danke: 1
It seems working, until The Rootprozess number 2. But I did not get what in number 3. I tried to follow, but it's stuck when it says "Wir folgen den Anweisungen und lassen das G1 rebooten. Nicht erschrecken, es scheint kein reboot ins Recovery zu erfolgen und so bleibt der G1-Screen stehen. Also mit Annehmen-Menü-Auflegen neu starten und wenn der Screen schwarz ist zügig die Hometaste gedrückt halten. Damit kommen wir zurück ins Recovery und können unter dem selben Menüpunkt das custom ROMflashen. Nach Abschluß neu starten und warten bis das ROM gestartet ist. Natürlich kann auch jedes andere custom ROM genutzt werden, aber ich wollte nur den Ablauf darstellen und nicht auf ROM Besonderheiten eingehen müssen." Could you make a video tutorial on it? I really appreciate if you have free time and show it by a video. Thank you so much, vielen dank |
| | #6 (permalink) |
Abgegebene Danke: 1
or maybe you can help me by chatting. please add me at Yahoo: riowahaab Thank you so much. |
| | #7 (permalink) | |
| Zitat:
good night
| | #9 (permalink) |
| Android Experte Modell: HTC Desire Z Registriert seit: 05.02.2009
Abgegebene Danke: 2
Erhielt 23 Danke für 18 Beiträge
I think winne means "no time" in general. so you completed step 1 successfully? Then you have a rooted phone now. What about step 2? Did you install Rommanger followed by Clockwork Recovery (via Rommanager) and reached Recovery after reboot?
__________________ MM white G1 | BiffMod 2.1 (im Test) | Amon Ra 1.7.0 | Danger SPL HTC Desire Z | Cyanogen (mostly) experimental |
| | #10 (permalink) |
Abgegebene Danke: 1
| I did not get Recovery after reboot, is it auto reboot or I should do manual reboot?
| Themen-Optionen | |
| Ansicht | |
| Thema | Autor | Forum | Antworten | Letzter Beitrag |
| root + busybox ? (kleines problem) | Semiotik | Root / Hacking / Modding für HTC Wildfire | 5 | 22.10.2010 12:29 |
| jph root problem | doublex | Root / Hacking / Modding für Samsung Galaxy S | 0 | 16.09.2010 02:54 |
| [Erledigt] Root problem | DrMole | Root / Hacking / Modding für Samsung Galaxy S | 10 | 30.08.2010 19:22 |
| Re-Root Bootlogo Problem | kringel | Root / Hacking / Modding für Samsung Spica | 3 | 27.05.2010 20:35 |
| ROOT problem | 4ego | Root / Hacking / Modding für HTC Magic | 3 | 09.09.2009 16:35 |
