[updated]AOKP Burstlam's Build (GEN 2/ 4.0.3/ Ice Cream Sandwich) [RC05.6]
XMasterNinni
XMasterNinni
Da ich gesehen habe, dass in den CyanogenMod 9 Threads von Tom_G des öfteren auch von Burstlams Builds die Rede war, habe ich hier nun einen eigenen Thread für die Burstlam Versionen eröffnet. :drool:
Thx to all the guys from MoDaCo and XDA :love:
News:
  • Burstlam's RC05.6 ist da!
  • Eine neue Open-GL Testversion (Test 2) ist erschienen!
  • Burstlam's RC05.5.1 ist da!
  • Burstlam's RC05.4 ist da!
  • Habe einen Animation Fix hinzugefügt, der die Animationen flüssiger macht! (in CWM flashen)
  • Google Music 4.1 hinzugefügt
  • DARKTREMOR A2SD App hinzugefügt
  • Softbuttons.zip hinzugefügt
The first said that a mention overwhelming appear MIUI beautification millet announced a so-called open-source package.
I would admire it can open source nature of such change, the final analysis, in fact, from the open-source compiler ICS 4.0 package, decompile and modify.
Because my bag is still relatively close to the source, so it can be used.
Basically OPENGL rendering fluency, but still the occasional card. The operation of State Bank deposit is too low, the situation serious.
Proposal corresponds to the method:
Check menu> on the Advanced Settings> Interface> long press the return key to end the process
(2) Menu> Developer Options> background to limit the number set to 2 or less.
Virtual key
Default virtual key the foreign AKOP team has navigation bar switch, but this phone does not support native
I did a slightly modified so that the small V can use, but use the switch is a bit tricky.
Advanced Settings> navigation bar> Options enabled navigation bar. This time the pop-up window to be asked to reboot. Choose not to (left)
2 Select the power button> Enable the virtual key switch (can not use the Flight mode off), and then restart the phone.
After the restart, you will be able to re-navigation bar to change other configuration. The next stop anti-hook enabled bar, direct use of the power button to open the key to control the virtual key switch can be.
About the weather service
The weather service open to open Columbia Valley services network location. Otherwise FC forced to close.
But like the end of foreign team to create, enter a custom location, then only in English.
Aktuelle Version:
Burstlam's RC05.6
https://rapidshare.com/#!download|432l35|2126849306|CM9-PRE-RC5.6.1-BLADE-signed.zip|81570|R~C9D7FF56949DD494BA106B7A00FA5F63|0|0
Open GL Testversion 2
zte_blade-ota-eng.burst-opengl2-signed.zip
Ältere Version(en):
Burstlam's RC05.5.1
CM9-PRE-RC5.5.1-BLADE-signed.zip
Burstlam's RC05.5
CM9-PRE-RC5.5-BLADE-signed.zip
Burstlam's RC05
CM9-PRE-RC05-BLADE-signed.zip
Gapps:
gapps-ics-20111128.zip - ics4blade - GApps ICS 2011-11-28 - port of the android open source project (aosp), ice cream sandwich (android 4.0) version on the zte blade - Google Project Hosting
Stripped Down Gapps:
market_google_accounts_fix.zip - ics4blade - Market / Google account only (alternative stripped gapps for 160MB /system) - port of the android open source project (aosp), ice cream sandwich (android 4.0) version on the zte blade - Google Project Host
Superuser:
Goo-inside.me Downloads - Downloading Superuser-3.0.7-efghi-signed.zip
Extras
Google Music 4.1 ICS:
Multiupload.com - upload your files to multiple file hosting sites!
Wifi Tether
wifi_tether_v3_1-beta11.apk
Animation Fix:
http://db.tt/jkp6LBgV
DARKTREMOR A2SD App (ICS)
dtapps2sd-ics-patch.zip
Softbuttons
ICS-soft-button-patch-RC5.zip
Mirror: ICS-soft-button-patch-RC5.zip
Wer den CM9 Trebuchet Launcher besser findet...
Trebuchet Launcher
Google Übersetzer
Momentan läuft Burstlam's RC05 auf unseren Blades (nach einem Reboot!) sehr flüssig.
Falls ihr Grafikprobleme habt:
geht in die Einstellungen -> Developer Settings -> und die "Window Animation Scale" und die "Transition Animation Scale" auf Animation Off setzen -> Reboot!
Ach Ja:
(Mehr oder weniger)gute Englisch Kenntnisse sind Voraussetzung, da in Burstlam's Build außer Chinesisch nur Englisch zur Auswahl steht! :cursing:
Was funktioniert: (kopiert von XDA & verändert)
- Wired headset is now recognised
- Bluetooth and Wi-fi (WI-FI can stay on while phone is sleeping)
- Music player
- GPU acceleration (fast with animations on too)
- SD card
- Google Sync
- Gmail (partly)
- Sound
- Gallerie
- Maps (May not work)
- Multi touch
- Market
- Auto rotation (with nice animation)
- Superuser
- Overclockable
- Telephone fully works
- GAPPS
- Usb storage mode
- DSP manager
- Most of the games are working (Tried Angry birds and N.O.V.A and Gangstar)
- Standard Browser (auch ohne Patch!)
- CM Einstellungen!
- eingebauter Datei Manager! (auch Root Explorer)
- Videos (mit MX Video Player App)
- Kamera (Man kann Fotos machen, sieht aber nicht was man gerade macht! :biggrin:)
Was nicht funktioniert:
- Youtube (App)
- Microphone (also Shazam, Soundhound etc... funktionieren nicht!)
- Wi-fi Tethering/mobiler Hotspot (funktioniert nur mit WIFI Tether App, siehe "Extras")
Reaktionen: B!G-P!nK-3lephanT, h4ck3d und doom666
Google Earth kann doch nicht funktionieren, das benötigt doch ARM v7. Unser Blade hat doch nur v6?
Danke für den neuen Thread. So gibts weniger "Verwechslungen / Mix" im CM9 Thread.
IM Prinzip werde ich wohl später eher das burstlam 4.0.x nehmen als das CM9.
PS: Geht der USB Storage Mode wirklich? Ich dachte das geht noch nicht wie in CM9.
EDIT: Oh verwechselt (USB Storage). Das USB Problem (und weitere) betrifft wohl nur das ICS Blade (auch als ASOP DEV benannt) (http://code.google.com/p/ics4blade/, zur Zeit Alpha22 ) ROM, welches sehr nativ entwickelt wird.
Burstlam CM9 ist wohl so ein MIX aus ICS Blade und dem CM 9 ROM.
Bei CM9 und der burstlam Variante gehen USB Storage.
Reaktionen: XMasterNinni
Weiß nicht, könntest du es vielleicht ausprobieren und mir dann Rückmeldung geben? Danke schon mal im Voraus!
hi leute,
hab grad mal bissel getestet, bei mir geht kein WLAN, schneller isses, stimmt, hab aber einige grafikfehler.
aber werds im auge behalten :D
MfG,
Marcel
wegen den Grafikfehlern:
geh in die Einstellungen -> Developer Settings -> und die "Window Animation Scale" und die "Transition Animation Scale" auf Animation Off setzen -> Reboot!
wegen WIFI:
Einmal aus und ein schalten...!
Hab den Build seit heute morgen auch im Einsatz, sehr fein das ganze!
Einzig mein Lockscreen geht nicht... weiss nicht was das ist!
Alles was laufen soll läuft flüssig und fein! Akku hält bisher schon besser als bei CM7!
Sehr sehr cooles Rom!
Sooo erstes Problem, ich kann nicht angerufen werden. Meine Nummer ist besetzt obwohl ich nix mache!
vllt kann mir jemand helfen oder weiss was es is!
gruß
Kannst du selbst raustelefonieren?
Hört sich so an als hättest du eine PIN-gesperrte SIM-Karte, der Lockscreen geht nicht und da das gleichzeitig die App ist die den PIN annimmt...dürftest du weder telefonieren, SMS versenden oder mobiles Internet nutzen können.
raustelen geht, sms senden geht, daten nutzen geht, lockscreen wird einfach nicht angeschaltet d.h. Handy ist direkt aufm Launch er egal wie lang ich es schlafen lasse!
So: Selbst nach reset ging nix, bei cm7 hats klasse gefunzt... naja ich weiss ja auch net!
Mache jetzt ma nen Nandroid und warte nochn bisschen mit dem ICS, schade aber wenn Betas raus sind bei denen auch ma die Cam geht bin ich wieder dabei!
ich glaube den screen lock musst du nur in den Einstellung bei Security wieder anmachen!
Genau das war ja das Problem, der Lockscreen war auf Slide gestellt...
Oje..XD
bei mi funktionierts...
Hier läufts leider nicht ganz rund.
Beim installieren ausm Market kommt:
Code:
Error downloading "k-9 Mail". There is insufficient space on the Device
Jemand ne Idee?
Zu kleine Cache oder System Partition ?
Dachte ich auch dran, aber sollte das nicht vom Image geregelt werden?! (hab da nich so die Ahnung von ;)) oder muss/kann ich das von Hand beeinflussen?!
Kommt auf den TPT drauf an, welchen hast du benutzt?
TPT == welches Gen!?
Vorher war halt Android 2.3.7 (GSF) drauf, also Gen2
Ahh .. okay ;)
Aehm .. ja .. die "Stardard-Tabelle" wenn man von Stock-Rom aufs Gen2 GSF flashed ;)
Kann ich die im Nachhinnein ändern bzw anschauen!?
DD0HS
Skilowi
  • Skilowi
Skilowi
Skilowi
Susonna
