[ROM][N9005][XXUFNF4][4.4.2] *05.12.2014* Echoe Rom v.20
MuffinCore
MuffinCore
45
Galaxy NOTE 3 (SM-9005) | EchoeROM EchoeROM
FEATURES:
*Based on the brand new Official Android 4.4.2 Samsung FirmwareN9005XXUFNF4
*With Option of Stock Kernel and AEL Kernels Mainline and Advanced Editions
(Available as Aroma Options)
*Prerooted with SuperSU
*Zipaligned
*Deodexed
*With latest Busy Box Installed
*Build.prop tweaks for Speed and Battery efficiency (seriously, TOO MANY to list...)
*Ex-FAT Support
*Aroma Installer! Preconfigured to allow for FULL, SLIM or CUSTOMIZED installation. Followed by choice of various mods
*Full wipe/No wipe available as options in aroma!!!
*Custom Echoe Rom Settings allow for FULL CUSTOMIZATION of your phone (CREDITS: Ficeto) (Check Screenshots)
*With Viper4Android
*The AMAZING Echoe OG Battery MOD with over 85 Battery Unique Battery Icons to choose from
*Various mods for SystemUI (Stock, OG Battery, Quick Launcher in notifications, Lock screen button in status bar, S5 modded toggles) all included in aroma as optional installation with variable attributes
*4 Way Reboot ("Echoe Power Menu)
*Modded TW Launcher for INSANE SPEED!!!
*3 mods of TW Launcher available in aroma installer: Stock, 4x5 home screen grid, and 4x5 grid with scrollable wallpaper
*S5 modded settings with grid enabled! Including Echoe Rom Settings in both variants. Available as option in aroma installer (Stock or S5)
*Wanam's Flash and Mythrandir's ink color changer integrated into settings in all variants for easy access
*Modded S-View cover app for custom Echoe background image (Thanks to @vonerk and @hilmi94zul for this AMAZING guide!!! Thread http://forum.xda-developers.com/show...2649714&page=2). Available in aroma as either stock or modded
*Accuweather widget available in aroma installer Stock, Transparent or Transparent with Yellow interface
*xperiacle's Pen Window Manager
*xperiacle's MultiWindow Manager
*Enabled Quad View in Multiwindows
*Keyboard with secondary symbols for all languages enabled
*Unlocked all the Hidden Features from Stock MMS/SMS application (thanks to this INCREDIBLE GUIDE BY jovy23 THANK YOU!!!): http://forum.xda-developers.com/show....php?t=2472009
*No SMStoMMS conversion
*No Emoji to MMS Conversion
*SMS/MMS Custom smileys (No more UGLY Green ones)
*SMS/MMS Show sent time instead of time received
*Save and Restore SMS/MMS to SD Card
*Enabled group messaging
*Unlimited SMS recipients
*Enabled Split View Mode in SMS/MMS Settings
*Enabled Screen On/Off Toggle in SMS/MMS Settings
*Increased the SMS hour limit to 1000
*Enabled option for folder view of SMS/MMS Messages
*Enabled All System Languages by Default (thanks to the GREAT wanam!!!)
*Exit menu in SBrowser
*Hopepage Option in SBrowser
*No more annoying SMS logs in Call Logs
*Extended Speed Dial Entries to 100
*Enabled Call Button in Contacts
*Added Shutter Sound Menu in Camera Settings
*Enabled App Ops (accessible via Settings/Security and via the Echoe Additional Settings
*Added Network Speed Indicator
*wanam's XTorch
*Ink Effect Changer (added to settings)
*Unlocked 2 hidden toggles in the Notification Panel: [/COLOR]
“Smart Network” and “Network Restriction” (NOTE: Only after a CLEAN INSTALL they become visible)
*Enabled 2 Additional Options in System Settings:
Call Settings and Call/Message Block (They are under Settings/ Device)
*Added custom color in Calendar (Sat and Sun are a bit more colorful now)
*Extended Speed-Dial Entries to 100
*MODDED SAMSUNG CAMERA WITH ABILITY TO TAKE PICS WITH THE POWER BUTTON,
WITH LESS THAN 15% BATTERY AND MUSIC CAN REMAIN ON WHILE YOU USE THE CAMERA
*CENTERED CLOCK WITH A HIDDEN FEATURE
*Added Pop-Up Browser from Note 2
*Added Latest Xposed Framework (Credits: rovo89), Xposed Framework: http://forum.xda-developers.com/show....php?t=1574401
*Added Wanam Xposed Module: (Credits: Who else??) http://forum.xda-developers.com/show....php?t=2383484
*Added PerApp DPI Xposed Module (Credits: xperiacle): Per APP Density Setting for Every APP: http://forum.xda-developers.com/show....php?t=2072081
*Added AdAway (THANKS TO THE CREATOR: mrRobinson): http://forum.xda-developers.com/show....php?t=2472009
*Updated to latest SuperSU
*init.d scripts for speed and battery
*EXTREMELY FAST & SMOOTH ("SuperSonic")
*VERY BATTERY FRIENDLY
*The MOST BEAUTIFUL Custom Boot Animation and Custom ShutDown Animation by @chavxxx
*Custom Boot Sound
*Both boot animation and sound can be chosen in aroma (Stock, Echoe, and Echoe KK)
Download:
ECHOE ROM DOWNLOAD CENTER
Installations Anleitung:
1. Benutze Costum Revovery!!
Note: Wenn du eine Costum Recovery benutzt verlierst du deine Garantie. Und der knox warranty Counter geht auf 0x1
2. Sei sicher, das die Option "REACTIVATION LOCK" aus ist!!!
3. Mache ein FULL NANDROID BACKUP!!! Und sichere dein EFS
4. DOWNLOAD Echoe Rom, und speicher sie auf der internen oder externen SD Karte5. In Recovery, Wipe cache, wipe dalvik cache, und Wipe data/factory reset dann auf Install Zip ( von da wo du die Rom gespeichert hast )
6. Und instllieren, dauert so ca. 3-5 Minuten.
7. Reboot und Spaß haben!
Der ursprüngliche Beitrag von 17:22 Uhr wurde um 18:23 Uhr ergänzt:
Weder ich noch Android-Hilfe.de sind verantwortlich für Schäden oder Fehler. Also nur flashen, wenn du dir ganz sicher bist was du machst!!
Reaktionen: holzfish, agentdoggie, perog und 2 andere
jetzt aber bestimmt, danke für den Hinweis...^^ :thumbup:
Reaktionen: Kumo
Hab gerade auf ************ gelesen, dass gerade v9 upgeloaded wird. Dürfte also heute abend zum Abruf bereit stehen.
Reaktionen: Kumo
V9 ist jetzt online
Reaktionen: uklukl
V9 läuft bis jetzt ohne Probleme!
Hallo. Ich hatte vorher die V7 drauf und hatte teilweise echt viele Probleme am Anfang. Jetzt nutze ich V9 und bin überzeugt davon. Bisher keine abstürze von touch ...... was ich nervig War. Bisher läuft alles echt sahne. Mal gucken wie lange dies stand hält. Mfg
V10 ist online. Läuft 1a!
Reaktionen: Kumo
Kann ich bestätigen. Läuft einwandfrei
Alles super, läuft wunderbar. Nur eine Frage:
Wie bekomme ich den Schalter oben links weg
Benutzt du wanam oder das gravity modul? Ich denke dort deaktivieren. Oder hast du ein theme geflasht?
Nach dem flashen mit full wipe war es schon da, ohne das wanam oder gravity schon aktiviert waren
Dann hast du denke ich im Aroma installer den power Button aktiviert. Wie du den so weg bekommst weiß ich nicht. Außer neu drüber flashen, und den Button im Aroma deaktivieren.
Der ursprüngliche Beitrag von 12:52 Uhr wurde um 12:54 Uhr ergänzt:
Der ursprüngliche Beitrag von 12:54 Uhr wurde um 12:55 Uhr ergänzt:
Bei mir ist er nicht!
Reaktionen: Kumo
Danke dir, werd ich mal versuchen
______________________________
Nun hat es geklappt und der Schalter ist weg
Top!
Reaktionen: Kumo
Für was soll der Button denn gut sein bzw. was signalisiert dieser ?
Das ist der lock screen Button! Nicht ausprobiert. Meine gelesen zu haben, das der screen damit aus geht. Also so wie beim g2.
Der ursprüngliche Beitrag von 18:43 Uhr wurde um 19:44 Uhr ergänzt:
V11 ist auf dem Weg. Soll morgen früh online sein!
V11 ist online
A Supersonic Rom for the Galaxy NOTE 3 N9005
*** With the most beautiful Aroma Installer for an Amazing Installation Experience***
FEATURES:
*Based on the latest Official Android 4.4.2 Samsung Firmware N9005ZHUENB5
*With Stock Kernel
*Prerooted
*Zipaligned
*Deodexed
*Ex-FAT Support
*Custom Echoe Rom Settings allow for FULL CUSTOMIZATION of your phone (Check Screenshots)
*Complete Phone DPI Control
*With Viper4Android
*The AMAZING Echoe OG Battery MOD with over 65 Battery Icons to choose from
*wanam's XTorch
*Custom Boot Sound
Und läuft wieder 1a!
Der thread sollte mal angepasst werden. Oder beide threads zusammen gelegt werden. Und natürlich aktuell gehalten werden!
Der ursprüngliche Beitrag von 11:42 Uhr wurde um 11:44 Uhr ergänzt:
Ich würde mich zum aktuell halten zur Verfügung stellen! :)
Reaktionen: SunSide
kann ich die 11er einfach drüber installieren? ich habe immernoch die v8 weil sie so super läuft...:razz::thumbup:
Triple_H72
deli99
deli99
Logel
Kleptomane
waro
