[Sammy-ROM][ICS] *01.06.12* CriskeloServanTeam v11.1 - 4.0.3 (LPW)
rewesun
rewesun
23
HI, WILL ICH MAL WIEDER WAS VON CRISKELO VORSTELLEN!!!
SAUGEIL MAL WIEDER!!
LINK: http://forum.xda-developers.com/showthread.php?t=1659654
ROM◥███◣ CriskeloServanTeam V11.1◥███◣-ICS 4.0.3 - 15 Togg full working (Oficial LPW)
ROM CRISKELO SERVAN TEAM ICS
CriskeloServanRom SGS2 4.0.3 oficial Firm XWLPW
LINK 1
CriskeloServanTEAM_-V11.1-LPW-MD5-454A437D7CDE1DE22DAB1535DBFBCCDB.zip
LINK 2
LINK 3
Apps STOCK
APP_EXT_LPW.zip
If you don't already have CWM, You have to install it before install the rom. (As CFROOT).
Download the latest Criskelo ROM and put it on your INTERN SD card.
Open your CWM Application, select flash Update, and select the rom zip.
Say "yes", your rom will be installed.
Enjoy !
CriskeloServanTEAM ICS V11
Changelog v11.1
• ApexLauncher Lanzador ICS
• ADD Commando added VoiceS4
• ADD-icons-Added systemUI Battery and Wifi Criskelo.
• ADD finished theming in xml for bar colors, ram, progress, updates, etc ...
And some more I do not remember
LINK
CriskeloServanTEAM_-V11-LPW-MD5-9653A8B278BA69438475112EB9F3DF20.zip
Changelog v11
• Base Rom XWLPW
• CF-Root-SGS2_XX_OXA_LPW-v5.5-CWM5
• ADD Modem LPW
• Deodex
• ADD Superuser apk
• ADD Galaxy S3 Launcher ICS Mod ToucWizUX-1.3-5x5
• Add BrowserPlus ICS stock Browser
• AOSP keyboard ICS
• Samsung keyboard ICS
• AppWidgetPicker (Widgets groups, the same APP)
• ADD Roletube App YouTube that allows the download of Videos (SDCARD/Download)
• Host updated to avoid publicity
• Everything you need to run VPN (not tested) Thanks to ookba
• ADD LockScreen Original ICS and Samsung (in SD-CARD/ CRISKELO-SERVAN-ADDONS Update LockScreen Samsung/ICS)
• ADD StatusBar 15 toggles Theme STOCK/CRISKELO (en SD-CARD/ CRISKELO-SERVAN-ADDONS Update status bar 15 toggles stock theme/criskelo theme)
• ADD Version of Rom Agregado in About phone (Settings.apk)
• Mod SMS are not logged in Call Log
• ADD CRT TV off effect
• Native CallRec
• Various improvements in Framework-res.apk
• ADD 15 Toggles LibDroid (working perfectly)
• Fixes Status Bar (GPS icon, Direct access to settings, new icons, Data enlarged erase button (now a cross), Operator at the bottom, and some other tinkering)
• Battery% on / off from settings / display
• Icons en statusbar color ICS
• ADD Wallpapers in gallery Criskelo
• ADD more Wallpapers in TW Wallpapers
• ADD Gallery ICS Google
• DialPad style ICS
• Improvements in performance, ported from Galaxy S3
• Many details, to improve the overall stability of the ROM
Acknowledgments:
Thanks to josechufa and maquinabaja, for their contributions to help me make this great rom, a glutton for power PNG menu and follow the whole team for making this rom, best
Reaktionen: Macallan72, kiriakos1963, gonzo1978 und 10 andere
Habe mir gestern das Rom geflasht über die VK 3.5.4 ohne wipe's und bin total zufrieden läuft stabil keine forces und sieht zudem auch noch ganz gut aus... Kann ich jedem nur an Herz legen!
Aktuell:
CriskeloServanTeam V05
Reaktionen: rewesun
he, ich bin auch schon lange bei Criskelo, bin seit anfang an zufrieden!!
viel spaß damit!!
Aktuell:
Reaktionen: Milchbeck
Wie sieht es denn mit der Akkulaufzeit im vergleich zu Stock LPQ aus?
Denn mit Stock bin ich schon sehr zufrieden!
so,habs auch drauf,bis jetzt schauts ganz gut aus,mit der Akkulaufzeit kann man wohl erst berichten wenn man seine ganzen einstellungen beendet hat und es dann nur noch für den altagsgebrauch nutzt.
gruß
Die ersten beiden Links sind nicht mehr verfügbar und die anderen 2 sind ARSCHlahm :-(
hab mir die ROM grad geflasht, auf Empfehlung und ... :scared:
schaut sehr, sehr geil aus.
Reaktionen: rewesun
Hab mir gerade die rom geflasht. Sieht nicht schlecht aus. Aber der twlauncher funkt nicht. Hat wer eine ahnung? ich öffne den twlauncher---hintergrundblid wird angezeigt aber keine icons---kurzes freeze---twlauncher wurde angehalten. Diese meldung kommt immer!! Habe schon ein full wipe gemacht und wieder neu geflasht aber das problem bleibt gleich!!!
du musst vorher die stock flashen, hatte ich auch den fehler!!
:cursing::cursing::cursing::cursing::cursing:
Reaktionen: cr7sgs2
Funzt denn alles?
Sprich Kamera, Wlan, Bluetooth, usw.?
kann die stock apps nicht installieren... kommt immer die meldung "konnte nicht installiert werden"
Leider ruckelt die flash Wiedergabe auf z.b voxnow sehr stark hat wer eine Lösung?
wie sieht es mit der sdkarte aus? wird die erkannt mit der neuen v5?
picard74 schrieb:
Funzt denn alles?
Kamera ging bei mir nicht, WLAN usw schon.
also ich habe alles getestet und alles funzt tadellos,kamera,w-lan,datenverbindung,apps ausm market lassen sich ohne probleme installieren,jeder der probleme hat mit einen von den sachen sollte nochmal neu drüberflashen und empfehle dann einen fullwipe,ich persönlich brauchte keinen fullwipe machen und alles funzt 1a,das problem mit installieren ausm market wo dann fehlermeldung kommt mit der sd-karte der soll sich den originalen stock-kernel drüberflashen dann kommt diese meldung nicht mehr.
gruß
Reaktionen: MrGalaxy
So habe mehrere ROMs schon geflasht unter anderem auch diese aber zurzeit läuft einfach noch nichts wie es soll also bin wieder zurück zu VK 3.5.4 und warte bis eine Rom rauskommt ohne einschrenkungen vorallem ist jetzt erst die 2.3.6 perfekt geworden und kaum ist ICS raus sind alle wieder beta Tester also viel Spaß sorry für OT!
Sent from my GT-P1000 using Tapatalk
@Milchbeck,
ist ja alles schön und gut, aber genau das selbe hast du ja schon in einem anderen Thread geschrieben, daher verstehe ich jetzt nicht, was du damit bezwecken willst... :confused:
Reaktionen: MrGalaxy und janosik
Gibt für diese Rom swype?
Ich wollte euch nur sagen lasst den dev's die Zeit und erfreut euch an dem woran sie Monate lang gearbeitet hatten, denn sobald ICS für DBT da ist fängt wieder alles von vorne an...
Aktuell:
VK 3.5.4 / Siyah 2.6.13 / Ondemand 1200-200 (SIO) / Stock ICS THEME
Thoddü
Thoddü
Deadboy
Jamen
debaki
debaki
debaki
