[ROM][4.1.2 EME2 & 4.3 UGML2][WanamLite ROM V6.8 & V7.3 Final] (30.12.2013)
craP_cillA
craP_cillA
Dauergast
569
!Development Has Been Stopped!
[ROM]4.1.2
WanamLite ROM V6.8 Features
Based On The Latest Android Jelly Bean Firmware Update (XXEME2)
Deodexed & Rooted & Zipaligned & Busybox
Unlimited SMS recipient list & disabled conversion sms to mms
Repacked & Tweaked & Secure stock kernel (init.d support)
Automatic SMS encoding (Arabic and other utf-8 encoding support)
Tweaked Pegasusq Governor for better Battery life
Disabled scrolling cache
Removed Samsung Apps (available on Aroma installer)
Large APN list
No incremental ringtone
Unbranded
Clean build.prop for best Market compatibility
Stock Keyboard with all supported languages enabled
Hacked Stock Email App
Latest SuperSU Update (V1.34)
Enabled all supported languages
Multi CSC (+146)
No SMS on Call logs
Enabled Exit button to browser
Enabled Call button on Contacts and Logs
Unlimited Contacts joining
Enabled Shutter sound menu on Camera
Disabled Shutter sound on Apps
Enabled Camera during Call
Enabled Call recording
4 way reboot (Reboot, Hotboot, Recovery, Download)
Auto wipe cache & dalvik-cache before flashing
More to come......
ROM Installation
Copy this ROM to your internal or external SD-Card.
Install the latest CWM recovery....you can get it Here.
Backup, Backup, Backup.
A Full-Wipe is HIGHLY! Recommended, if you came from JB 4.0, (or higher!) AOSP & ICS ROM's.
Flash this ROM from recovery.
Reboot.
A Short Video-Tutorial:
How to Flash WanamLite ROM (V1.4 & Higher Versions!) (Made By "TotallydubbedHD")
Some Tips For A Longer Battery-Life
Disable auto sync for accounts.
Disable GPS (and wifi gps).
Disable auto backup of Gmail account.
Set wifi sleep policy to "Never".
Set brightness level to automatic.
Disable motion.
Check your apps settings & disable useless background sync.
Disable useless animations.
Adam Kernel V2.6 (JB 4.1) (Kernel-Sources)
Changelog, Features & Download For Adam Kernel V2.6
Adam Kernel V3.0 (JB 4.3) (Kernel-Sources)
Changelog, Features & Download For Adam Kernel V3.0
Changelog For WanamLite ROM V6.8
Updated Base to ME2
Updated Root Files (SuperSU V1.34)
Adam Kernel V2.6 (Optional but Recommended)
Repacked Stock ME2 Kernel (Optional)
CEELL1 Modem
Downloads
(WanamLite ROM V6.8 (JB 4.1.2) & WanamLite ROM V7.3 (JB 4.3))
ENJOY...
:biggrin:
Reaktionen: holzfish, Brickerl, !FlaSh! und 32 andere
Ich freu mich. War mit dem Rom auf dem S2 sehr zufrieden. Bin gespannt ob das Rom auch wieder so gut laufen wird.
was genau beinhaltet die
GT-I9300_WanamLite.ZSALED.SamsungApps.zip ???
Sind da die Apps drin, welche normal entfernt wurden?
Apps die Entfernt wurden.
Gesendet von meinem GT-I9300
Ich hatte in der letzten Zeit auf meinem S2 immer die Wanam Deoxed Rom drauf, sie lief immer echt gut.
Das erste Rom mit dem ich absolut Lagfrei via Tapatalk scrollen kann. Nach 20 Minuten meine absolute Nummer 1 unter den Stock Roms.
Reaktionen: mystery007
Reicht diese Datei? GT-I9300_WanamLite.ZSALED.V1.0.NO-WIPE.zip
Die andere über Odin flashbare brauche ich dann nicht?
BZW wofür ist des Modem gut?
Kann mal jemand schauen,ob bei diesem ROM bei den Zuordnungen von Kontakten alles in Ordnung ist ?
Ruft mich eine fest zugeordnete Person/Kontakt an,dann steht nicht mehr der Name,sondern nur noch die anrufende Telefonnummer
(Kontakte sind vorhanden).
Danke.
Hatte ich auch. Meine Lösung war, GoogleKonto löschen, neu eingeben, Kontakte Synchronisieren ,jetzt passt es.
Danke. Ich werde es so auch versuchen.
Apps die entfernt wurden:
AllshareDMC.apk
AllshareMediaServer.apk
AllSharePlay.apk
AllshareService.apk
AnalogClockSimple.apk
AnalogClockUnique.apk
ChatON.apk
DigitalClock.apk
Dropbox.apk
DropboxOOBE.apk
DualClockAnalog.apk
DualClockDigital.apk
FotaClient.apk
GameHub_2.0_ICS.apk
PanningTryActually.apk
SamsungApps.apk
SamsungAppsUNA3.apk
SamsungChineseIME_HKTW_Phone.apk
SamsungIME.apk
ShaoNv.apk
ShareShotService.apk
SNS.apk
SSuggest.apk
WfdBroker.apk
YahoonewsDaemon.apk
YahoonewsWidget.apk
YahoostockDaemon.apk
YahoostockWidget.apk
... lassen sich per CWM wieder installieren.
Das gute bei Wanams ROMs ist, dass er beim bloatware entfernen nicht gleich immer das Kind mit dem Bade ausschüttet.
Welchen Kernel verwendest du dazu?
Ich bin mir ziemlich sicher das er den siyah benutzt
Also ich habe es mal installiert mit full wipe davor wie immer und bekomme einen fc in com.android.phone. Außerdem sind einige Sachen Chinesisch.
Keine FCs bei mir und was ist denn auf chinesisch?
Naja beim ersten start waren ein paar Widgets zu sehen welche in Chinesisch waren. Kann man nicht wirklich übersehen eigentlich. Habe nochmals denn Cache und Dalvik gewipt aber fc besteht noch immer. Werde nochmals das Rom drüber installieren ohne Wipe und mal schauen wie es dann läuft. Habe das Rom von der Externen SD installiert was aber egal sein sollte denke ich.
Edit: Bezüglich Full Wipe, so mache ich immer auch wie schon beim S2 auch ein extra Format System.
Edit2: Auch ein erneutes drüber installieren hat nichts gebracht daher fliegt das Rom wieder runter bis der fc weg ist. Warum manche hier keinen fc haben weiß ich nicht denn ich denke ich installiere das Rom nicht anders aber irgendwo muss wohl der haken sein nur ka wo.
Bingo:)
Übrigens denn fc welchen ich hier bekomme habe ich eigentlich bei fast jeder Custom Rom gehabt. Was ich aber nicht verstehen kann denn ich mache alles so wie beim S2 auch und dort ging es ja auch immer. Entweder ist mein S3 anders als eures oder aber der Full Wipe wird bei mir nicht richtig ausgeführt aus welchen Gründen auch immer. So langsam nervt mich das aber schon vor allem weil ich mir denke das ich nichts falsch mache denn ich habe schon hunderte Roms installiert beim S, S2 und jetzt beim S3. Das einzige was ich immer mache ist das ich die Rom noch extra anpasse aber an der Phone App welche denn fc auslöst ändere ich nie was. Und die Anpassungen welche ich mache sind die selben wie schon immer von daher kann es daran eigentlich auch nicht liegen.
Pocketsoldier
Pocketsoldier
Pocketsoldier
V
Cobra427
  • Gesperrt
  • Android.Freak
SavanTorian
SavanTorian
