[ROM][I9300][4.3][XXUGNK1] *18.12.2014* Imperium v33.0 [HD Voice][AROMA][OTA]
alex1969
26
Imperium v26
Features:
Based on the last firmware XXEUGNA7 with Android 4.3
Deodexed + Rooted + Zipaligned
Aroma installer
Auto wipe cache and dalvik-cache before flashing the ROM
EFS folder backup before flashing the ROM
Wipe data, system and sd card (in aroma)
OTA Update with Update me Imperium - (thanks acquariusoft)
Root with SuperSU
Busybox v1.22.1
Sqlite3
OpenVPN support
Updated all app
Kernel:
NA7 Kernel Stock repacked with init.d folder support (in aroma and OTA)
Googy Max Kernel (Thanks to googy_anas)
LiteGX kernel (Thanks to AndroidGX)
Devil2 kernel (Thanks to DerTeufel1980)
Boeffla kernel (Thanks to AndiP)
AGNi pureSTOCK kernel (Thanks to psndna88)
Adam kernel (Thanks to Wanam)
Modem:
XXUGMK6 (JB 4.3)
DDUGMK1 indian (JB 4.3)
UBUGMK1 brasialian (JB 4.3)3)
XXUGMJ9 (JB 4.3)
BUUGMJ3 Vodafone (JB 4.3)
EMH1 no brand
EMG4 no brand
EMG2 no brand
Removed:
Bloatware and more app
Integrated:
Adobe Flash Player
FastDormancy Toggle for I9300 by gokhanmoral
Es File Explorer (in aroma)
AdAway (in aroma)
Gallery Excluder (in aroma)
SGS3 Easy UMS (in aroma)
Xposed Installer Framework (Thanks to rovo89)
Xposed App Settings (Thanks to Tungstwenty)
Wanam Xposed (credits to wanam)
LMT launcher (thanks to noname81)
Photo Editor
Mods:
With Wanam Xposed (credits to wanam)
Call Recording
4 Ways Reboot (Reboot, Recovery, Hotboot, Download)
Full Color/Transparency customization for Status bar and Notification drawer elements
Secure Samsung Keyboard
Option to keep "Add Call" button with Call recording menu
Disable Camera shutter sound (+Screen Capture)
Flashlight trough volume button UP
Skip Music with Volume buttons
Save Call Logs View
Enable Keyboard Symbols
Enable Hangouts Calls trough cellular
Enable Camera while calling
Unlimited and Customizable Multi-View support
Bypass Exchange Lock check
Notification Panel Customization
Long Home key behavior
Long Back key to kill App (+ white list)
Disable increasing ringtone
Messaging Tweaks (raise limits and conversion)
Disable Scrolling cache
Enable Full rotations
White/Colored Circle Battery
Transparent Notifications panel
Customize Clock format and size
Customize Battery text helper size
Customize Quick Settings buttons number per row
Collapse Quick Settings after toggle
2 line formatted date on the panel header
Dark themed Multi-Window
Disable Boot sound
Customize Two line date header format
White/Black Email App background (Supported on some devices)
Transparent Quick Settings buttons background
Default hidden SMS logs
Add Call button to Logs and Contacts list
Disable Accounts icons on Contacts list
Custimize Wifi AP Clients number
Disable Launcher page rotation
Add Exit button to browser
SMS Automatic input mode
Disable Call number formatting
Enable unlimited Contacts joining
Enable Gallery Rotation trough button
Set default Browser view to Desktop
Hide Wireless charging popup
Hide Full Battery Notification
Clock position Status bar (Hide, Left, Right, Center) (Compatible with I9300 and I9500 only)
NFC behaviors (UN/Locked on Screen ON/Off)
Hide Headset icon and notification bar
Disable TW DVFS
Enable TW DVFS Boost Benchmark mode
Hide Smart Stay, Alarm, NFC icons on status bar
Launcher: Enable Scroll wallpaper and Hide Dock labels
Disable Wake Home button
Use separate Address field on Contacts
Add Fast PIN unlock (to be used with caution)
Added SMS sent time details
Enable Screen ON options on Messaging App
Disable low Battery warning
Add custom carrier label on notification label
Set low Camera battery level
Change System Holo Dark/Light background
Acces hidden Lockscreen shortcuts menu
Disable SEAndroid/Knox notifications
And much more to come...
4x5, 4x6, 5x5 and 5x6 home and menu app grid for S3 TouchWiz
Note2 Camera
Note2 Keyboard
Note3 white keyboard (thanks to daoudedy)
Note3 TW with My Magazine (thanks to daoudedy)
Note3 MyFiles (thanks to daoudedy)
4x5 and 5x6 menu app grid for Note3 TouchWiz
Note3 Google Search Widget v2
Note3 Mobile Print v3
Note3 Mms
Note3 Calculator with one hand support
Note3 sound
Note3 Call notification popup ported by me
S4 sound
S4 S Health
S4 Gallery
S4 Digital Clock
S4 S memo v2
S4 Calculator
S3 AccuWeatherWidget MOD (Thanks to KIMBASINGER)
S4 Accuweather (thanks to indresh88) (in OTA)
S4 Album Story
AOSP Mms
AOSP calculator
AOSP Nexus5 4.4 KitKat keyboard
AOSP Nexus5 4.4 KitKat clock
AOSP Nexus5 4.4 KitKat Roboto Condenced Fonts
AOSP Nexus5 4.4 KitKat sounds
AOSP Nexus5 4.4 KitKat system app icon
AOSP Nexus5 4.4 KitKat wallpaper
AOSP Nexus5 4.4 KitKat email
Google launcher
Sony Xperia Z1 Walkman (Thanks to Rizal Lovins)
Sony Xperia Z1 Album and Movies (Thanks to Rizal Lovins)
MX Player and Samsung Video Player in aroma
Popup browser
New MegaBass for S3 (Thanks to geva28)
Viper4Android (thanks to viper520 and zhuhang)
AIO audio mod
Modded Bootanimation (Thanks to ayoubadri and Volpe92)
Fix GPS
Inverted GAPPS by Kryten2k35
Multi CSC (89) with HD Voice
CRT-OFF
Long Press Menu Key To Kill App
Hide SMS from Call Logs
Native support for IPEGA GAMEPADs (thanks to achaw)
Flare and Ink Effect by Arsaw ported in ML4 firmware by me
Lock Button in statusbar (in OTA)
Sense recent apps (in OTA)
OGBatteryMod
and more...
Tweaks:
build.prop tweaks
improve ext4 file system performance
GPU redering (force 60fps)
zipalign all app at the boot
Sqlite optimize
netforks tweaks
3G tweaks
Tweaked kernel and vm
Performance, moderate and battery saver script in aroma
Minfree Low Memory Killer in aroma
Download Aktuelle Imperium v26.0 [ROM][NK1 4.3][EMJ2 4.1.2][aroma][OTA] Imperium v33.0/v13.6 [HD Voice] [05/12/14] - Post #21 - XDA Forums
Change Log
[ROM][NK1 4.3][EMJ2 4.1.2][aroma][OTA] Imperium v33.0/v13.6 [HD Voice] [05/12/14] - Post #3 - XDA Forums
I TAKE NO RESPONSIBILITY FOR THE RISK IN FLASHING YOUR DEVICE.
FLASH IT ON YOUR OWN RISK .
CREDITS:
Thanks to Brothers Team (Bestboss & Slim80), dsixda for the kitchen, waman for more mod and guide, Kryten2k35 for more mod and inverted GAPPS, TopoMonko for keyboards thme and to all the authors of mods and tweaks on my ROM.
If you like my work please, offer me a beer
alex1969 übernimmt das Thema von Trina, dies sollte aber nur vorläufig sein. Er will es auch nicht zu lange machen.
Es wird also weiterhin ein Nachfolger gesucht.
Reaktionen: Jalintara, ~Aro~, fr3ak87 und 10 andere
oh...ganz frisch...
na dann wollen wir mal...
gesendet im letzten Jahr auf folgenden Festivals
Hatte schon die 4.1.2er Versionen der Rom, noch nie Probleme gehabt.
Klare Empfehlung. :thumbup:
Reaktionen: Hcolhcsra
Hat jemand Probleme SMS zu versenden?
Bei allen 12´ war alles ok, bei der 13´ kann ich (bin bei O2) keine SMS versenden da die Nummer der Versendezentrale nicht angegeben ist - Eingabe ist nicht möglich. Sonst läuft die 13´ prima!
Also ich bin so was von begeistert von der Rom...
Schnell zu und dabei sparsam...
Und man muss nicht den ganzen Bloadwarescheiss mitflashen...
Ich glaube die bleibt es erstmal....
...und ja...SMS senden geht Perfekt....
Allerdings sollte man dringend fullwipe beim flashen machen...wird ja direkt im Installationsmenue angeboten....
Werde wieder zu Imperium wechseln, habe damit am wenigsten Bloatware nach Aroma.
Gibt es irgendwelche bekannten Probleme?
also bei mir läuft sie seit 3 Tagen völlig problemlos. ..
Ja, jetzt läuft es bei mir auch.
Bis jetzt alles Top.
Ps: hast eine PN von mir, wegen dem Post im Goa Thread.
Bei mir fällt das mobile Netzwerke immer aus. Wenn ich neustarte klappt es dann ne Weile. Hat jemand einen Rat? Danke
ich kann nur allen raten, ein full wipe mit formatieren des internen Speichers durchzuführen, da 4.2.2 eine andere Speicherstrucktur verwendet. .
Hat noch jemand das Problem das er keine Sms versenden kann?
Ich kann auch keine Sms versenden.
Ist wohl ein Bug.
Kann, auch nach x Mal formatieren und tun und ....... :huh:, keine SMS versenden. Habe auch mit einer anderen SIM Karte versucht - keinen Erfolg gehabt.
Abwarten, Tee trinken (kann man bei diesem suuuuuuper Märzwetter sehr gut machen) ... und die Imeprium 12´ nutzen.
Unter SMS _ Einstellungen _ Nachrichtenzentrale fehlt die Nummer.
Anscheinend haben mehrere das Problem, laut XDA.
Mal schauen.
Guude, ich habe mal eine andere Frage!! Und zwar gibt es die Möglichkeit die Statusbar Transparent anzeigen zu lassen. Download der .zip Datei klappt auch, aber das flashen will irgendwie nicht.
Danke im vorraus
Alles klar danke, werde mich gleich mal ans Werk machen.
Eintellungen werden erst nach reboot übernommen!!
Es gibt eine neue Version aufvXDA, Sms bug behoben plus ein paar andere Sachen.
v13.1- Fix not install Stock S3 Samsung keyboard- Fix not set Message Center number- Added 1% battery mod- Added all app in MultiWindow- Added long press menu key to kill app- Added S3 camera Mod- Added EMA5 modem from the last fw EMD3- Update Philz recovery v5.05.3- Update Google Chrome- Update Google Play Music- Update Netforks Tweaks v3.0
@marc86 hast deine Tage heute?
araic
araic
Kani_23
Spot.Zwei
Spot.Zwei
Pocketsoldier
Pocketsoldier
Pocketsoldier
