[ROM][I9505][5.0.x] *22.12.14* Echoe GPE v 6.1
beicuxhaven
beicuxhaven
Ehrenmitglied
10.436
The ECHOE TEAM PROUDLY PRESENTS:
LOLLIPOP RELEASE:
(13 December 2014) Echoe GPE v5.0
DOWNLOAD
Echoe GPE Lollipop 5.0 (S4 I9505) - EchoeROM EchoeROM
Based on official Android 5.0 Lollopop I9505GUEUDNL3 (LRX21P.S012.141205)
Changelist: 2809293
Build Date: 05 Dec 2014
- Prerooted with latest SuperSU 2.38
(it asks for the binary to be updated which you can easily do whenever you feel like it-
even if you dont update the binary you still have root access)
- Latest Stericson Busybox
- Archi Init.d (init.d support independent of kernel/0
- Stock Kernel
- This is the first build so no mods for now- just pure stock..
- Updated to latest GoogyMax GPE Kernel (v1.2.4)
- Enabled all Mobile Networks (aka World Phone)
- Themed Lollipop Babyyyy!!
*** Darkened Settings, framework, systemui, dialer, contacts, keyboard (with 4 themes to choose from),
hangouts, playstore, youtube (the blackened gapps are courtesy of the blackout team!!) ***
* Default Kernel: GoogyMax GPE Kernel
(Try to get a random reboot now lol) ;)
* Re-introduced the Echoe Customization Center (It's in Settings/Personal)
(Your portal for OTA customizations as well as access to necessary tools
like Air Gestures, extended reboot, adaway, etc.)
* 3minit Battery mod (Choose over 1000 unique battery styles)
* Extended Power Menu available in the Echoe Customization Center
* Enabled Ambient Display (It's in Settings/Display)
* Added Viper4Android
* Enabled ALL languages by default
* Applied External SD Card Fix
Installation:
1. Use a custom recovery
2. Make a CLEAN FLASH (wipe data/factory reset and wipe system)
3. Flash the Rom
4. Enjoy!
Die ROM ist 541 MB groß... Sehr interessant
Der erste Start dauert locker 5Minuten...KEINE PANIK
Reaktionen: abemann
Gibt leider Probleme mit zufälligen Reboots. Ausschaltmenü über Power ist auch nicht vorhanden. Ansonsten ist die Rom nicht schlecht.
Reaktionen: abemann und beicuxhaven
wieso ist die Rom unter AOSP/AOKP eingeordnet? So wie es oben steht basiert die Rom ja auf der I9505GUEUDNL3 Firmware und diese ist die erste offizielle Android 5.0 Firmware für das I9505 GE - und hier halt abgewandelt für das I9505 Int.
Andi
GPE = Google Play Edition!? Sollte doch stimmen oder?
Update
* Based on official Android 5.0 Lollopop I9505GUEUDNL3 (LRX21P.S012.141205)
Changelist: 2809293
Reaktionen: abemann
Es gibt schon eine neue version und zwar dark themed ,die v6.1
Sieht wirklich cool aus in orange und grün.
Laut dem Entwickler soll man die Themes verändern können,
habe nur leider noch nicht den Schalter zum Wechsel gefunden.
( Siehe original thread auf xda-galaxy I9505 devolrpment)
Reaktionen: beicuxhaven
hier noch der komplette Changelog:
Reaktionen: abemann
Danke auch dir für den kompletten Chanelog.
hast du die V6.1 schon getestet ?
Läuft bisher ohne random reboots und sehr smooth.
Suche leider immer noch die themes in den settings
Ich hatte sie eben geflasht und wie du habe ich die Themingmöglichkeiten NICHT gefunden. Bin aber schon wieder auf AOSP.
Danke für dein schnelles feedback zu dem Thema.
Ich dachte schon ,es sei mein Fehler gewesen evtl.beim flashen.
Vielleicht gibt es bald Hilfe vom Entwickler.
Übrigens Frohe Weihnachten an alle hier
Frohes Fest auch von mir kann man denn auch wieder zurück auf die 4.4 flashen sollte die rom nicht gefallen?
Yepp
Leider geht das Bluetooth Protokoll RSAP für Mobiles nicht. Bin deshalb zurück auf ECHOE V38 da geht´s
Fifaheld
postmaster
Fifaheld
Darks
Darks
Nufan
Nufan
