[26/09][2.3.5]VillainROM 3.0 for SGS2 < Making perfection more perfect
Gast5050
Gast
VillainROM 3.0 for Samsung Galaxy S 2
So that old thread was long... Very long... It had good memories, but it's time to move on to a new thread, as 10k posts is just too much, and there are some more changes this time round. First off, it's as usual, a CWM flashable zip file. But, in a slight change of direction in light of Ninpo and Netarchy's Ninphetamine kernel being more complete, version 2.0.5 is now included. That is newer than the version released in the thread, but it will be updated in due course.
So for now, here's what's new in Version 3.0
- Fully deodexed
- Introduction of Ninphetamine kernel into the ROM (version 2.0.5 with BLN etc) - Note that BLN doesn't work with the stock SMS app, but Handcent is fine. I will look at ways to trigger BLN from the Messaging app later
- Install the BLN app from the market to use this
- Removal of Diginotar root certificates from the trusted store, given they are about as secure as a paper bank vault.
- All the usual stuff, although VRTweaks will be added from scratch again, since this seems a newer and better base.
- Re-addition of SIP since Samsung thinks you should be deprived of it.
Additionally, this is a way to try out the official KI4 ROM, without the bootloader being touched, thus allowing the USB jig to continue to working. To re-iterate, VR never flashes radios or bootloaders, so is safe. Stock ROMs, and other custom ROMs which are ODIN flashed, or indeed ZIPs, can and do sometimes flash these things without telling you. Just be aware - Samsung knows about the USB jig resetting the counter, and is on it...
Install procedure, and other details to come in following posts.
Contributing VRTweaks to VillainROM
Iff you want your tweak in VillainTweaks (with full credits etc) then please PM LennyUK with a description, screenshot if you have one to hand and a direct link (xda attachment, dropbox or your own server) No file hosts please.
We will add them to VRTweaks, so users can install them without having to download files to their phone. Likewise, if users find nice tweaks, let Lenny know
VillainROM Installation Instructions
To follow these instructions we presume you already have access to Clockworkmod recovery, and are able to put the zip file onto the SD card, and flash it.
If you are coming from a ROM other than VillainROM 1.2 or above, then you should carry out a full wipe. In fact, you should be carrying out a full wipe anyway, but it's not strictly 100% necessary if you are just coming from the previous version.
Coming from Another ROM
Ensure CWM recovery is available, do a CWM/nandroid backup and titanium backup, and put the zip onto the root of the internal SD.
Enter CWM, carry out a factory reset, and cache wipe, and flash the ROM via "Install zip from SD" option.
Reboot the phone into VillainROM, bearing in mind the first boot may take some time on the boot animation.
To use BLN
Ensure you are using the included Ninphetamine kernel, and install this app from the market (free, paid version with more features available)
Quelle:
[20/09][KI4]VillainROM 2.5 for SGS2 < Making perfection more perfect - xda-developers
Reaktionen: Simuur95, Kaio, niknase und 6 andere
[KI4] ? ist aber schon ne stock rom oder?
und KI4 kenne ich garnicht ist das neu?^^
Ich weiss aber aufgrund der neuen base und dem komplett neuen thread auf xda habe ich mich entschlossen den thread hier neu zu erstellen
Sent from my GT-I9100 using Tapatalk
Ist auch gut so, der Alte ist schon ewig in der versenke und unbenutzt was eigentlich schade ist da Villain ein sehr gutes Rom ist.
Themes musst mal schauen, früher war immer das App Villain Tweaks dabei , ähnlich dem von Leomar , darin sind auch Themes.
SGS II Cyanogen Mod 7
Und es läuft echt super
Das erste Rom welches auf meinem SGS2 super schnell und flüssig läuft. Wahnsinn. Hatte CM7, Litening, Oxygen, Miui usw. usf. drauf aber das hier läuft mit Abstand am schnellsten.
Gibt es denn die Möglichkeit diese Rom optisch etwas aufzuwerten ? Statusbar, Dialer, Akkusymbol und co ? Das schätze ich ja an den anderen Roms so sehr. "Personalisierung" ^^
Themes und Mods werden wohl kommen. Mir fehlt auch einiges aber man kann nicht alles haben.
Das stimmt. Aber es ist ja super so wie es ist. Nur nicht so "anders" ^^.
Was mir bisher sehr Positiv aufgefallen ist:
-Schnell und flüssig
-Banding hat abgenommen oO
-Klareres Bild
dann muss ich es ja auch mal testen^^
Oh jetzt habt ihr mich auch neugierig gemacht^^
Im Post 3 oder 4 ist die Villian Tweaks APK , darin sind immer Mods ect . Steht auch dabei.
Edit : Post 7
zum ersten mal hat mich mein Handy Überrascht.
Standard Kernel mit UV hier meine Werte:
1200MHz
  • 1150mV
1000MHz
  • 1050mV
800MHz
  • 950 mV
500MHz
  • 825 mV
200MHz
  • 800 mV stable
Meine Akkulaufzeit 15h Restakku 50%
Anzeige an 1h 10 Minuten
WLAN 5h
GSM 10h
GPS AN
Pushnachrichten an
Für mich die beste Akkukombination zur Zeit
Edit : Post 7
Die Mods sind aber scheinbar noch nicht für die Version 2.5
War auch nur ein Allgemeiner wink :)
Kein Thema, daher aber nur mein Hinweis eh sich jemand etwas zerschießt.
Sind ja nur die Tweaks für die jeweilige Version drin , zumindest war das früher so. Werde es mir die Tage auch mal wieder ansehen :)
Ja also steht drinne für welche Versionen diese gedacht sind.
MFG und gute Nacht
Dann ist es noch wie früher ;) Gute Nacht
Gast5050
Masta_Gee81
Masta_Gee81
Masta_Gee81
Lehrer
