  1. Chris1996, 28.05.2012 #1
    Chris1996
    Chris1996 Threadstarter Android-Experte
    [​IMG]
    Video zur Rom:
    RebelROM AOKP Galaxy S II 1.0 - YouTube
    Download:
    v1.3.1:
    Downloadlink 1
    oder
    Downloadlink 2
    Gapps nicht mehr in der Rom enthalten.
    -Download GAPP'S
    -Phone.apk die DPI unter 180 unterstützt: Download
    Features:
    -Based on AOKP-SGS2 ICS 4.0.4 -built from source, with some tweaks done by me
    -FLUXI KERNEL ICS XX.01-RC5.2
    -Google Apps & Face Unlock included in rom
    -APEX launcher - Launcher settings integrated into settings
    -OTA updater (thanks to Update me app) - Integrated into settings
    -Multi-language fluxi xxTweaker app - Integrated into settings
    -Solid Explorer added
    -Apollo Music player
    -Optimus 4x Style lockscreen
    -CM9 keyboard (added languages )
    Changelog:
    1.3.1 (08/6/12):
    -All bugs from 1.3 should be fixed
    -Updated Apex Launcher to latest beta (1.2.2Beta1)
    -Updated xxTweaker to latest beta (0.3.9_beta3)
    1.3 (07/06/12):
    -AOKP build 38 aokp
    -pHrail's rebel rom boot animation
    -all apks PNG optimized
    -Optimus 4x lockscreen no longer included (not compatible ATM)
    -Latest Fluxi kernel and xxTweaker
    1.2.1 (1/6/12):
    -Cleaned up a little bit
    -Fixed kernel flashing problem
    1.2 (30/5/12):
    -USB connection mode option re-added (go to settings->storage->click menu button)
    -DSPmanager replaced MusicFX
    -Some more build.prop tweaks
    +Google apps removed (flash GAPPS ICS separately)
    1.1 (29/5/12):
    -Optimus 4x lockscreen option cooked in
    -Apollo music player
    -xxTweaker updated to v.36
    -Keyboard from CM9
    -Couple graphical fixes in settings app (Apex setting icon changed, and "OTA update" renamed to "OTA Updater"
    1.0.1a (28/5/12):
    -1.0.1 +settings fix included
    -Wipe cache+dalvik included in updater-script (does it by itself when installing)
    1.0.1 (28/25/12):
    -Removed "Device Tweaker" (tweakGS2.apk) from settings and rom, because it really isnt needed when you have xxTweaker.
    -Couple other minor changes. ("Mod version" name change, etc)
    Installation:
    1. downloadet die Rom und die Gappa
    2. legt beides auf eure interne SD
    3. bootet ins Recovery
    4. führt einen Fullwipe aus ( wipe data/factory reset, wipe cache partition, wipe dalvik cache, format system )
    5. flasht die Rom indem ihr auf "install zip from sd card" geht und dann die Rom auswählt
    6. nachdem der Flashvorgang beendet ist klickt ihr erneut auf "install zip from sd" und flasht die Gapps dann geht ihr zu "Reboot system now"
    7. jetzt seid ihr fertig ;) enjoy!
    Falls ihr ein Update machen wollt ist es nicht nötig irgendwelche Wipes auszuführen, da in den Versionen ab 1.0.1a ein Updatescript enthalten ist ;) !
    -Netchip
    -AOKP team
    -Fluxi
    -any other devs involved
    Your work is REALLY appreciated
    Screenshots:
    [​IMG] [​IMG] [​IMG]
    [​IMG]
    ->XDA-Thread<-
    Extras:
    Giant AROMA tweak pack coming soon! It wont be included in rom, that will remain a clean install and under 120mb (110 currently). But I will put up a "Tweak pack" that you download separately and run in CWM after install of Rebel Aokp (if wanted). It will offer a choice of things like, replace/add launchers (nova,trebuchet, xperia s etc), Change bootanimation, Add reverted Gapps(black), Different kernel choices (dormanx/siyah, with extweaks in settings vs xxtweaker etc) Bravia engine addon, beats addon.. Stuff like that, working on it now, and will release with Rebel AOKP 1.3
    Request mods, bootanimations, launchers here http://goo.gl/Rj9sv
    Its a Google docs spreadsheet, Put requests in there respected column
    mareis1973, Akira-1980, Westi01 und 3 andere haben sich bedankt.
  2. Mayday, 28.05.2012 #2
    Mayday
    Mayday Android-Guru
    Werde es nachher mal testen.
    Gesendet von meinem GT-I9100
  3. Shaitan, 28.05.2012 #3
    Shaitan
    Shaitan Android-Lexikon
    Ich finde es nur merkwürdig das netchip dabei is und in about phone hydrogen ics steht!:mad:
  4. vivalasven, 28.05.2012 #4
    vivalasven
    vivalasven Android-Ikone
    Vielelcizht hat das ja dieser paradox unter neuen Namen reingestellt!? Aber komisch würde ich das auch finden.
  5. MadMurdoc, 28.05.2012 #5
    MadMurdoc
    MadMurdoc Ehrenmitglied
    Oder der Dev hat es nicht umbenannt..
  6. Chris1996, 28.05.2012 #6
    Chris1996
    Hat mich auch gewundert aber ich vermut mal das das in der nächsten Version geändert wird :rolleyes:
  7. debaki, 28.05.2012 #7
    debaki
    debaki Android-Lexikon
    Also die Rebelrom ist echt mega geil damals als asop, hatte mega geilen Akku und super flüssig. Ich Test naher auch mal die AOKP Version :)
  8. Chris1996, 28.05.2012 #8
    Chris1996
    Achja:
  9. Mayday, 28.05.2012 #9
    Mayday
    Mayday Android-Guru
    Gerade installiert, mal sehen...
    Erster Eindruck, funzt bis dato alles fehlerfrei, allerdings habe ich mir noch das RemountSD App installiert, denn das ist nicht dabei.
  10. Chris1996, 28.05.2012 #10
    Chris1996
    v1.0.1 zum Download verfügbar :D
    Download auch über die OTA-app möglich ;)
  11. gerti75, 28.05.2012 #11
    gerti75
    gerti75 Android-Hilfe.de Mitglied
    Bei mir fehlt in den Einstellungen der Eintrag "Konten&Synchronisieren"
    Ist seit der neuen Version nicht mehr mit aufgelistet. Kann das einer bestätigen?
    Edit: Zeit und Sound Einstellungen fehlen auch noch.
  12. zikarus, 28.05.2012 #12
    zikarus
    zikarus Android-Hilfe.de Mitglied
    Jap fehlt..
    Galaxy S2 tapatalking....
  13. gerti75, 29.05.2012 #13
    gerti75
    Chris1996 bedankt sich.
  14. Chris1996, 29.05.2012 #14
    Chris1996
    @ gerti75
    Danke ;) ich werds in den Opener aufnehmen :thumbup:
  15. Chris1996, 29.05.2012 #15
    Chris1996
    Und es gibt schon wieder ein Update :D
    1.0.1a (5/28/12):
  16. Shaitan, 29.05.2012 #16
    Shaitan
    Am anfang war ich etwas skeptisch wegen hydrogen in about phone. Aber der dev scheint ein anderer zusein und nur auf paradoxx aufzubauen.
    Zur rom kann ich nur sagen leider geil!
    Läuft smooth schnellbund bis jetzt ohne abstürze!
    Finde auch gut das kein aromainstaller an board ist bläst nur das download volumen auf!
    Echt Top Arbeit Danke!
    Send from Hell
  17. Mayday, 29.05.2012 #17
    Mayday
    Mayday Android-Guru
    1.0.1a (5/28/12):
    • 1.0.1 +settings fix included
    • Wipe cache+dalvik included in updater-script (does it by itself when installing)
    http://www.androidfilehost.com/main.../RebelROM/AOKP/RebelROM_aokp_1.0.1a_i9100.zip
    http://rebel-rom.googlecode.com/files/RebelROM_aokp_1.0.1a_i9100.zip
    CWM .zip that will replace phone.apk with one that supports a DPI change below 180
    http://www.androidfilehost.com/main...-I9100/RebelROM/AOKP/addons/phone_dpi_fix.zip
    Ich bin sehr sehr begeistert von dem ROM, denn alles läuft schnell und stabil. :w00t00::w00t00::w00t00:
    Das erste AOKP-ROM was mich überzeugt hat.
    Schade das er das TweakGS2 App rausgenommen hat, da doch einige Einstellungen drin sind, die es beim xxTweaker nicht gibt, aber per Titanium Backup kann man es problemlos zurückholen.
  18. Chris1996, 29.05.2012 #18
    Chris1996
    @ Mayday
    hab die TweakGS2 app die ja nicht mehr in den neueren Versionen enthalten ist ;)
  19. Shaitan, 29.05.2012 #19
    Shaitan
    Hi hab die tweak apk runtergeladen und installiert. Aber app ist nich auffindbar.
    Edit: habs hinbekommen apk nach system app verschoben und rechte gesetzt!
    Send from Hell
  20. Mayday, 29.05.2012 #20
    Mayday
    Mayday Android-Guru
    @Chris1996
    Hatte das App per TB wiederhergestellt.
    Mittlerweile gibts schon die v0.7.1, aber die ist nicht mehr free.
Diese Seite empfehlen
  1. rabel rom kernel
