[AOSP-Rom]*16.06.2012* Valhalla - LewaOS v.0.1.0 [Cm7 Base][Alpha]
debaki
debaki
Dauergast
500
Ich glaub heute wirds fast schon unübersichtlicher als an sonst einem anderen Tag =P Auch mal wieder gefunden bei XDA
Welcome to the Valhalla thread
This is a LeWa OS Port
Well, lets be straightforward. This is a port of the LeWa OS for our Galaxy S II. Its based on CM 7.2. Since I've not got the opportunity to test stuff out, it's tagged as alpha. I've named it Valhalla.
Screenshots:
Steps to flash the ZIP is simple:
  1. Fire up CWM
  2. Select "Install ZIP from SDcard"
  3. Browse to the ZIP (assuming you have copied it inside your sdcard already)
  4. Select yes and done!
  5. Wipe cache, dalvik cache and factory reset (if necessary)
  6. Flash gapps for gingerbread (link below)
FLASH AT YOUR OWN RISK!!!
I REPEAT, FLASH AT YOUR OWN RISK!!!
Download ROM (Mediafire)
Download gapps for gingerbread
:: V 0.1.0 ::
Updated Base ROM to the latest CM7.2 stable
Updated LeWa ROM to 15/6 release
:: V 0.0.1 ::
Initial release
Der thread ist abzugeben, wer ihn will schreibt mir ne pn.
X IE N o T IR i X
X IE N o T IR i X
dj3d
karu2003
j1gga84
vonharold
vonharold
