1. tc-maxx, 28.03.2012 #1
    tc-maxx
    tc-maxx Threadstarter Neuer Benutzer
    ich versuche mich an den APN-Einstellungen aber ich komme einfach nicht weiter.
    Meine App soll einen neuen APN anlegen und diesen als default setzen.
    Leider schmiert die Anwendung direkt nach dem Start ab:
    ( context.getContentResolver(... )
    Wer findet den Fehler? :rolleyes2:
    vg
    Code:
     package de.apn;
     import android.app.Activity;
     import android.os.Bundle;
     import android.content.ContentResolver;
     import android.content.Context;
     import android.content.ContentValues;
     import android.database.Cursor;
     import android.database.SQLException;
     import android.net.Uri;
     import android.util.Log;
     public class APN_Test1Activity extends Activity {
     private static final String TAG = "MyActivity";
     public Context context;
        @Override
        public void onCreate(Bundle savedInstanceState) {
            super.onCreate(savedInstanceState);
            setContentView(R.layout.main);
            EnumerateAPNs();
            int id = InsertAPN("WEBBED","webbed.de");
            SetDefaultAPN(id);
        //-[ Information of all APNs]-----------------------------------------------------
        public static final Uri APN_TABLE_URI = Uri.parse("content://telephony/carriers");
        //-[ Information of the preferred APN]-------------------------------------------
        public static final Uri PREFERRED_APN_URI = Uri.parse("content://telephony/carriers/preferapn");
       //-[ Enumerate all APN data]------------------------------------------------------
       private void EnumerateAPNs()
            Cursor c = context.getContentResolver().query(APN_TABLE_URI, null, null, null, null);
            if (c != null)
                String s = "All APNs:\n";
                Log.d(TAG, s);
                  try
                    s += printAllData(c); //Print the entire result set
                  catch(SQLException e)
                      Log.d(TAG, e.getMessage());
                  //Log.d(TAG, s + "\n\n");
                c.close();
        //-[Insert a new APN entry into the system APN table                        ]-----
        //-[Return an id (_id) that is automatically generated for the new apn entry]-----
        public int InsertAPN(String name, String apn_addr)
            int id = -1;
            ContentResolver resolver = context.getContentResolver();
            ContentValues values = new ContentValues();
            values.put("name", name);
            values.put("apn", apn_addr);
            values.put("mcc", "310");
            values.put("mnc", "260");
            values.put("numeric", "310260");
            Cursor c = null;
            try
                Uri newRow = resolver.insert(APN_TABLE_URI, values);
                if(newRow != null)
                    c = resolver.query(newRow, null, null, null, null);
                    Log.d(TAG, "Newly added APN:");
                    // Obtain the apn id
                    int idindex = c.getColumnIndex("_id");
                    c.moveToFirst();
                    id = c.getShort(idindex);
                    Log.d(TAG, "New ID: " + id + ": Inserting new APN succeeded!");
            if(c !=null )
                c.close();
            return id;
        //-[ Set an apn to be the default apn for web traffic ]--------------------------
        //-[ Require an input of the apn id to be set         ]--------------------------
        public boolean SetDefaultAPN(int id)
            boolean res = false;
            values.put("apn_id", id);
            try
                resolver.update(PREFERRED_APN_URI, values, null, null);
                Cursor c = resolver.query(
                        PREFERRED_APN_URI,
                        new String[]{"name","apn"},
                        "_id="+id,
                        null,
                        null);
                if(c != null)
                    res = true;
                    c.close();
            catch (SQLException e)
             return res;
        //-[Return all column names stored in the string array]---------------------------
        private String getAllColumnNames(String[] columnNames)
           String s = "Column Names:\n";
           for(String t:columnNames)
               s += t + ":\t";
            return s + "\n";
        //-[Print all data records associated with Cursor c]------------------------------
        //-[Return a string that contains all record data  ]------------------------------
        private String printAllData(Cursor c)
            if(c == null) return null;
            String s = "";
            int record_cnt = c.getColumnCount();
            Log.d(TAG, "Total # of records: " + record_cnt);
            if(c.moveToFirst())
                String[] columnNames = c.getColumnNames();
                Log.d(TAG,getAllColumnNames(columnNames));
                s += getAllColumnNames(columnNames);
                do{
                    String row = "";
                    for(String columnIndex:columnNames)
                        int i = c.getColumnIndex(columnIndex);
                        row += c.getString(i)+":\t";
                    row += "\n";
                    Log.d(TAG, row);
                    s += row;
                }while(c.moveToNext());
                Log.d(TAG,"End Of Records");
            return s;
  2. DieGoldeneMitte, 29.03.2012 #2
    DieGoldeneMitte
    DieGoldeneMitte Android-Lexikon
    Fehler nummer 1: Du hast keinen LogCat gepostet. :D
  3. tc-maxx, 29.03.2012 #3
    tc-maxx
    up's :)
    Code:
    Tag:                   Text:
    D/AndroidRuntime(208): Shutting down VM
    W/dalvikvm(208)      : threadid=3: thread exiting with uncaught exception (group=0x4001b188)
    E/AndroidRuntime(208): Uncaught handler: thread main exiting due to uncaught exception
    E/AndroidRuntime(208): java.lang.RuntimeException: Unable to start activity ComponentInfo{de.APN/de.APN.APNActivity}: java.lang.NullPointerException
    E/AndroidRuntime(208):  at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2496)
    E/AndroidRuntime(208):  at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2512)
    E/AndroidRuntime(208):  at android.app.ActivityThread.access$2200(ActivityThread.java:119)
    E/AndroidRuntime(208):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1863)
    E/AndroidRuntime(208):  at android.os.Handler.dispatchMessage(Handler.java:99)
    E/AndroidRuntime(208):  at android.os.Looper.loop(Looper.java:123)
    E/AndroidRuntime(208):  at android.app.ActivityThread.main(ActivityThread.java:4363)
    E/AndroidRuntime(208):  at java.lang.reflect.Method.invokeNative(Native Method)
    E/AndroidRuntime(208):  at java.lang.reflect.Method.invoke(Method.java:521)
    E/AndroidRuntime(208):  at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860)
    E/AndroidRuntime(208):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
    E/AndroidRuntime(208):  at dalvik.system.NativeStart.main(Native Method)
    E/AndroidRuntime(208): Caused by: java.lang.NullPointerException
    E/AndroidRuntime(208):  at de.APN.APNActivity.EnumerateAPNs(APNActivity.java:39)
    E/AndroidRuntime(208):  at de.APN.APNActivity.onCreate(APNActivity.java:25)
    E/AndroidRuntime(208):  at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1047)
    E/AndroidRuntime(208):  at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2459)
    E/AndroidRuntime(208):  ... 11 more
    I/dalvikvm(208)      : threadid=7: reacting to signal 3
    E/dalvikvm(208)      : Unable to open stack trace file '/data/anr/traces.txt': Permission denied
  4. swordi, 29.03.2012 #4
    swordi
    swordi Gewerbliches Mitglied
    der fehler ist in der apnactivity
    du hast den code der APN_Test1Activity gepostet
    und auch wenn das der richtige code ist
    du schreibst oben
    Context context;
    dann context.getContentResolver
    ist klar, dass der null ist. musst schon den context mal was zuweisen
    Zuletzt von einem Moderator bearbeitet: 29.03.2012
    tc-maxx bedankt sich.
  5. tc-maxx, 29.03.2012 #5
    tc-maxx
    ja das ist der richtige Code (heißt jetzt APNActivity)
    Thx! Iich habe jetzt context = this zuweisen, nun gehts schon mal etwas weiter..
    Code:
    Caused by: java.lang.SecurityException: No permission to write APN settings: Neither user 10028 nor current process has android.permission.WRITE_APN_SETTINGS.
     at android.os.Parcel.readException(Parcel.java:1218)
     at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:160)
     at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:114)
     at android.content.ContentProviderProxy.insert(ContentProviderNative.java:445)
     at android.content.ContentResolver.insert(ContentResolver.java:629)
     at de.APN.APNActivity.InsertAPN(APNActivity.java:80)
     at de.APN.APNActivity.onCreate(APNActivity.java:27)
    aber warum habe ich keine Rechte die APN's zu setzen?
    Dazu muss das Gerät doch nicht gerootet sein. :ohmy:
    vg
  6. DieGoldeneMitte, 29.03.2012 #6
    DieGoldeneMitte
    Öhm, ist dir noch nicht aufgefallen, dass es unter Android so etwas wie App Permissions gibt? :D
    Security and Permissions | Android Developers
    Welche Permission du der App geben musst, geht aus deiner Fehlermeldung hervor.
  7. swordi, 29.03.2012 #7
    swordi
    wie wärs mit google ?
    wenn du deine fehlermeldungen mal kurz vorher bei google suchst, wirst mind. 95% deiner probleme auf anhieb finden.
  8. tc-maxx, 29.03.2012 #8
    tc-maxx
    Ach stimmt, davon habe ich gelesen :unsure:
    Jetzt funzt dat!
    Vielen Dank euch :thumbsup:
    vg
  9. DieGoldeneMitte, 29.03.2012 #9
    DieGoldeneMitte
    Fürs Danke gibts nen Button. :D:D:D
    soma-web, tc-maxx und swordi haben sich bedankt.
