1. 19sheriff93, 15.06.2012 #1
    19sheriff93
    19sheriff93 Threadstarter Junior Mitglied
    Hi Leute! Ich ärger mich zur Zeit mit folegendem Problem herum: Hab Eine Datenbank (im vorhinein gebastelt). Diese vom Assetts Ordner zu kopieren ist kein Problem, die Datenbank wird im richtigen Ordner gespeichert! Ich hab nur ein Problem, und zwar dass ich einen Zugriff drauf bekomme... Hier mein code:
    Code:
    package at.android.twhk;
    import java.io.FileOutputStream;
    import java.io.IOException;
    import java.io.InputStream;
    import java.io.OutputStream;
    import java.sql.SQLException;
    import android.content.Context;
    import android.database.Cursor;
    import android.database.sqlite.SQLiteDatabase;
    import android.database.sqlite.SQLiteException;
    import android.database.sqlite.SQLiteOpenHelper;
    public class DataBaseHelper extends SQLiteOpenHelper{
        //The Android's default system path of your application database.
        private static String DB_PATH = "/data/data/at.android.twhk/databases/";
        private static String DB_NAME = "twhk_android_sqlite";
        private SQLiteDatabase myDataBase;
        private final Context myContext;
         * Constructor
         * Takes and keeps a reference of the passed context in order to access to the application assets and resources.
         * @param context
        public DataBaseHelper(Context context) {
            super(context, DB_NAME, null, 1);
            this.myContext = context;
         * Creates a empty database on the system and rewrites it with your own database.
        public void createDataBase() throws IOException{
            boolean dbExist = checkDataBase();
            if(dbExist){
                //do nothing - database already exist
            }else{
                //By calling this method and empty database will be created into the default system path
                   //of your application so we are gonna be able to overwrite that database with our database.
                this.getReadableDatabase();
                try {
                    copyDataBase();
                } catch (IOException e) {
                    throw new Error("Error copying database");
         * Check if the database already exist to avoid re-copying the file each time you open the application.
         * @return true if it exists, false if it doesn't
        private boolean checkDataBase(){
            SQLiteDatabase checkDB = null;
            try{
                String myPath = DB_PATH + DB_NAME;
                checkDB = SQLiteDatabase.openDatabase(myPath, null, SQLiteDatabase.OPEN_READONLY);
            }catch(SQLiteException e){
                //database does't exist yet.
            if(checkDB != null){
                checkDB.close();
            return checkDB != null ? true : false;
         * Copies your database from your local assets-folder to the just created empty database in the
         * system folder, from where it can be accessed and handled.
         * This is done by transfering bytestream.
        private void copyDataBase() throws IOException{
            //Open your local db as the input stream
            InputStream myInput = myContext.getAssets().open(DB_NAME);
            // Path to the just created empty db
            String outFileName = DB_PATH + DB_NAME;
            //Open the empty db as the output stream
            OutputStream myOutput = new FileOutputStream(outFileName);
            //transfer bytes from the inputfile to the outputfile
            byte[] buffer = new byte[1024];
            int length;
            while ((length = myInput.read(buffer))>0){
                myOutput.write(buffer, 0, length);
            //Close the streams
            myOutput.flush();
            myOutput.close();
            myInput.close();
        public void openDataBase() throws SQLException{
            //Open the database
            myDataBase = SQLiteDatabase.openDatabase(myPath, null, SQLiteDatabase.OPEN_READONLY);
        public synchronized void close1() {
                if(myDataBase != null)
                    myDataBase.close();
                super.close();
        @Override
        public void onCreate(SQLiteDatabase arg0) {
            // TODO Auto-generated method stub
        @Override
        public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
        public void open() {
        // Add your public helper methods to access and get content from the database.
       // You could return cursors by doing "return myDataBase.query(....)" so it'd be easy
       // to you to create adapters for your views.
    Hoffe dass mir jemand helfen kann was noch fehlt oder vil sogar einen besseren Code hat den er mir zur Verfügung stellt...
    lg und danke im Vorraus Sheriff :smile:
  2. swordi, 15.06.2012 #2
    swordi
    swordi Gewerbliches Mitglied
    ja und wo ist die fehlermeldung?
  3. 19sheriff93, 15.06.2012 #3
    19sheriff93
    Bekomm ich eben keine, das ist ja das komische :S
  4. swordi, 15.06.2012 #4
    swordi
    das glaub ich dir aber mal nicht.
    woher weißt du dann das es nicht geht ? irgendwo wird was stehen
    logcat kennst du aber oder ?
  5. Coeptis, 15.06.2012 #5
    Coeptis
    Coeptis Neuer Benutzer
    Erstmal das Erstellen von Datenbanken
    Das Eintragen von Daten
    Das Auslesen von Daten zum Beispiel so
    So habe ich es das letzte mal gelöst! Vielleicht hilft es dir ja deinen Fehler zu finden.
  6. 19sheriff93, 18.06.2012 #6
    19sheriff93
    mal schauen ob ich da war hernehmen kann, danke!
