Cthulhu 1.0 ROM for Bluepanther Thunder MID/Derivates
lgstoian
Hello folks. Sorry for the long period of sillence. I have been quite busy with work and other problems and didn't have any time for our tablet. But now I finally got some free time and the result is Cthulhu 2.0. 1.0 was more of a proof o concept rom and it had many issues and not too many improvements.
2.0 on the other hand is a big step up and also should work on all GM10 tablet derivates ( including the ones with bluetooth)
Features :
- crap app's removed
- latest gapps ( new market, new gmaps , etc ...)
- street view
- you can now connect to ad-hoc wifi networks
- calendar now works
- news and weather
- contacts
- car home
- dev tools
- calculator
- build.prop tweacks
- more things coming soon !!!
- fixed gmail
Next step will be performance optimizations.
To install :
- make sure you have the latest update for your GM10 ( Bluepanther one is here )
- grab this archive from here and extract it
- make sure you have the usb drivers for your tablet. Get them from here
- open the comand line and go to the folder where you extracted the cthulhu rom
- run install.bat
- wait for the install to finish and the tablet will reboot on it's own
- profit !!!
Reaktionen: ClemensK, Stoffel und Nowis
Don't have to much this weekend but at the first look, seems to be nive work
Some people have been having problems unpacking the 7zip. Ill upload a new normal zip soon.
Was ist das jetzt? Ein Update auf die jetzt neue cf von Bluepanther Thunder?
Es scheint eine abgeänderte Version der neuen FW zu sein, werde es probieren.
EDIT: So habe es installiert, wenn ich diese richtig verstehe ist dies nur ein Script welches einige teile des OS´s löscht bzw. verändert.
Als Tipp für Vista und Win7 Nutzer, Install.Bat als Amdin ausführen.
Ja mach das mal und berichte. Bin mit der neuen Version eigentlich gut zufrieden, mal schauen was diese hier noch bringt.
Konnte bis jetzt noch keine große Veränderung feststellen außer das BT fehlt, aber wenn hier wirklich das Tele. entfernt ist müsste der Akku jetzt lange halten wir werden sehen.
Kannste du nochmal die genauen Schritte aufschreiben?
Klar:
erst die neuen Version des Blue Thunder flashen.
Die Datei von Cthulhu runterladen, falls der USB Treiber nicht installiert ist auch noch runterladen und Manuel über Systemsteuerung installieren(falls er nicht automatisch nach den Dateien fragt.
Danach das Touchlet per USB verbinden und daran denken das der Debugging Modus aktiviert sein muss.
Keine Speichermedium am Touchlet aktivieren und die Install.bat am PC als Admin starten.
Bei Fragen einfach melden.
So nun habe ich folgendes Problem, dass ich die Navgear Software nicht mehr benutzen kann, weiß nicht ob es an dem FW update lag oder an dem Script.
Folgender Fehler,
"Please exit Navgear, delete devive.nng and ACTIVATION_CODES filed form the iGO/license directory of the sd card, and powercycle the device.
Habe schon nen Hard reset gemacht und alles neu installiert auch die daten auf die SD kopiert.
jemand ne Idee??
EDIT: So liegt an diesem Script man kann bei diesem Script die NavGear Software nicht benutzen.
Werde dies bis morgen lassen und schauen was der Akku macht jedoch möchte ich auf das Navi nicht verzichten, evlt. hat jemand ne idee wie ich es zum laufen bekomme.
was bringt den diese rom für neuerung?
Und kann einer Scenshoots von der neuen rom machen fals sich was vom aussehne getahen hat
mir ist nur audgefallen das der Standartdateimanager weg ist, kein Bluetooth mehr gibt und vorallem der Prozess Mobilfunkstanby ist weg.
Aber leider geht das NavGear nicht mehr.
@lgstoian
Have you made this script? Can you made a script who only the telephone app remove?
You can adapt my bat file for your app list.
I have not experience with this things, how i can edit the bat file?
I will just that the Mobilphonestandby be disable.
EDIT:
i have open the file.
i had edit the file but the NaviSoftware dont go. i get the same error:
"Please exit Navgear, delete devive.nng and ACTIVATION_CODES filed form the iGO/license directory of the sd card, and powercycle the device."
Before the script the NaviSoft. running.
here my bat.
adb shell mount -o rw,remount /dev/block/mtdblock3 /system
adb push su /system/bin/su
adb shell shell chmod 4755 /system/bin/su
adb shell rm /system/app/Phone.apk
adb shell rm /system/app/TelephonyProvider.apk
adb push Superuser.apk /system/app/Superuser.apk
adb reboot
The navi software might require the Phone service.
Sorry for the long wait. New rom is out. Enjoy.
O
hävksitol
hävksitol
Val
hävksitol
hävksitol
Stoffel
