CyanogenMod FULL for trekstor-Surftabe Xiron 10.116gb ST10416 1AC
mussonero
Final update 30/01/2015
HW acceleration , added Panorama view fix , Auto rotate, added GLS_Webview fix, added MediaFlot fix, patched CWM recovery and Kernel updated.
* Frameworks: Fix volume button changing two ‘steps’ per click
* Frameworks: Add ‘Screen Off’ action for double-tap/long-press configuration options
* Show devices connected to your WiFi (tethering) Hotspot
* Fix bug related to ‘switch to last app’ action while in Recents view
* Fix Navigation Bar arrow keys in RTL locales
* Camera: Add support for all available Slow Shutter speeds (hardware dependent); Improve shutter button
* Various security updates
* General bug fixes
* Frameworks & Core Apps: CAF and other upstream updates
For formating the Tablet after the first start in CWM
[URL = "https://www.4shared.com/zip/ATqzF2oyce/utils_format-signed.html"] utils_format-signed.zip [/ URL]
For installing Google Apps
gapps-full-4.4.4-20150125-signed.zip
Thanks to development CM community and RK
CM11_4.4.4_Surftabe_Xiron_10_16gb_ST10416-1AC_2015_01_30.zip
MD5 24fe423e2a8af8c2a71e6de4b04e34a6
SHA1 f9c9a60994710e34aefaf3f23e74ae34714b169e
:tongue:
Reaktionen: rudolf
Hi Mussonero,
I have a question for you...
I tried to install your Cyanogenmod package,
but the tablet, after running the update from an SD card, doesn't turn on.
I have tried any possible combo with the keys to reboot tha tablet,
but no one was correct...
The tablet still remains black...
HELP PLEASE.........
Thank you 4 your work
Du hast vielleicht das 1C. Dieses Rom ist für das 1AC.
Notfalls gibt es meine unbrick Anleitung.
(He could have the 1C variant).
Hab es auf einem 1AC laufen, also naja, zumindest installiert.
Egal welche der beiden Versionen ich nehme,
und egal welche Wipe Methode ich über die utils_format-signed.zip auswähle,
es zeigt mir nur das Cyanogenmod Logo mit dem drehenden Kreis an,
und sonst passiert nichts.
Selbst nach einer Stunde hat sich noch nicht wirklich was getan,
und nur der Kreis dreht sich weiter.
Schade eigentlich,
hab Cyanogenmod auf meinem HTC One Max laufen,
und hatte damit eigentlich immer gute Erfahrungen :D
Aber auf jeden Fall : Big Thanks für den Up! :)
are you sure ,you have done a full format using utils_format-signed.zip from cwm recovery.??
when you installed the firmware using tool Batch RockchipV1.6 did you select restore or upgrade ??
please follow this guide here link
Sind Sie sicher ?? ... hast du eine Vollformat mit utils_format-signed.zip von cwm recovery.??
wenn Sie die Firmware mit dem Werkzeug Batch RockchipV1.6 haben Sie ..restore wählen oder ein Upgrade installiert ??
folgen Sie bitte diese Anleitung hier verlinken
Yeah, i'm 100% sure that i did a full format with utils_format-signed inside of cwm recovery.
And yeah, i selected "Restore", just like we're getting told in your awesome tutorial.
I repeated the Flash Procedure a few times now,
and now it's booting the way it's supposed to be.
But, unfortunately, the Rom isnt saving the Setup-Settings,
so i have to setup from scratch everytime i restart or shut-down & start my Tablet.
Well, but at least it's now running kinda stable,
so my efforts werent completly useless :D
first thing congratulate on your efforts :)
but i did not understand what you mean by "the Rom isnot saving the Setup-Settings," ??,, any settings should be saved to /data partition
i am getting the feeling that you need to check your data partition again from recovery, try formating it from CWM advance mount menu .
zuerst, gratulieren auf Ihre Bemühungen
aber ich verstand nicht, was Sie mit "the Rom isnot saving the Setup-Settings," ??,, .. Ich bekomme das Gefühl, dass Sie brauchen, um Ihre Datenpartition wieder von Recovery prüfen, versuchen Sie es Formatierung von CWM Voraus montieren Menü.
Hallo zusammen!
Ich habe nun das ROM laut Anleitung auf die 1C Version geflashed,
hat alles prima geklappt.
Nach dem formatieren mit den utils bekomme ich jedoch nur den Boot Splash Screen,
mehr tut sich nicht.
Habe somit auf das original ROM zurück geflashed.
Gibt es eine Möglichkeit es auch auf dem 1C zum laufen zu bekommen?.
Viele Grüße Marc
spacewan schrieb:
Hallo zusammen!
Viele Grüße Marc
versuchen Sie es Formatierung Data & cache von CWM fortgeschritten montieren Menü.
Das habe ich schon gemacht.
2x geflashed, 2x format von data und cache in cwm advanced.
Bekomme nur den BootSplash Screen.
Könnest du mir evtl sagen wo ich die proprietären Dateien und Treiber für die Hardware von diesem Tablet bekomme, bzw. was genau alles an Hardware verbaut ist.
Ich würde mir dann das CM11 für das 1C nochmal versuchen selbst bauen...
Grüße
Marc
ohne Logcat um zu sehen, was los ist ,ich kann dir nicht helfen :confused2:.
aber versuchen Sie das Formatieren mit diesem link format.zip.
oder versuchen, herauszufinden, wie Sie die Logcat erhalten :sleep:
Mussonero, er hat das 1C und nicht das 1AC. Du sagtest das video ist anders, und seins bleibt dunkel.
He has a 1C and not a 1AC. You wrote the LCD/video is different, and he has no screen picture. See your other thread on the 4.4 update.
ja, ich erinnere mich ich so sagte ,aber es scheint, es gelang ihm irgendwie zu bekommen es wie stillerchiller läuft Vielleicht gibt es eine andere versione wir nicht kennen
yes, i remember i said so,but it seems he managed somehow to get it running like @stillerchiller:confused2: maybe there is another versione we do not know about:confused2:
hatt jemand Dritter, ausser dem Rom Bauer, das Rom zum laufen bekommen?
Und wenn ja wie! Entweder es hängt im Recovery Startbildschirm, oder aber in der Startanimation. Wäre echt schön auf dem Tab cm11 am laufen zu haben.
Bikergruß
Tassi
gibt es was neues dazu ob jemand diese rom bzw. eine andere rom mit android 4.4.* auf einem 1C zum laufen bekommen hat ?
würde gern nen ps4 controller am tablet nutzen. leider funtzt das pairing mit der stockrom nicht wirklich.
auf meinem handy mit 4.4.4 läufts 1A.
hat vllt. jemand nen anderen bluetooth controller (zB PS3) mit der stockrom getestet ?
Blade1979
  • Blade1979
Blade1979
Blade1979
Nexus001
  • Nexus001
Nexus001
Nexus001
Spirit3678
RockThisParty
