[DEV] Reloaded ICS 1.9b4-050712 | CyanogenMod 9 UI Enhancements | All phones
hanschke
Gast
FEATURES
  • Transparency
  • Status Bar Layout
  • Date Format
  • Brightness Control
  • Horizontal Recent Panel
  • Clock Location
  • Power Widget Enhancements
  • Tabbed Layout
  • Bottom Statusbar
  • Volume control
  • Statusbar Theming
USAGE
Reloaded ICS replaces the default user interfaces and adds many options for you to choose from.
Install CWM zip in recovery, clear dalvik cache, and reboot.
After reboot, click on the settings button in your expanded statusbar, or find the Reloaded ICS icon in your app drawer.
REQUIREMENTS
Any Deodexed CM9 ROM. Reloaded ICS is not compatible with tablets.
DOWNLOADS
http://forum.xda-developers.com/attachment.php?attachmentid=1045986&d=1336376220
xda-developers - View Single Post - [DEV] Reloaded ICS 1.9b3-041012 | CyanogenMod 9 UI Enhancements | Update: themes
This should work on all phones with CM9. This list is just some of the devices that have been tested.
CHANGELOG
May 7, 2012 - Version 1.9b4
  • Statusbar icon alignment bug fix
  • Reloaded Settings bug fixes
  • New color settings for wifi/data indicator & data type
  • Updated power widget icons to new CM ones
  • Full Circle battery set added
  • Stock signal/wifi icons with transparency
  • (thanks to lilxflip for the stock transparency icons)
  • Lots of other bugfixes
Known issues:
  • Small display bugs while changing settings - toggle themes on/off to fix
  • CM9 Torch toggle requires you to have torch app installed (net.cactii.flash2)
  • (not really an issue but listed here to avoid erroneous posts)
  • USB string bugs in certain kangs
April 10, 2012 - Version 1.9b3
  • All text color bugs fixed when no themes are applied
  • Initial battery icon implementation, 6 different types, more to come
  • Alternate notification style, inspired from fake Jellybean screenshots
  • Wifi/bluetooth switches no longer jump, acts like Settings toggles
  • Other bugfixes
Known issues:
  1. Some display and alignment bugs when changing settings, restart or turn themes on/off to fix
  2. Hard to see activity indicator on top of new wifi/3g icons
  3. CM9 Torch toggle requires you to have torch app installed (net.cactii.flash2)
  4. (not really an issue but listed here to avoid erroneous posts)
  5. USB string bugs in certain kangs
April 2, 2012 - Version 1.9b2
  1. Restarting UI no longer necessary for changes
  2. Theming
  3. New app to allow better organization
  4. Navigation bar customization (CM9 navbar editing patched in)
  5. New wifi/3g/battery icons to allow for theming
  6. Too many to list!
March 20, 2012 - Version 1.7
  • Audio widget - volume slider in statusbar
  • Widget ordering, select how you want audio/backlight/power widget displayed
  • Hide auto-brightness button option
  • Date positioning options as requested
  • Large battery text style
  • Updated Reloaded Settings
[DEV] Reloaded ICS 1.9b4-050712 | CyanogenMod 9 UI Enhancements | All phones - xda-developers
Reaktionen: vivalasven, Icedsoul, Donald Nice und eine weitere Person
so neues update eingebunden. hoffe es gefällt euch. die ganzen muimiu rom user brauchen also nicht mehr umsteigen ;)
Reaktionen: Icedsoul und Donald Nice
Weißt du zufällig, ob da vielleicht irgendwann auch noch die versteckbare Navigation Bar dazukommt?
das kann ich dir leider nicht beantworten. frag mal bei xda nach. cool wäre es wenn das in cm9 einfließen würde ;)
So hab nu Antwort bekommen..
Sorry, not at the moment, maybe in a later version..I get too many feature requests and really have a lot on my plate at the moment. Thanks for your support!
ein neues update eingebunden. könnte ein mod den titel bitte anpassen? danke :)
Das ganze integriert in AOKP und ich wäre glücklich. Sieht wirklich sehr sehr gut aus was man damit so anstellen kann. Vor allem der Vorschlag unten links gefällt mir extrem gut.
Bin ich doof oder kann man die Farbe der Statusleiste nicht anpassen?
Kann irgendwie nur die Position der Uhr und so anpassen und die Farbe der NavBar aber Statusbar nicht...
hab mal die neue beta eingebaut. falls ein mod den titel wieder anpassen könnte ;) danke :)
hat das teil eigentlich kein autohide? bin total verwirrt da ich bei the lost city die softkeys sehe obwohl man die nicht benötigt.
ein neues Update ist da :D
mal was dämliches. wie komme ich an die einstellungen vom 1. bild und kann ich die farbe der icons ändern in der benachritigungszeile?
Hi Hanschke. Sieht sehr gut aus, was du da anbietest. Ich würde es gerne nutzen, weil mir die Statusleiste im runtergezogenen Zustand insgesamt zu dunkel ist. Allerdings klappt das nicht. Habe das ZIP in CWM geflasht und der Anleitung entsprechend den Dalvik geleert. Nach dem Booten kommt sofort eine Fehlermeldung, dass System UI beendet wurde. Nandroid Backup war der einzige Ausweg.
Ist mein ROM - Burstlam's AOKP CM9 Remix RC 6.3 - nicht kompatibel oder habe ich sonst irgendwas falsch gemacht?
Danke schonmal!
kurze frage, auf die ich keine antwort gefunden hab: wenn ich reloaded ics wieder entfernen will einfach die rom nochmal installieren?
ja
. Eine fix für die aktuelle nightly gibt's noch nicht, oder!?
________________________________
gesendet via Brieftaube namens Tapa
Würde mich auch brennend interessieren.....
solange ich hier nichts reinschreibe gibt es kein update. ihr könnt aber gerne bei xda eure probleme schildern um den entwickler zu helfen.
Leider ist im XDA Thread nicht wirklich die Bewegung bzw der Dev lässt noch nix von sich hören, aber naja. Kommt Zeit kommt Rat. Iwann wird er sich das schon anschauen :)
  • flipsns
flipsns
MacDidi
MacDidi
sgspluss
  • sgspluss
2 3
gorgooger
