choppy
Dauergast
- 277
Quelle: XDA
★☆ Kangaroo Kernel ☆★, Kernel for the HTC One
Vom Entwickler eingestellt!
Linux 3.4.105 base, comes with a modified ramdisk for sdmount fixes from santod040
Poondog hat uns wieder mit Kernels beglückt, einen für Lollipop GPE und einen für Lollipop Sense Roms.
Wie immer akkuschonend, alles Features dabei.
Viel Vergnügen!!!
Letzte Versionen:
GPE 5.0.1 16. März
Sense 5.0.2 16. März
Changelog für beide Kernel:
Changelog: 16 March
.some misc tweaks
.fix sound from speakers issue
[KERNEL][LOLLIPOP] ★☆ Kangaroo K… - Pg. 86 | HTC One | XDA Forums
Changelog: 8 March
.introduce PRESERVATIVE gov, tuned it for m7
.introduce SMARTMAX gov
.update BFQ iosched to v7r7
[KERNEL][LOLLIPOP] ★☆ Kangaroo K… - Pg. 78 | HTC One | XDA Forums **
Changelog: 26 Feb
.added Slimbus OC (for better audio output and power, now we can push audio further)
.trim some fat from the kernel (you won't notice what's gone hopefully)
.added init.d support, it requires busybox assuming its in system/xbin
.add support for official WWE 7.19 base on Sense version
Changelog: 19 Feb
.upstream update to Linux 3.4.106
.misc patches from CM/CAF to rid potential memory leaks and lockups
.support lower GPU idle freqs
.fix some boosting issues on GPE
***** 6 February *****
.hotfix for speakers issue on Sense 5.0.2
[KERNEL][5.0.1] ★☆ Kangaroo Kern… - Pg. 46 | HTC One | XDA Forums
***** 5 February *****
.Disabled some logging stuff (less waste of resources)
.some optimizations for KSM (kernel samepage merging, to do with memory. See here KSM - KVM)
.a lot of under the hood stuff for smoothness and battery
.updates to kernel mode neon
.some updates from CM and Google for conservative gov
.advanced TCP control (default westwood, sorry @ZeroInfinity )
.misc cleanups for 2w
.add pocket detection feature for 2w (flar2)
.set default io as deadline, readahead to 512kb (seems to be optimal for battery and performance)
.some more tweaks to network related stuffs
[KERNEL][5.0.1] ★☆ Kangaroo Kern… - Pg. 44 | HTC One | XDA Forums
***** 22 Jan *****
.allow GPU to sit at 27MHz
.some small tweaks for performance and battery
.some RAM tweaks (thx Imoseyon)
.set DEADLINE as default scheduler
[KERNEL][5.0.1] ★☆ Kangaroo Kern… - Pg. 37 | HTC One | XDA Forums
***** 16 Jan *****
.hashtable: introduce a small and naive hashtable
.switch to new hashtable for some drivers (more simple, less generic code for better efficiency)
.workqueue: introduce Linaro Power Efficient Workqueues
.switch to power efficient workqueues for some drivers (for efficiency)
.move all voltages up a PVS version
.introduce USB FORCE FAST CHARGING
.reduce some wifi wakelocks
.removed some logspam
.disabled some debugging (reduce power waste)
.show GPU freq properly, idle at 27MHz
.add userspace voltage control
.usb: gadget: mass_storage: added sysfs entry for cdrom to LUNs
.add a config option to switch to Nexus 7 acpu table (1512 max but this is disabled)
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #251 - XDA Forums
***** 22 Dec *****
.introduce sweep2wake, doubletap2wake, logo2menu, logo2wake options (see below)
.some more optimizations and improvements under the hood (better battery + performance)
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #183 - XDA Forums
***** 13 Dec *****
.compress with LZ4 rc125 (for faster booting, backported from 3.17 source)
.init to max speed on boot (for faster booting, from motorola)
.increase read speed of deadline scheduler
.introduce BFQ-v7r6-3.4 scheduler
.introduce FIOPS scheduler
.optimized AES and SHA1 routines
.optimize square root algorithm
.use glibc version of string and memcopy
.freezable blocking calls and updates to freezer
.remove some debugging
.RCU_FAST_NO_HZ timer offsets from motorola
.some other misc code improvements
.Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #121 - XDA Forums
***** 11 Dec *****
.full upstream to 3.4.105 from 3.4.10 base, 4000+ commits. (kernel.org)
.don't limit optimization of kernel by size
.compile with GCC Google 4.8
.some changes to the way the kernel name displays
.make the ramdisk insecure
.set adb debuggable
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #89 - XDA Forums
***** 10 Dec *****
.patch upstream 3.4.100 (changelog is massive lol)
.all in one zip (thx golv, I referenced your zip)
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #64 - XDA Forums
***** 9 Dec *****
.merged updates up to and incl. 3.4.80
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #47 - XDA Forums
***** 7 Dec *****
.add NTFS RW capability
.fix for system RW
.patch to 3.4.30
.sd mount patch (santod040)
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #22 - XDA Forums
***** 6 Dec *****
.stock ramdisk
.compiled with GCC 4.8 from Google (official lollipop branch)
.patch to 3.4.14
[KERNEL][5.0.1] ★☆ Kangaroo Kernel ☆★ 6 Feb | GPE | SENSE - Post #4 - XDA Forums
.some misc tweaks
Changelog: 8 March
Changelog: 26 Feb
Changelog: 19 Feb
***** 22 Jan *****
***** 16 Jan *****
***** 22 Dec *****
***** 13 Dec *****
***** 11 Dec *****
.set adb debuggable
***** 10 Dec *****
***** 9 Dec *****
***** 7 Dec *****
.fix for system RW
.patch to 3.4.30
***** 6 Dec *****
.stock ramdisk
.patch to 3.4.14
