[Firmware][7.1.1] OxygenOS 4.1.0 [Nougat]
CerealKiller77
CerealKiller77
Stammgast
435
OxygenOS 4.1.0 mit Android 7.1.1 Nougat wird ab sofort verteilt.
Download Mirror hier:
[Mirror] Original Firmwares OxygenOS
Original Thread:
OxygenOS 4.1.0 (7.1.1) OTA for OnePlus 3T - OnePlus Forums
Here are some highlights:
  • Upgraded Android 7.1.1
  • Updated Google security patch to 1st March 2017
  • Added expanded screenshots
  • Improved picture taking of moving objects with blur reduction
  • Improved video stability when recording
  • Improved WiFi connectivity
  • Improved bluetooth connectivity
  • General bug fixes
For those who were on previous versions for OnePlus 3T, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing your continued feedback in the bug reporting forum here: Bug Reports - OnePlus Forums.
Please follow the link below for the UI/UX experience survey. We’d really appreciate a few minutes of your time, as it will help us make OxygenOS even better.
- Feedback on UI/UX: OxygenOS 4.1.0 Official Release for OP3/OP3T
As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy!
Reaktionen: TomTim und freeztyler
Wurde mir auch gerade angeboten. Habe schon gedacht das es wieder Wochen dauert bis ich drann bin, wenn es raus kommt. Geht das bei Oneplus immer sofort.?
Nein. Bei mir ist noch nichts angekommen.
Nice und gerade heute den Akku nicht am Abend geladen :D
Ich kann mich jetzt extrem irren, aber mir scheint es, als ob die Anzeige- und Schriftgröße in der Standardeinstellung reduziert wurde. Zumindest habe ich vorher beides auf Standard gehabt und das scheint mir jetzt deutlich kleiner zu sein.
Schade das OnePlus die App Shortcuts nicht mit drin hat.
Auch bei der Version funktioniert kein Sideload mehr. Über TWRP ging es aber ohne Probleme zu flashen.
Habe eben die fertige Android 7.1.1 OTA heruntergeladen und erfolgreich installiert. Ca 358 MB groß und alle "alten" Dateien und Einstellungen sind noch da.
Hier die Verbesserungen:
  • General bug fixes
außerdem hoffe ich, die sporadischen Neustarts sind nun Vergangenheit
Reaktionen: Inso und freeztyler
Einer der wichtigsten Punkte bei den Update ist
Wird aber noch etwas dauern bis ich auf die neue Wechsel, erstmal abwarten^^
Vielleicht kann einer ein paar Tests machen obs wirklich besser ist
Ich habe das eben installieren wollen, bin aber gescheitert.
Ich habe den originalen BL und original Recovery, aber systemles Root und offenen Bootloader.
Wie muss ich vorgehen?
Ich habe original und nicht gerootet - alles ungerootet und auch der Bootloader ist untouched. Ich habe über Opera VPN auf Kanada gestellt und sofort wurde mir das Update angeboten. Heruntergeladen, installiert und nach einem Neustart war alles vollbracht. Bitte in der Suchfunktion die Community bemühen.
Viel Glück - bei mir ist alles im grünen Bereich. Ist mein bisher bestes Smartphone ever - und nun mit der Android 7.1.1 Softwaremäßig auf Augenhöhe mit dem Goolge Pixel :)
Ich habe auch eben upgedatet, ganz normal und ohne Kanada etc. Schaut bisher ok aus.
Reaktionen: Muhamed und freeztyler
bis auf das, dass Screenshots direkt nach dem Knipsen noch ziemlich lange so angezeigt werden, konnte ich bisher keine Unterschiede feststellen.
@romeon
Das ist deshalb so, weil du nun direkt die Möglichkeit hast das Bild zu teilen, bearbeiten, betrachten oder zu löschen. Die Symbole erscheinen unter dem Screenshot.
Reaktionen: romeon
danke! Das hatte ich auf die Schnelle gar nicht bemerkt.
Hallo
Heute habe ich 7.1.1 erhalten u. gleich installiert. Hat einwandfrei funktioniert. Nur eines verwundert mich: Vorher hatte ich eine Speicherbelegung von ungef. 5,6 GB, nun sind es 8,6 GB. Wie kann das sein. Die heruntergeladene Datei hatte ja nur ungef. 360 MB.
Viele Grüsse
braun1951
@RyperX - Der Punkt war mir auch gleich ins Auge gesprungen. Die Bilder waren auch bei relativ gutem Licht immer recht schnell verwackelt. Gefühlt hat sich da wirklich was getan, aber das ist natürlich rein subjektiv.
Reaktionen: smartpr1v4t3
Außerdem ist dort der Button für den scrollshot (bei der Anzeige des Screenshots).
TomTim
rotkreuzhelfer
Cyclotron
Cyclotron
  • Hondabiker
schnueppi
schnueppi
