1. Möchtest Du unser Team im Android OS-Bereich unterstützen? Details dazu findest du hier!
  2. Nimm jetzt an unserem UMI Z - Gewinnspiel teil - Alle Informationen findest Du hier!
  1. planeth, 06.12.2011 #1
    planeth
    planeth Threadstarter Neuer Benutzer
    Erhaltene Danke:
    06.12.2011
    Hi
    Für alle Musiker unter euch:
    [​IMG]
    G-Stomper Drum Machine for Android (Base Tutorial) - YouTube
    G-Stomper is a highly optimized Drum Machine/Groovebox for doing electronic live performances
    Tablet optimized Layout
    11 Tracks (+ 11 Accent Tracks)
    Audio Output Format: 16bit, 44.1kHz, Stereo
    Internal Audio Format: 32bit (float), 44.1kHz, Stereo
    3 chainable Effect Processors, 1 master Effect Processor
    17 Effect Types: Compressor, Chorus/Flanger, Phaser, X-Delay, Short Delay, Reverb, Pitch Shifter, Distortion, Bender Distortion, 6 Filter types, 2 Equalizers
    Pattern Length: 1..128 steps
    Beat Types: 16th, 32th, 8th triple,16th triple
    Shuffle/Swing: 50..75
    Modulation Recording incl. Step edit support:
    … per Track:
    Accent Amount
    Sample Panorama
    Sample Volume
    Sample Start Point
    Sample Length
    Sample Pitch
    Amp Gate/Envelope
    Envelope: Linear/Exponential
    Sample Reverse
    Efx send
    … per Effect Processor:
    Parameter 1 + 2
    Tap Recording
    Step Shifting on running beat
    Fill-In function
    Live Arranger with 16 Preloaded Patterns
    Song Mode
    9 Drum Kits
    Wave Sample import
    Audio export
    Minimum recommended device specs:
    800 MHz processor
    800 * 480 screen resolution
    Give it a try (demo and full version available on android market)
    https://market.android.com/details?id=com.planeth.gstomperdemo
    [​IMG]
    [​IMG]
    Zuletzt von einem Moderator bearbeitet: 17.06.2015
Diese Seite empfehlen
