[Guide][UB][4.4.4] Dirty Unicorns
Aaskereija
Aaskereija
Inventar
5.601
WICHTIG! ICH ÜBERNEHME KEINE HAFTUNG FÜR EVENTUELLE SCHÄDEN AN EUREN GERÄTEN! NUTZUNG DER ANLEITUNG AUF EIGENE GEFAHR!
Changelogs Nightly KTU84Q:
Build 1
-- Initial Release
-- Built-in Adlocker (able to update hosts on the fly)
-- Ability to disable FC notifications
-- Enable pointer/user microphone options (screen record)
-- Download Center (Gapps, Xposed, etc)
-- Ability to force Expanded Notifications
-- Over 100 cloud based wallpapers
-- Facebook Sync Hack
-- Immersive mode
-- Hot Reboot In Power Menu
-- Appbar (app sidebar)
-- Customizable Quick Settings
-- Customizable power menu
-- Customizable lockscreen shortcuts
-- App Ops access in Settings
-- TRDS (built in theme in settings)
-- Statusbar Clock options
-- NavBar Options
-- Halo (multi-tasking tool)
-- Halo size/color changer
-- Hardware key remap mod (only for HW button devices)
-- Battery Bar / Circle batteries
-- Network speed indicators in statusbar
-- SuperSU (chainfire)
-- Build.prop mods
-- Init.d Tweaks
-- Active Display (Moto X notifications)
-- ListView Animations
-- Custom System Animations
-- Toast Animations
-- Custom BusyDialog
-- Advanced Low Battery Indicator options
-- ScreenShot QuickTrash
-- Color Changing PhaseBeam
-- Gesture Anywhere
-- Button Light Notification
-- Statusbar Color options
-- OmniSwitch (multi-tasking tool)
-- Driving Mode
-- Lockscreen theme options
-- Lockscreen notifications / options
-- System App Remover
-- Identicons
-- Suspend Actions
-- Wakelock Actions
-- SlimROM based recents
-- Contextual notification panel headers
-- SlimROMs privacy guard
-- Blacklist calls/sms
Funktioniert nicht
-- FM Radio
-- A2DP (Anrufe funktionieren)
-- Wifi direct
Falls etwas schief geht:
Sony Companion
Firmware zum flashen mit Flashtool
Downloads:
Rom: Dirty Unicorns - Build 1
GApps: Google-Stock / AOSP-Stock / Mini / Micro / Nano / Pico (Uni) / Pico
Das flashen einer Custom-Rom und eines veränderten Kernel bedeuten einen tiefen Eingriff in das System deines Xperia GO, du entfernst zwischendurch das komplette OS vom Handy, deswegen sei dir immer sicher was du tust und nutze diesen Guide erst, wenn du ihn auch verstehst und du auch verstehst was du tust. Frage lieber vorher, nicht dann wenn es zu spät ist! Sony's sind zwar in der Regel immer rettbar, doch sollte man die Gefahr eines Full-Brick immer im Hinterkopf behalten.
1. Daten sichern
Falls ihr eure Daten/Apps/Kontakte absichern wollt und dies noch nicht getan habt, empfehle ich euch die App Helium (ohne Root) oder die App Titanium Backup (Root), die speichern so ziemlich alles.
2. Flashtool vorbereiten:
Lade das Flashtool herunter und installiert es. Es sollte dann unter C:\Flashtool erscheinen. (Windows7)
Wie ihr Flashtool nutzt, lernt ihr hier: Klick*
Für das Go müsst ihr zusätzlich den Common drivers RioGrande auswählen.
Danach PC neu starten!
3. Custom-Rom vorbereiten:
Falls ihr von einer anderen Custom-Rom kommt oder nicht die aktuelle Android version (4.1.2) habt, flasht bitte vorher mit Flashtool die letzte aktuelle Stock-Rom.
Kopiert euch die Rom.zip und GApps.zip danach auf eure Interne SD und aktiviert in den Einstellungen unter Entwickler Optionen das USB-Debugging.
Kopier danach die boot.img aus der Rom.zip nach C:\Flashtool\x10flasher_lib
4. Bootloader öffnen:
*#*#7378423#*#* als Anruf eingeben, danach sollte das Service Menü auftauchen wo ihr bei Service info > Configuration > Rooting Status nachseht ob euer Bootloader auf Bootloader unlock allowed: Yes steht (Andernfalls nicht möglich!)
Für das TA-Backup benötigst du Root, (Das beeinflusst nicht den Bootloader) mithilfe des Easy Rooting-Toolkit von DooMLoRD. Eine One-Klick Methode über den PC (minimale Englischkentnisse vorrausgesetzt).
Unlock-Code von Sony zusenden lassen
TA-Backup machen.
Ab diesem Zeitpunkt sollte dein Handy zu mind. 50% geladen, USB-Debugging aktiviert und Ausgeschaltet sein!
Los Gehts!
Windows-Eingabeaufforderung (CMD) aufrufen, in dem Fenster dann cd C:\Flashtool\x10flasher_lib\ ein eingeben. Wenn kein Fehler auftaucht drückt die Lauter-Taste (Vol +) eures Handys und steckt gleichzeitig das USB-Kabel an. (Lila LED)
danach fastboot.exe -i 0x0fce getvar version eingeben um die Verbindung zu testen.
Falls nur <waiting for device> erscheint hast du wohl einen Fehler gemacht, überprüfe einfach deine Schritte beim Flashtool-Bilderguide erneut.
Jetzt fastboot.exe -i 0x0fce oem unlock 0xKEY eingeben (KEY stellt den von Sony zugesendeten Code dar) und Enter drücken.
Der Bootloader ist jetzt geöffnet!
5. Kernel & DU Installieren:
Die boot.img enthält Kernel, Recovery und Root, desshalb der wichtigste Schritt, wie ihr diese flasht, könnt ihr mit einer von beiden Anleitungen lernen:
boot.img flashen mit CMD oder Flashtool
Nachdem nun hoffentlich die boot.img erfolgreich geflasht wurde, startet euer Handy nun neu und ihr müsst beim Kernel-Logo (SONY logo) nach der verschieden Farbigen LED und einer kurzen Vibration schnell die Lauter-Taste (Vol +) drücken um in die Recovery zu kommen.
Geht in TWRP auf Wipe, dort dann auf Advanced Wipe und wählt Dalvik Cache, System, Data, Cache und Android Secure an und swiped dann den Slider nach rechts.
Danach zurück und auf Install, dort die Rom.zip auswählen und dann auf Add more zips, wählt zusätzlich die GApps aus. TWRP kann bis zu 10 zips auf einmal flashen. Beachtet aber bitte die Reihenfolge das ihr zuerst die Rom auswählt, ansonsten kann es Probleme geben.
Wenn alles geklappt hat drückt reboot system und warten bis das Phone zum Willkommen Screen bootet.
Erster Boot kann bis zu 5 Minuten dauern und ist vollkommen normal!
Viel Spass mit Dirty Unicorns!
Quellen/Credits: Sony, Flashtool,
Google Drive, Google Play,
Thx for GApps to TKruzze,
Thx to geralD_carl for making this rom
Probleme bitte melden.
Danke, Sag mal ob es was taugt
ICH RATE VON DER NUTZUNG VON GRAVITYBOX, XBLAST UND XUIMOD STRIKT AB!
Leider auch kein Leistungs menue (einstellbarer governor oder io sheduler) was ich bei CM sehr mag.
Ansich klasse stabile rom, fuer ein initial release schon mal sehr geil. Mir persoenlich nur etwas zu ueberladen, viele Funktionen (fast doppelt Soviel wie bei hellkat) die ich einfach nicht brauch, bin zu sehr minimalist.
bei mir erscheint die stock ftf nicht im Flashtool, woran kann das liegen? Die ftf ist unter Flashtool/firmware kopiert, also eigentlich vorhanden. Und die Treiber (Common RioGrande) sind auch installiert.
Bootloader ist schon offen sowie root mit Custom Rom CM11 (4.4.2).
Viele Grüße
Arisha
Dann ist die ftf fehlerhaft
Aaskereija
  • Aaskereija
Aaskereija
Aaskereija
Aaskereija
  • Aaskereija
5 6 7
Aaskereija
Aaskereija
Aaskereija
Micha68
