Hilfe - Seit Flash keine Funktion
Chrisu
Hallo Liebe Gemeinde,
wollte heute mein Spica, den LK Mode installieren, danach wollte ich den Samdroid Mode installieren hab diese Update.zip installiert, gut neustartet ( Bootlogo -> ladet bis zur Hälfte danach kommt ein Schönes Rufzeichen und eine handy Abbildung und es tut sich nichts mehr.
Jetzt probierte ich eine Original Software zu flaschen keine Chance, was kann ich noch machen?!
LÖSUNG:
For other firmware just replace JCE with the one you want.
Flash I
1. Select spica_jc3.ops into Select OPS field
2. Select I570EXXJCE.tar into Selet Integrate Package – Choose One Package Option field
3. Tick the One Package option
4. Click Start to start flashing. The timer and progress bar above COM Port Mapping field should start . If the progress bar doesn’t start but the timer continue to run , close Odin and disconnect the phone from PC. Remove and insert the battery and start the phone in download mode again, then run Odin.
5. Wait until PASS message appear in Message box and the progress bar box turns into blue.
6. At this step, you may get the flashing seems to be failed, and you’ll see exclamation mark appears like image shown below. Don’t worry, this is not the end of your spica, close the Odin and disconnect the phone from PC.
7. Remove and insert the battery, start the phone in download mode then run Odin again and follow the steps in Flash II.
Flash II
1. Keep spica_jc3.ops in Select OPS field.
2. Click Reset Files to clear the fields.
3. In Select Images to download panel
Select I570EXXJA1_CLI32638_Bootloader.tar into BOOT field
I570XXJB4_Phone.tar into PHONE field
I570EOLBJB3-CSC-CL167487-OLB.tar into CSA field, and let the PDAfield empty.
4. In Debug Option panel, tick Debug Only and PDA Format option. Don’t tick One Package option in Option Panel.
5. Click Start and watch the progress bar and timer, wait untill PASS message appear on Message box.
6. Disconect the phone from PC, remove and insert the battery, start the phone in download mode again then continue to Flash III.
Flash III
2. Click Reset Files to clean the fields.
3. In Select Images to download panel, Select I570EXXJCE.tar into PDA field.
4. If you get an error dialog, rename the I570EXXJCE.tar into I570EXXJCE_PDA.tar and insert into PDA field again.
5. Don’t select One Package option and Debug Option.
6. Click Start and watch the progress bar and timer, wait untill PASS message appear on Message box.
7. The phone will restart and you will get the Eclair screen :)
DANKE!!!!
DomKo1
  • bcj
franzm19
  • renoir
chris1234
