  1. totofroto, 16.07.2011 #1
    totofroto
    totofroto Threadstarter Neuer Benutzer
    Erhaltene Danke:
    16.07.2011
    hi
    i am using HyperDroid-CM7-v2.1.0[a2sd+][CyanogenMod7 LEO 2.3.4][Tytung_R10]
    i have installed the recommended radio, magldr.
    all things ok except........ when i use messenger as skype or yahoo , after that any incoming call (normal call) the device will stuck and doese not react till i remove battery.
    please help me:confused:
Diese Seite empfehlen
