  1. idova, 20.10.2011 #1
    idova
    idova Threadstarter Neuer Benutzer
    Hallo Leute!
    Ich habe das Problem, das bei dieser Anwendung nach der Installation auf Handy oder Simulator/Emulator
    das Icon für diese App mehrfach auftaucht. Genauer: für jede Klasse!?
    Aber wieso?:sad:
    Code:
    package de.rhapp;
    import android.app.Activity;
    import android.content.Intent;
    import android.os.Bundle;
    import android.widget.Button;
    import android.view.View;
    public class RHAppActivity extends Activity
    /** Called when the activity is first created. */
        @Override
        protected void onCreate(Bundle savedInstanceState)
         super.onCreate(savedInstanceState);
         setContentView(R.layout.main);
       /////////// button 1 AllesZumTraning
        final Button allgTraining = (Button) findViewById(R.id.button1);
        allgTraining.setOnClickListener(new View.OnClickListener()
             public void onClick(View view)
                 Intent myIntent = new Intent(view.getContext(),AllesZumTraning.class);
                startActivity(myIntent);
         }); //setOnClickListener
        /////////// button 2 Fragen an den Einstazleiter
        final Button FragenAnEL = (Button) findViewById(R.id.button2);
        FragenAnEL.setOnClickListener(new View.OnClickListener()
                 Intent myIntent = new Intent(view.getContext(),FragenAnEL.class);
     } //onCreate(Bundle savedInstanceState)
    }//RHAppActivity extends Activity
    File: AllesZumTraning.java
    package de.rhapp;
    public class AllesZumTraning extends Activity
        @Override
           setContentView(R.layout.allgekines_training);
    File: FragenAnEL.java
    package de.rhapp;
    public class FragenAnEL extends Activity
        @Override
           setContentView(R.layout.fragen_an_el);
        final Button FragenAnELT = (Button) findViewById(R.id.button1);
        FragenAnELT.setOnClickListener(new View.OnClickListener()
                 Intent myIntent = new Intent(view.getContext(),FragenAnELT.class);
        final Button FragenAnELF = (Button) findViewById(R.id.button2);
        FragenAnELF.setOnClickListener(new View.OnClickListener()
                 Intent myIntent = new Intent(view.getContext(),FragenAnELF.class);
    File:  FragenAnELF.java
    package de.rhapp;
    public class FragenAnELF extends Activity
        @Override
           setContentView(R.layout.fragen_an_el_f);
    File:  FragenAnELT.java
    package de.rhapp;
    public class FragenAnELT extends Activity
        @Override
           setContentView(R.layout.fragen_an_el_t);
    File: AndroidManifest.xml
    <?xml version="1.0" encoding="utf-8"?>
    <manifest xmlns:android="http://schemas.android.com/apk/res/android"
          package="de.rhapp"
          android:versionCode="1"
          android:versionName="1.0">
        <uses-sdk android:minSdkVersion="9" />
        <application android:icon="@drawable/icon" android:label="@string/app_name">
            <activity android:name=".RHAppActivity"
                <intent-filter>
                    <action android:name="android.intent.action.MAIN" />
                    <category android:name="android.intent.category.LAUNCHER" />
                </intent-filter>
            </activity>
            <activity android:name=".AllesZumTraning"
                      android:label="Frage1">
                <intent-filter>
                </intent-filter>
            </activity>
              <activity android:name=".FragenAnEL"
                <intent-filter>
                </intent-filter>
            </activity>
               <activity android:name="FragenAnELT"
                <intent-filter>
                </intent-filter>
            </activity>
               <activity android:name="FragenAnELF"
                <intent-filter>
                </intent-filter>
            </activity>
        </application>
        <supports-screens android:anyDensity="true" />
    </manifest>
  2. ko5tik, 20.10.2011 #2
    ko5tik
    ko5tik Android-Experte
    Launcher zeight die Aktivities mit:
    Code:
                <intent-filter>                 <action android:name="android.intent.action.MAIN" />                 <category android:name="android.intent.category.LAUNCHER" />             </intent-filter>
    An - also macht es alles richtig. Nehme diese Filter weg, dan verschwinden die
  3. Blalasaadri2, 20.10.2011 #3
    Blalasaadri2
    Blalasaadri2 Android-Hilfe.de Mitglied
    Warum hast du in der AndroidManifest.xml für jede Activity einen intent-filter? Und zwar immer den Gleichen? Wenn du (außer bei der Activity, die zuerst starten soll) die Zeilen
    Code:
                <intent-filter>
                </intent-filter>
    entfernst sollte es glaube ich funktionieren.
    Gruß,
    Blalasaadri
  4. idova, 20.10.2011 #4
    idova
    Vielen Dank!!
    Ich ahnte es... das es so was sein muss... ich muss mir das mal anlesen...
    :laugh::)
  5. swordi, 20.10.2011 #5
    swordi
    swordi Gewerbliches Mitglied
    genau das passiert, wenn man code kopiert, ohne zu wissen was er tut :)
