[Kernel][CM13/14.x/OOS] Boeffla Kernel
Mcenzie
Mcenzie
Stammgast
398
Hinweis: Weder Android-Hilfe noch Oneplus oder ich übernehmen eine Garantie oder jegliche Haftung bei Beschädigung eurer Smartphones!
Download :
- Current Kernel Versions - Lord Boeffla
- Boeffla-Config App - Lord Boeffla
___________________________________________________________________________________________________________
Installation :
- Herunterladen der korrekten Kernel Version entsprechend des Systems (OOS/CM) und der Boeffla Config App
- Flashen des Kernels im TWRP
- Reboot
- Installation der Boeffla Config App
- Update der Kernel-Version : Einfach über den bisherige Kernel im TWRP flashen
Features CM :
  • Support of anykernel concept (only latest kernels) - flash stock kernel before flashing Boeffla
  • Full integration with Boeffla-Config V2 (you need at least version 2.4.02 or higher !!!) configuration app (get it from http://www.boeffla.de) to configure all kernel settings
  • Dash charging fully supported
  • The two CPU clusters (big and little cpu) can be configured completely separate in terms of min/max frequencies, governors and CPU core profiles
  • Additional governors: Impulse, zzmoove, elementalx, conservative, ondemand
  • Additional schedulers: fiops, sio, sioplus, fifo, vr, tripndroid and zen
  • CPU overclocking - one additional overclocking step for both clusters (1,72 GHz for little CPU / 2,26 GHz for big CPU)
  • No GPU overclocking, no CPU and GPU voltage interface
  • CPU core profiles to restrict number of CPU cores being used (the OP3 does not hotplug based on load)
  • Boeffla-Sound engine: Headphone volume and speaker volume (only lowering volumes for speaker)
  • Dynamic FSync (activated if screen on, deactived if screen off), configurable
  • Input boost frequencies and duration configurable per CPU cluster, input boost switch
  • Show CPU frequency usage per CPU and frequency in Boeffla-Config
  • Show GPU frequency usage per frequency in Boeffla-Config
  • KCal V2 Color control (not yet fully compatible to msm8996, expect side effects)
  • Swipe2wake gestures
  • Swipe2sleep gestures
  • SD card read ahead buffer configurable (default increased to 1024 kB)
  • Ext4 File system tweaks (default to on, can be disabled)
  • Kernel logger (dmesg) configurable
  • CIFS support (module, do not mount inside /data, if you rooted with Chainfire SuperSu, make sure you uncheck the namespace separation in SuperSu app)
  • NFS support (module)
  • NTFS support (module)
  • XBox support (module)
  • OTG-Ethernet support (module)
  • TCP Congestion changed to Westwood
  • Many additional TCP congestion algorithms available
  • Entropy values configurable
  • Hardware touch keys are locked as long as screen is in use (touched) for better usability
  • Swap supported
  • Various minor kernel tweaks
  • Doze mode configurable in Boeffla-Config
  • Full selinux strict support (switchable to permissive on demand)
  • Show speedbin information (PVS level) in Boeffla-Config app
  • init.d support (in /system/etc/init.d - set correct permissions!)
  • Automatic EFS backup
  • Integrated full busybox 1.24.2 (own compilation)
  • Kernel initialisation log file (with history of 3 log files)
  • Emergency reset script automatically placed into /boeffla-kernel-data folder of your internal memory
  • Google gcc 4.9 toolchain (64 bit) used for best stability
Features OOS :
  • Additional schedulers: fiops, bfq, sio, sioplus, fifo, vr, tripndroid and zen
  • Notification LED control (effect + speed for blinking/fading, brightness for continuous notification like battery charging etc.)
  • Control haptic feedback of gestures (except fingerprint)
  • Haptic feedback intensity control
  • Swap supported
  • Always based on latest OOS kernel sources (https://github.com/OnePlusOSS/androi...neplus_msm8996)
Links :
- XDA CM13/14.x : [KERNEL] [OnePlus3] [CM14/CM13] Boeffla-Kernel (05-12-2016)
- XDA OOS : [KERNEL] [OnePlus3] [OOS] Boeffla-Kernel (01-12-2016)
- Boeffla : Boeffla-Kernel - Lord Boeffla
Reaktionen: sph3re, tenzin, Elektro und 3 andere
Danke für die Mühe :)
Reaktionen: Mcenzie
Gern geschehen ;)
Mal sehen, evtl probiere ich den Kernel morgen mal aus. Habe bis jetzt immer den CM-Stock Kernel genutzt.
Reaktionen: datt-bo und bmwpowerf11
Moin :)
Wenn ich den Boeffla Kernel drauf habe und ich eine Nightly flash ,dann ist er doch wieder weg ?
Oder muss ich vorher noch was machen ?
Cache oder so leeren ?
Danke für eine Antwort
Ja dann is er wieder weg.
Also neue nightly flashen und dann nochmal den kernel... Ob da ein reboot dazwischen muss weiß ich ned...
Reaktionen: datt-bo
Nö ,muss da nicht. einfach raufkloppen das Ding.
Support gibts übrigens nur in der XDA Gruppe bzw den dortigen Thread.
Reaktionen: Elektro und datt-bo
Nicht nur bei XDA......
Aber überwiegend. Bei Twitter gibts nix, anschreiben lohnt nicht. Ab und and mal ne kurze Twitterunterhaltung mit Ihm. Netter Kerl.
besten Support erhält man von Andi im Hubo Forum.
Reaktionen: tenzin und MisterRoot
So, erste Beta für OOS 4 ist jetzt draußen.
rotation
rotation
rotation
HeartOfDarkness
  • HeartOfDarkness
ocp11
O
Mcenzie
  • Mcenzie
scara2
scara2
