Mayday
Enthusiast
- 997
*And get a thermonuclear reactor in your device for free ! (AAA batteries sold separately)
Overview & features :
Don't go crazy with overclocking, only the best devices will be able to get 2.3 GHz stable or even bootable, though heat will be your main issue.
The benchmark results in the banner were obtained with "only" 1.94GHz CPU, 627MHz GPU, and "Extreme" L2/cache OC, running on stock 4.4.2 rom.
- Based on Google AOSP 3.4.0 kernel source for MSM devices updated to linux 3.4.79
- Modifications based on CyanogenMod CAF source to make AOSP base compatible with official CyanogenMod 11 and others CAF based roms
- CPU OC up to 2.3Ghz with OV/UV support
- L2/bus speed OC up to 1.49GHz / 4.96GBPS
- GPU OC up to 627 MHz with OV/UV support
- CPU governors : Faux's intellidemand, interactive, ondemand (default), smartmax, conservative
- I/O schedulers: noop, deadline, row (default), cfq, fiops, sio
- Kernel based thermal control by crpalmer and flar2
- Kernel based msm_mpdecision hotplug driver by Showp1984
- Kernel based Intelli-plug hotplug driver by Faux123
- Kernel based Input-Boost by Showp1984
- tni.andro's battery life extender support
- Latest Sweep2wake/Sweep2sleep/Doubletap2wake from flar2
- Magnetic on/off setting
- SLIMbus OC by ZeroInfinity and Poondog
- FauxSound support
- Panel color and gamma tweaking by Faux123
- Dynamic Fsync by Faux123
- USB fast charging support
- USB OTG charge hack support by flar2
- Kernel-based NEON support
- UKSM support
- Optimized algorithms and libraries
- Various performance and power saving tweaks
- NTFS and exFAT support
- Kexec-hardboot support
- Touchscreen patches from Showp1984
- Aroma installer to set core features at flash time (L2 OC level, CPU OC, GPU governor etc.)
- Compiled with SaberMod 4.8.3 toolchain using -O3 optimizations
Downloads (all kernels are compatible with both flo and deb)
Your rom is stock or AOSP based :
- Glitch kernel for AOSP based roms
Your rom is official CyanogenMod/CAF based :
- Glitch kernel for CM/CAF based roms
Mirror : Dev-Host- Glitch kernel for CM/CAF based roms
Tools/Misc :
- Patch to make AOSP/stock 4.4.x kernels compatible with AOSP/stock 4.3.x roms
- Patch to make AOSP/stock 4.3.x kernels compatible with AOSP/stock 4.4.x roms
Um alle Funktionen nutzen zu können, wird TricksterMod, oder FauxClock benötigt.
https://play.google.com/store/apps/details?id=com.bigeyes0x0.trickstermod&hl=de
https://play.google.com/store/apps/details?id=com.teamkang.fauxclock&hl=de
Changelog
08/02/2014 - r140.1 :
- Fix the updater script and configuration generation to fix missing files errors when some settings aren't selected. Also, set a fallback to Qualcomm MPDEC hotplug when nothing was configured.
07/02/2014 - r140 :
- Update to Linux 3.4.79
- Switch to XZ compression
- Add kernel mode NEON support as well as NEON accelerated AES & XOR implementations
- Fix CPU load miscalculation
- jbd2 and ext4 optimizations
- Add max screen off frequency support - Thanks to Flar2 (if disabled in Aroma, changing frequency in apps won't have any effect)
- Add UKSM 0.1.2.2 support
- Add dynamic management of dirty page writebacks
- Enable Wiimote HID support
- Enable USB printer support
- Bugfixes
Aroma installer overhaul :
- Reworked installation process to be clearer and more customizable
- Added an automatic backup of your settings to the root of your internal SDcard
- Added a restoration mode to get your settings from internal SDcard backup back on any rom (cross-compatible with Glitch kernel variants)
- Renamed /system/etc/settings.conf to glitch-settings.conf to make it more obviously glitchy
- Removed the need to set CPU OC, L2/cache OC and auto-uV again when keeping previous settings (now reading it from your settings at flash time. Note : editing this part in /system/etc/glitch-settings.conf requires a reflash using the "already glitched" option)
- Added Qualcomm optimized Dalvik/Bionic libraries into the installer (bionic only on CM variant) so you can install/restore them with the kernel
- Added I/O scheduler, CPU governor, read-ahead buffer size, fast charge, max screen off frequency and maximum multi-core power savings to available settings
- Fixed how the min CPU clock is applied to make it more robust and work better with governors
- Fixed how the min CPU freq uV is applied to make it work independently of the min freq (by subtracting the uV amount to the original voltage instead of forcing plain values) - Also, make it capable of setting uV for all freqs for future use.
- Changed the auto-uV menu to reflect the internal changes
- Fixed some permissions issues
- Added hotplug driver check so it's possible to restore it as well from settings without interference
- Change theme
Link zum Original XDA-Thread.
[KERNEL][OCT 8]Glitch kernel for Flo - CPU OC/UV 2.3GHz - GPU OC 627MHz - S2W/S2S - SM toolchain - xda-developers
