Gast5050
Gast
[KERNEL-ICS] Air Kernel
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Kernel-Infos:
Air Kernel Kernel für ICS
Funktionsumfang:
zur Zeit erst mal auf Englisch:
- Patched to latest in Linux 3.0.x branch: 3.0.36.
- All unnecessary kernel components removed to make kernel lean and fast!
- OC to 1.65ghz. Boot speed is maxed at 1.2ghz within kernel (in addition to ramdisk) for stability.
- User voltage control
- InteractiveX V2 (screen-off hotplug of cpu1) added. Select it using setcpu if you want to use it.
- Ramdisk tweaks (sysctl, vm, filesystem speed, etc.)
- SWAP & zram (next generation compcache) support. Run "zram enable" in terminal.
- init.d support in ramdisk.
- lk.conf for basic kernel configuration.
- HotplugX governor (Hotplug optimized and modified for screen-off suspend).
- wakelock tweaks for wlan and lte modem
- lkflash - script to flash latest versions of leanKernel from Terminal (type "su" without quotes, hit enter, then type "lkflash" without quotes and then hit enter)
- checkv - voltage checking script (for custom undervolting) - detailed at bottom of this post.
- checkt - script that displays 1) your current temp, 2) # of times you were throttled due to temp "recently", 3) CPU trim type, and 4) CPU silicon type, etc. (sample output)
- Fast USB charge (by chad0982) and "ffc" toggle script by me. (Open terminal, and type "ffc" without quotes then enter)
- ColorControl from both CM9 and Ezekeel (compatible with all ROMs). Helpful posts: 1and 2.
- TempControl - sysfs interface to control the CPU temp threshold. Read these two posts: 1 and 2.
- Variable GPU OC - sysfs interface to select GPU max speed between 307MHz (stock), 384MHz and 512Mhz. The changes take effect immediately. Check FAQ for more info and how to use it.
- Custom SR Tuning - override kernel default minimum voltage for SR calibration. More info here and here. V2
- SoundControl
- Gamma Control
Flash-Anleitung:
Installation:
1. Neustart ins Recovery
2. Kernel flashen
6. Neustart
Downloads:
Download: http://air.sloud.kr/2012/07/air-kernel-weekly-build-for-gn.htmlICS-Weekly
Download: ICS-Stable
Changlog:
07.07.2012
v2.1 (06-27-2012 KST / GMT +9:00)
-Added 'PegasusQ' governor (Galaxy S3)
-Adjusted MPU(CPU) Clocks and Voltages
(200Mhz->230Mhz, 725.6Mhz->729.6Mhz, 1024Mhz->1064.4Mhz, 1.224Ghz->1.228Ghz, 1.544Ghz->1.52Ghz)
-Added evdev patch
-Cpufreq_pegasusq.c: Increase MIN_SAMPLING_RATE value 10000 to 20000
-Cpufreq_interactive.c: Tund interactive governor
-Fixed reboot and freezing issue (maybe)
Support auf Englisch:
Für englischsprachigen Support empfehle ich die Threads bei unseren Kollegen von XDA.
Thread-Changelog:
08.07.2012
- Thread erstellt
