[KERNEL][Samsung]SaberKernel_45.3(3.0.97)(UC-100mhz)(OC-1920mhz)(exFAT)[10/03]
perog
perog
Stammgast
690
WICHTIGER HINWEIS:
Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg oder die Haftung für jegliche Beschädigungen an eurem Note 2.
Wenn ihr nicht sicher seid, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Daher flashen auf eigene Gefahr.
SaberKernel 7100
This Kernel Is Compatible with all TW/Samsung based JB ROMS for this device--- (Not AOSP)
READ, READ, READ before downloading, flashing, or posting questions
Not all phones are created equal meaning some phones will not handle Overclocking or Undervolting as well as others.
Features
Kernel Version 3.0.96
UC to 100
OC to 1960
UV Support
Added Support For 3rd Party OC apps---
Advanced Power Emulation
Default Scheduler= Zen
Default Governor= Pegasusq
Default boot set to 1600
Built using arm 4.4.3 toolchain
Ramdisk Mods to support Custom Boot Animations
Boeffla Sound Support
Touchwake
GPU Control​
Github
In my GITHUB you can find my sources and code changes​
Credits
Samsung for Official Source Code
Andreilux
Faux123
Cmenard
Simone 201
Gregkh
Sarcastillo
supercurio
Der Teufel
Ezeekel
ZaneZam
Yank​
Instructions
TWRP Recovery HIGHLY Recommended!
-Download Kernel
-Nandroid
-Flash Kernel
-Boot system and Feel The Force​
Changelog
10|03
Upgrade to Linux 3.0.97
Revert of GPU edits to fix glitches in Graphics/reboots
Raise Voltages on 1960 for stability
Update zram_drv.c … thanks to insanemal
9|26
Raised Max Clock Speed --1960
Edits to GPU Clocks and scaling for Max performance (while preserving battery at stock values)
New compression ADB Remount Enabled
9|18
Complete Rebuild from Updated Source
Zen default sched
Upgraded to 3.0.96
Fixed GPU freq scaling More voodoo code removal
9|11
Upgrade to Linux Version 3.0.95
Edits to GPU Voltage Allocation
Boeffla Sound Replaces Voodoo (by request)
Boeffla and Trickster apps now added with flash
Clean Up of Version
Remove Dirty in Version Description
USB Charging Rate Increased to match A/C rate
ZZmoove Updated to 7d
Fixed Memory/cache leak that was causing instability and poor battery​
8|28
I have been slacking on releasing kernels outside of my ROMs so this changelog is kind of a mess.
If you cannot follow the log please see my git for itemized changes
--Upraded to Linux 3.0.93
-- Added in exfat module source thanks to Faux123 and SORC
-- ZZMOOVE updated to v0.7 (ZaneZam/Yank)
-- LulzactiveQ added in (Gohkanmoral)
-- Upgraded to Linux 3.0.91
-- Wifi driver edit for reduce wakelock
-- All sources Merged!!
-- Upgraded to Linux 3.0.87
-- Added ZZMOOVE
---- zzmoove edited to support more frequencies
-- Edits to WIFI handling for less wakelock issues/performance
-- Some Peg gov Edits
-- Edit to I/O que
-- Edits to kernel/module.c in hopes of further work on exfat later on​
7|2 --
Upgraded to Linux Version 3.0.84
New Under Clock Frequency --STABALIZED
- 100 mhz UC all set
---All testers have reported back as things being stable and most
have run it through intensive and reg use and no SOD at 100mhz low.
I believe the times of certain devices not liking the low step is over. Have Fun​
6|24 --
Upgraded to Linux Version 3.0.83
2 Versions
--- One with UC for those who's chips dont mind
---One Stock Low end
New Under Clock Frequencies
- 120 mhz UC VERSION ONLY
Edits to Peg GOV in Both Versions​
6|19 --
Upgraded to Linux Version 3.0.82
- 160 mhz
- 140 mhz​
6|13 --
Complete Clean Rebuild from updated sources
Linux 3.0.81
ZRAM
Freq Voltage Edits
Compression Edits
Freq "Bleeding" fixed
Intelliplug/Ecomode
More Mali Edits
Dynamic Filesync​
5|05 --
Upgraded to Linux Version 3.0.76
GPU Handling is Back And Fixed
Touchscreeen Mods
TouchBoost Control Added
SetLocalversion Modification ( Just Shows differently in about)
More...​
4|26 --
Upgraded to Linux Version 3.0.75
TouchWake Added (Control With TricksterMod)
Voltages/Voltage interface Fixed for Undervolting Compatibility
FlexRate Edits
Fsync Edits
IntelliPlug​
4|18 --
Upgraded to Linux Version 3.0.74
Edits to Freq/Voltage Handling​
4|11 --
Upgraded to Linux Version 3.0.72
sysfys-helpers edit
double flexrate
Voltage control/UV voltage edits
Freq Edits​
3|20 --
Upgraded to Linux Version 3.0.69
Etc​
3|11 --
Voodo Sound Enabled
Upgraded to Linux Version 3.0.68​
2|22 --
MHL Tv Out Audio Officially Fixed Damnit lol
Updated to Linux 3.0.64​
2|15 --
Edit Frequencies
-OC to 1920
-Fix for CPU sticking Etc
-Removed GPU Edits From Last Version For Now​
2|6 --
Mali Rework
GPU Can Now Be Adjusted By 3rd Party App
Ramdisk Modifications
- Fixed Memory Swap
- Probable MHL Audio Fix
Edit to Module.c
Added Lazy Governor
Added BFQv5 Sched
Added V(R) Sched
Set ReadAhead to 1024
Fixed Wonky Frequencies: No Issues With 3rd Party Apps Holding Freq​
2|4 --
3.0.59 Revised
3.0.60
3.0.61
1900mhz OC!
Voltage Optimization
Edits to mali/gpu
Increased Charging Rate​
2|1 --
Linux 3.0.59
Deadline Edit
Edits to sched.c
Multiple Updates from Samsung OSRC​
1|28 --
Updated 27 Kernel Versions to Linux Kernel Version 3.0.58
-(ALOOOTTT of code updates)
Update to device sensors​
1|21-- Initial Public Release​
Note To Donators!
Every donation is more than appreciated! To show my appreciation for my
supporters, I will now begin listing every Donator in the OP as a special
thank you.​
THANK YOU​
yoojin1081​
Special Thanks To The Following Supporters Of This Kernel
**Webleeper
** TheContinental​
Downloads
How Do I Use TouchWake?
*** Grab TricksterMod From Below. Enable TouchWake and Set Delay To 0 ( You can now wake your phone without power button)​
Support this Development By clicking this Button,,, Thank you
--TMobTim
XDA:DevDB Information
|KERNEL| SaberKernel_45.3 || 3.0.97 || UC-100mhz || OC-1960mhz || exFAT | 10|03, a Kernel for the Samsung Galaxy Note II
Contributors
ptmr3
Kernel Special Features:
Version Information
Status: Stable
Created 2013-09-12
Last Updated 2013-10-03​
Reaktionen: skysat, Cpt. Future, Woschdi und eine weitere Person
Schon jemand erfahrung mit dem Kernel?
Da ich ihn vom "ersten Moment" an drauf habe, kann ich sagen, dass ich etwas Erfahrung mit dem Saber habe. :rolleyes2:
Fakt ist, er hat bei mir den Perseus - in seiner jetzigen aktuellen Version - abgelöst. Sehr schnell, Akku-Verbrauch hält sich im "Normalrahmen". Also keine sonderlichen Auswüchse nach oben oder unten.
LG
Andreas
Reaktionen: perog und Xrunner
Ich nutze den Saber auch schon seit paar Tagen. Bis jetzt keine Probleme. Schön schnell, stabil und Akkuverbrauch ist auch gut. Bin gespannt wie er sich weiter entwickelt.
LG
Update auf 23.5
Startseite aktualisiert
CHANGELOG
5|08 -- Upgraded to Linux Version 3.0.77
Config edits
LG
Reaktionen: Xrunner
Hab den Saber (Rom Dual N@te) jetzt paar Tage drauf, läuft bis jetzt sehr Stabil und Akkufreundlich . Auch die Performance fühlt sich sehr gut an ( die Akkuwerte sind mit 1800 MHz OC) . An Touchwake gewöhnt man sich sehr schnell :D kann jetzt schon nicht mehr ohne
Gesendet von meinem GT-N7100 mit Tapatalk 2
Update auf Saber_25
Changelog:
5|31--
3.0.80
Mali edits
GPU interface
GPU scaling now available and functional. Use trickster.
LG
Andreas
Reaktionen: perog
Hier ist noch der Dl-Link.
http://d-h.st/2sG
Schade, leider nicht AOSP-ROMs.
@smooth 123
Bringen die 200 Mhz gefühlt mehr Geschwindigkeit ?
PS: Merke bei 1800 Mhz keine Unterschiede.
Reaktionen: perog
Danke Andreas und Mayday:smile:
Startpost aktuell
LG
Reaktionen: Mayday
Sehr gerne. :D
Irgendwie funktioniert der DL-Link nicht so richtig.
Nur als Angebot...hier ist noch Einer: Download all Versions
Ansonsten uploade ich gerade noch den Kernel-Changer.
LG
Andreas
Reaktionen: perog
@ Mayday
Im normalen Betrieb eher nicht :D wenn aber sehr viele Anwendungen laufen hat ist es schon geschmeidiger oder bei Gameloft Spielen die halt Power brauchen kann aber auch Placebo sein:D
Bei Downlaods und Hompages mit viel Bildern und schnick schnack merkt man es schon spürbar an den Ladezeiten!
Auch bei Benchmarks wie Quadrant usw merkt man schon unterschiede!
Reaktionen: Mayday
Und mit wieviel mV läuft Dein N2 bei 1800Mhz?
@als Thor Fan bin ich zum Saber-Kernel gewechselt weil ich sehr neugierig war und war mit dem 23.5 schon mal sehr zufrieden. Der 25 hat sich doch etwas geändert und läuft sehr geschmeidig und baut recht zügig die Webseiten auf und spielt auch Videos sauber ab. Also seit dem 23.5 verzücke ich mein Note 2 mit dem Saber-Kernel und bin echt Glücklich und hoffe, dass es so weiter geht mit dem Saber-Kernel.
Was wünschenswert wäre, wäre die Kompatibilität mit Triangel-Away, sodass man direkt aus der Triangel-Away App den Counter resetten kann ohne Reboot des Fons. Sonst sage ich mal Klasse " Arbeit" vom Dev und wirklich gute Abstimmung mit den Kernen in bezug auf Leistung und Stabilität:cool2:
Update Linux 3.0.84
Reaktionen: depetti73 und perog
Danke dir smooth123
Startseite aktuell
LG
Wie läuft der Kernel im Vergleich zum Adam?
@ der Saber 25 läuft super und zum Adam wirklich exakter in den Reaktionszeiten und Ladezeiten.
@ .i saw 32 have a little lag and drains too much battery
Kann das sein ist der 32.2 nur 5.15 mb groß??der 25 er war noch 6.49 mb groß nicht das ich was falsches flashe:D
Passt so smooth 123. Ist bei mir auch 5.14mb groß der 32.2.
LG
redbull1
redbull1
redbull1
perog
perog
perog
DirtyKlot
xX-BaTTle1987-Xx
X
