KERNEL] uv/oc 2.6.32 for Sense Roms (CFQ/UV950mV/OC1113Mhz/EXT4/Audiomod/CIFS+utf8)
Gast5050
Gast
  • Kernel 2.6.32 (Overclocked & Undervolted)
  • Read ahead 128Kb
  • Max 1113Mhz (for now)
  • minimum voltage@950mV
  • maximum voltage@1300mV
  • BFS (Brain F*ck Scheduler).
  • CFQ Scheduler
  • Pershoot's audiomod (loudness).
  • EXT4
  • tun.ko module
  • CIFS (+utf8)
  • NFS
Current acpu table:
Code:
struct clkctl_acpu_speed acpu_freq_tbl[] = {
{ 19200, CCTL(CLK_TCXO, 1), SRC_RAW, 0, 0, 950, 14000 },
{ 128000, CCTL(CLK_TCXO, 1), SRC_AXI, 0, 0, 950, 14000 },
{ 245000, CCTL(CLK_MODEM_PLL, 1), SRC_RAW, 0, 0, 950, 29000 },
/* Work arround for acpu resume hung, GPLL is turn off by arm9 */
/*{ 256000, CCTL(CLK_GLOBAL_PLL, 3), SRC_RAW, 0, 0, 1050, 29000 },*/
{ 384000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0A, 0, 975, 58000 },
{ 422400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0B, 0, 975, 117000 },
{ 460800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0C, 0, 1000, 117000 },
{ 499200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0D, 0, 1025, 117000 },
{ 537600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0E, 0, 1025, 117000 },
{ 576000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0F, 0, 1050, 117000 },
{ 614400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x10, 0, 1075, 117000 },
{ 652800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x11, 0, 1100, 117000 },
{ 691200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x12, 0, 1125, 117000 },
{ 729600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x13, 0, 1150, 117000 },
{ 768000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x14, 0, 1175, 128000 },
{ 806400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x15, 0, 1200, 128000 },
{ 844800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x16, 0, 1200, 128000 },
{ 883200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x17, 0, 1225, 128000 },
{ 921600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x18, 0, 1225, 128000 },
{ 960000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x19, 0, 1250, 128000 },
{ 998400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1A, 0, 1250, 128000 },
{ 1036800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1B, 0, 1275, 128000 },
{ 1075200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1C, 0, 1275, 128000 },
{ 1113600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1D, 0, 1300, 128000 },
{ 0 },
Personal github: http://github.com/richardtrip/bravo-2.6.32
Pershoot github (audiomod): http://github.com/pershoot/
Original HTC kernel: http://member.america.htc.com/downlo...d96f2c0.tar.gz
Only use this if you have a Sense ROM (no defrost/cyanogenmod/AOSPDesire/opendesire/)
Download:
Froyo Kernel V5f_HAVS@925mV min
Froyo Kernel V5f_HAVS@875mV min
Froyo Kernel V5f 1190Mhz max
Froyo Kernel V5f 1113Mhz max
No Audiomod versions:
Froyo Kernel V5f_HAVS@925mV min No Audiomod version
Froyo Kernel V5f_HAVS@875mV min No Audiomod version
Froyo Kernel V5f 1190Mhz max No Audiomod version
Froyo Kernel V5f 1113Mhz max No Audiomod version
Older kernels:
Froyo Kernel V5e_HAVS@925mV min
Froyo Kernel V5e_HAVS@875mV min
Froyo Kernel V5e 1190Mhz max
Froyo Kernel V5e 1113Mhz max
Froyo Kernel V5e_HAVS@925mV min No Audiomod version
Froyo Kernel V5e_HAVS@875mV min No Audiomod version
Froyo Kernel V5e 1190Mhz max No Audiomod version
Froyo Kernel V5e 1113Mhz max No Audiomod version
WiFi N-mode module:
WiFi N-mode V5 module
WiFi PM FAST module: WiFi PM Fast V5 module
Older version you can find here:
http://xda.richardtrip.org/kernels/Sense_kernels/
Flash with recovery or ROM Manager.
Changelog:
V5f:
  • Add BFS (Brain F*CK Scheduler).
V5e SVS + HAVS kernels audiomod & noaudiomod version :) :
  • Modded gpu driver (Thanks to snq-)
V5d HAVS kernels:
  • Changed the avs table to scale less on the higher frequencies. Could be more stable if you have problems on the V5c havs kernels.
V5c HAVS kernels:
  • HAVS 1113Mhz@925mV minimum
  • HAVS 1113Mhz@875mV minimum
V5b Test havs kernel
V5a 1190Mhz kernel (smartass governor is in but not default).
V5a (Smartass only):
  • changed default_ramp_up_step and max_ramp_down to 384000
  • set smartass as default governor
V5:
  • Add lzma compression for kernel images backported by snq-
  • Read ahead to 128Kb
V4:
  • Higher voltages (more stable, some phones had reboot problems)
V3:
WiFi PM FAST module posted (nmode also) (see this thread)
V3:
  • Added interactive scheduler
V2:
  • disabled debugging options
  • fixed ext2/3
  • added Performance and Conservative scheduler
Quelle:
[KERNEL] uv/oc 2.6.32 for Sense Roms (CFQ/UV950mV/OC1113Mhz/EXT4/Audiomod/CIFS+utf8) - xda-developers
Reaktionen: actionjackson4k, wanschi und dj-darkside
Kann/Soll/Darf ich das über das flashen und was hab ich bzw. mein Desire davon? Bin nicht sooo dick drin in der Materie.
Danke! :)
Ja, funzt damit.
Wie es oben steht nur mit Sense Roms.:cool2:
nur zur sicherheit (ich glaube/hoffe schon :D ) geht das mit dem MoDaCo R8 Roms auch?
Da die MoDaCo Sense enthalten, sollte es da auch funktionieren. Es sei denn, man hat Sense/Rosie in der Kitchen rausgenommen.
Steht ja auch im Start Post , Getestet unter LeeDroid 2.1 und Modaco R9
Sollte demnach unter R8 auch laufen :)
xD das hab ich voll überlesen das es im eröffnungspost steht... sry. aber thx für die antwort!
Ich glaube das spielt keine Rolle, ob Rosi raus ist oder nicht, es ist im Grunde ja immernoch ein HTC lastiges Rom.:)
Sense ist ja nur die Oberfläche, es geht meiner Meinung nach um den HTC Kernel. Ich werds mal probieren, so zum Spaß.:D
bei mir ging danach wlan nicht mehr ..
Kann ich für mich nicht bestätigen, bei mir funzt WLan sowie auch Mobiles Inet.
so ein schmu .. gestern nacht ist bei mir alles schief gelaufen was gehn konnte :D
hab via rom manager geflasht u automatisiert vorher das backup.
da iwie zu wenig platz frei war hat er nen halbes back up gemacht...
vorm flashen hatte ich wlan ein, vllt war dass das problem.
nach dem einspielen des backups hing mein desire im splashscreen, musste ein ein wochen altes backup einspielen :mad2::scared:
hab nun alles wieder eingerichtet platz gemacht nochmal nen nandroid backup u vorher wlan aus, nun klappt alles.. :)
keine ahnung was schief gelaufen is :D
Wlan, Bluetooth und Mobiles Internet 0 Probleme. Akkulaufzeit bis jetzt gleichbleibend
Wie ist denn die geschwindigkeit vor allem beim app drawer? Ruckelt der noch?
benutze launcherpro ..
Jaja der ROM-Manager :(
Flashe lieber direkt im Recovery, dann siehst Du wenigstens, ob alles so läuft wie es soll. Ist auf dem Weg eben eine Fehlerquelle weniger :)
Viele Grüße
Handymeister
ja hab ich mir auch gemerkt .. anstatt der dann einfach alles abbricht .. hab mich schon gewundert das er ne meldung wegen zu wenig speicher bringt.
dann aber wirklich zu flashen bzw son 20% backup zu erstellen welches nicht startet .. das ist sehr leichtsinnig und geht mir nicht in den kopf :(
naja nun bin ich wieder nen stück klüger :)
also bei mir funzt auch alles einwandfrei mit dem kernel .. bt wifi mobiles internet. morgen dann mal testen wie der akku so hält bei normaler benutzung.
Hat bei mir vorher auch noch net geruckelt
So ich hab mir vorhin schnell ein modaco Rom gebacken, ohne Sense/Rosi, auch hier funktioniert es wunderbar.
Wie ich vermutet habe es muß ein HTC Rom geflasht sein nicht zwingend mit Sense. - Nur als Info.:cool2:
Bisher hat mir noch keiner die Frage beantworten können, was das Update bringt. Zählt doch mal auf :)
Maysi2k
Maysi2k
Maysi2k
  • Shadow128
Shadow128
Maysi2k
Maysi2k
Maysi2k
