[MOD] *03.03.16* ViPER4Android Audio Effects v2.4.0.1
tobiasth
tobiasth
Philosoph
2.559
ViPER's Audio is an audio enhancing software to provide everyone with better audio experiences in various platforms such as smartphones and PCs.
ViPER's Audio is founded by Euphy Wong (ViPER520). ViPER's Audio has been a popular audio mod in China. Recently, co-founder Zhu Hang extended the popularity globally through xda-developers forum. It has gained fame and made its stand in the audio mod field.
ViPER's Audio made great improvements in Bass with its dynamic bass system and ViPER Bass. ViPER's Audio also outshines in terms of Clarity with its unique ViPER Clarity and XHiFi technology. Surround sound had never been enough until the presence of field surround, differential surround or haas effect and Virtual Headphone Surround+.
Talking about audio effect, nothing is more significant than convolution. Being the first audio mod to have Convolver makes ViPER's Audio a must for effect lovers. Convolver lets you load technically any impulse response sample you have.
ViPER's Audio is concern with user's auditory health too. Auditory Protection System with the one and only Cure Tech+ reduces your ears' stress and keep you ready for longer duration of pounding musics.
_______________________________________
Installationsanweisung:
  1. Extrahiere und installiere ViPER4Android_FX/XHiFi.apk
    Speziell für Lollipop Android 5.0 User:
    1. Lade die Datei LolliViPER_v2.3.4.0.zip herunter und flashe diese via CWM oder TWRP!
    2. Es ist wichtig den Linux Kernel auf PERMISSIVE zu stellen, am einfachsten geht das mit dieser App.
  2. Starte die FX/XHiFi App und gebe der App root Zugriff.
  3. Jetzt fragt er dich ob du den ViPER Treiber installieren willst, wähle YES "Install/Update".
    Falls die Installation fehlschlägt, die neueste SuperSU aus dem Playstore installieren und die SuperSU binaries updaten/installieren!
  4. Die Installation ist jetzt fertig, starte jetzt dein Telefon neu.
  5. Unter Android bis v4.4 (nicht unter Lollipop 5.x) gibt es jetzt zwei Optionen um V4A an deinem Telefon zu betreiben (ich persönlich empfehle Option 1):
    Um nur V4A zu nutzen, folge Option 1. Um V4A neben anderen MusikFX Effekten (zB. dem DSP Manager) zu nutzen, folge Option 2.
Option 1:
  1. In Einstellungen > Ton > Musiceffektes, wähle ViPER4Android FX
  2. Extrahiere das IRS Starter Pack und kopiere alle irs Dateien in den Ordner /ViPER4Android/Kernel/xxxx.irs
  3. Falls dieser Ordner nicht existiert, bitte anlegen, dabei auf Groß/Kleinschreibung achten!
Option 2:
  1. Öffne V4A FX, dort in den Einstellungen, die FX Compatible Mode auf Compatible Mode setzen.
FIX: ViPER4Android mit allen Playern nutzbar machen!
hierfür muss folgendes in der build.prop eingefügt/bearbeitet werden:
(dies ist zB. mit root explorer möglich)
lpa.decode=false
tunnel.decode=true ---> auf false setzen
lpa.use-stagefright=true ----> auf false setzen​
speichern
sicher stellen das die Berechtigungen richtig sind rw- r-- r--
und neustarten!​
Download Link:
FX version v2.4.0.1 (Android 4.0~6.0): Mediafire
FX version v2.3.4.0 (Android 2.3~5.0): Mediafire
LolliViPER FX version v2.3.4.0
(nur für Android 5.0 und nur falls die normale Version nicht funktioniert!)
: MEGA
FX version v2.3.3.0: Mediafire
LolliViPER FX version v2.3.3.0
: MEGA
FX version v2.3.2.6: Mediafire
FX version v2.3.2.2: Mediafire
FX version v2.3.2.0: Mediafire
FX version v2.3.1.5: MediaFire
FX version v2.3.1.3: MediaFire
FX version v2.3.1.1: MediaFire
FX version v2.3.0.1: MediaFire
FX version v2.2.1.1-1 (nur für Android 4.0-4.3): MediaFire
XHiFi version v2.1.0.2-1 (nur für Android 4.0-4.3): MediaFire
bei Problemen:
build.prop modifizieren
  1. Open up /system/build.prop in text editor.
  2. Change the line Ipa.decode=true to lpa.decode=false (If you can't find this line, skip this.)
Falls es noch immer nicht geht:
MAKE SURE YOU HAVE CHOSE THE CORRECT DRIVER. Siehe oben! (nur für v2.2.1 relevant)
MAKE SURE YOU HAVE LATEST BUSYBOX INSTALLED. (4.3 - SuperSU v1.51+ via recovery)
Check to modify build.prop lines. (If that line doesn't exist, skip this.)
  1. Uninstall driver, reboot. Reinstall driver, Choose correct driver, reboot.
  2. Don't use compatible mode yet, go to sound settings>music effects> and choose v4a(either fx or xhifi).
    Test on several players.
  3. If not working, switch to compatible mode, reboot, go to sound settings>music effects> and select something else other than v4a.
  4. 4. If not working for some players, activate safe mode, reboot.
    Test on those players. If no help, then the player is not compatible. Give up and use a different player for music.
  5. If V4A still not working, make sure you installed the correct apk for your android version. (2.3, 4.0-4.2, 4.3)
meine persönlichen Settings
(Die für mich optimalsten Einstellungen via BT (VW Autoradio RNS 315) und Kopfhörer (Beyer Dynamic DT990Pro) )
Headset Settings
1. Master Power:
Playback Gain Control
(1) Enable checkbox:
(2) Select Effect Strength: Moderate
(3) Max Gain: 8x
(4) Max Output: 0dB
FIREqualizer
(2) Select Preset: Deep
(3) Linear Equalizer graphic: default
Convolver
(2) Impulse Response: DBX160SL Blue - Medium Ratio.irs
Field Surround
(2) Select Field Surround Strength: Slight
(3) Select Mid Image Strength: Level 5
Differential Surround
(2) Select Effect Quality: 5ms
Headphone Surround +
(2) Select Effect Quality: Normal
Reverberation
(2) Room Size: 25m2
(3) Sound Field: 5m
(4) Damping Factor: 0 Percent
(5) Wet Signal: 0 Percent
(6) Dry Signal: 50 Percent
Dynamic System
(2) Select Listening Device: High-end Headphone(v2)
(3) Select Dynamic Bass: 10 Percent
(4) Tube Simulator(6N1J):
Fidelity Control
(1) ViPER Bass checkbox:
(2) Bass Mode: Natural Bass
(3) Bass Frequency: 60Hz
(4) Select Bass Boost:3.5 dB
(5) ViPER Clarity checkbox:
(6) Clarity Mode: XHiFi+
(7) Select Clarity: 3.5 dB
Auditory System Protection
(i) Enable Cure Tech+ checkbox:
(ii) Select Binaural Level: Moderate
Master Gate(Limiter)
(1) Ouput Gain: 0dB
(2) Channel Pan
(3) Limit Threshold: 0dB
BT Settings
1. Master Power:
(3) Max Gain: 4x
(4) Max Output: 0dB
FIREqualizer
Convolver
(2) Impulse Response: DBX 160SL Blue - Medium Ratio.irs
Field Surround
Reverberation
(2) Room Size: 25m2
(3) Sound Field: 5m
Dynamic System
(3) Select Dynamic Bass: 14 Percent
Fidelity Control
(4) Select Bass Boost: 8.0 dB
(7) Select Clarity: 6.0 dB
(1) Ouput Gain: 0.8 dB
(2) Channel Pan
(3) Limit Threshold: 0dB​
IRS Files
Was ist IRS?:
IRS steht für Impulse Response Samples.
Wikipedia: Impulse response - Wikipedia, the free encyclopedia
Seit Version FX v2.2.0.2, sind IR samples nicht mehr im WAV Format, sondern .IRS.
Falls ihr IR Samples im WAV Format findet, dann einfach die Dateiendung umbenennen in IRS um sie mit ViPER nutzen zu können.
Installation:
Entpacke alle IRS files in das Verzeichnis /ViPER4Android/Kernel/
*Falls dieser Ordner nicht existiert, einfach einen erstellen. Stelle sicher das er sich im /ViPER4Android/ Verzeichnis befindet.
IRS Files findet ihr hier.
via XDA
via XDA
Reaktionen: j1gga84, submain, Bronco77 und 14 andere
Boaaaaah. Der Mod rockt ja mal echt extrem! Ich spiel Morgen mal damit ein wenig rum. Aber dickes Dankeschön für den Link! Sound ist mal echt extrem verbessert... Habs auf meine Omega 7.0 gebügelt und der unterschied war sofort hörbar.
Hi der Mod ist echt genial hab in auf der WanamLite Rom.
Und muss sagen Affengeil jetzt kann man auch mit den Headset endlich Musik Hören.
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Also ich habe wanam rom und irgendwie will der mod nicht installieren...
Hi du Lades dir eine von denn beiden Apk runter und entpacks diese dann Kopiers du die Apk mit nenn Rootexplorer nach
system/app vergibst die Rechte neu (644) und startetes das Handy neu.
Dann starteste die App und Installierst den unteren Treiber dann noch mal neu starten.
Jetzt kannste die App verwenden und einstellen.
So müssen die Rechte eingestellt werden!!! uploadfromtaptalk1372653825459.jpg
Wenn er nach Treibern fragt, den für Cortex A8 nehmen.
Stimmt das?
Ja. cortex a8 ist für snapdragon: All Qualcomm/Snapdragon of freq higher than 800MHz, regardless of cores, choose "CortexA8 with NEON"
Reaktionen: Janeo
Also egal was ich mache ist der Mod nicht aktiv.
Welchen Player benutzt du? Also Ich bekomme de Mod auch nur auf stock zum laufen leider (obwohl mir der Sound es wert ist). Hab normal n7 da gehts leider nicht obwohl ich den Compatible Mode und Safe Mode angemacht habe wie in der Anleitung empfohlen.
edit: Diese: http://forum.xda-developers.com/showpost.php?p=42879837&postcount=22 Settings hab ich übernommen und muss sagen..... WOOOOOHOOOO!
Reaktionen: pdmber
Also ich nutzte Poweramp, wobei ich nur den Player nutzte und alle Effekte und Equalizer Setting weder verstelle noch einschalte... Ich habe es eben mit dem Stockplayer ausprobiert und es funktioniert leider auch nicht. Ich glaube ich werde es einfach sein lassen.
Bei Poweramp muss unter Einstellungen/Audio/Erweiterte Einstellungen/ Direke Lautstärekeregelung deaktiviert werden. Dann gings bei mir.
Reaktionen: d407974, beltor, farid1979 und eine weitere Person
Also egal was ich einstelle, welchen Player ich benutzte, steht immer beim Driver Status Enabled: No
Ich hatbe auch den PowerAmp und da nur die direkte Lautstärkesteuerung deaktiviert und schon ging alles.
Was ist eigentlich der Unterschied zwischen den beiden Viper4Android FX und Hifi?
Ich bekomme nur FX zum laufen.
Ciao Lars
Ich habe ein ganz anderes Problem.
Gibt's eine Lösung? Sonst scheint der Mod gut zu funktionieren.
Du musst dir ir samples von der xda-seite laden sind im 2. Post bei xda. Anleitung wie du sie einfügst steht da auch irgendwo auf der ersten Seite.
Nabend,
also ich habe es eben einfach nochmal probiert und es läuft...
Sound ist wirklich super und mit meinen AKG 141 rockts!!!
Danke nochma...
Ich benutze den JoeMeek SC2 Impulse. Der ist wohl sehr beliebt. Hab aber noch nicht alle getestet.
ah okay, bin irgenwie zu blöd den zu finden
habe grad auf xda gesucht aber nur irgenwelche beiträge mit dem text gefunden
natraj
SaschaKH
SaschaKH
submain
submain
