[MOD] 1% Battery Mod für Wolfbreak's CM 6.1.3 V053
Q
quercus
Gast
Quelle: XDA
Autor: shvyue
Link: 1% battery ONLY mod for Wolfbreak's CM 6.1.3 V053
Personally I like WB's theme which comes with the ROM, simple and nice. However there's no way to change the battery icon to 1% except use CM settings. I tried to modified other ppl's framework-res.apk but got menu color problem, most of the current theme using black/dark menu but I like the white one.
ONLY TESTED ON Wolfbreak's CM 6.1.3 V053
So I compiled the framework-res.apk and changed the XML to display 1% battery icon in the status bar only, didn't touch anything else.
Hope this could be kinda useful for some of you.
I've uploaded 2 versions one with my own simple battery icon while another one using kevjef420's MattedBlues battery icon. I borrowed the charging icons from kevjef420's theme hope that's fine. You're happy to change to any battery icons you'd like.
No HW LED issue with the work.
attachment.php
Simple version:
http://www.megaupload.com/?d=T696OPD9
MattedBlues version (didn't test but should be ok):
http://www.megaupload.com/?d=35OHC6U5
Knubbel
bildmacher
bigbootykilla
  • bigbootykilla
bigbootykilla
bigbootykilla
Q
quercus
Q
