N4 Style TW Lollipop ROM for N9005/ SM-N900T/ SM-900W8 (Android 5.0)
Andy King
Andy King
Tweaked N3 Base / N4 Style Lollipop ROM
(Stable, Speed, High Performance, Battery Friendly) :thumbsup:
Für mich die beste Touchwiz Rom aller Zeiten. Alles läuft stabil und wirklich sehr schnell. Air Command funktioniert auch ohne Probleme.
For Samsung Galaxy Note 3 n9005 / SM-N900T / SM-900W8
Download N4 Style Lollipop ROM
https://mega.co.nz/#!JdtVETxT!SZdq8oflczp_rO09kMNt21fOSpKbsApOekhHLi7ix04
Orginal XDA Developers Thread hier
[ROM][N900X][ODEX&DEODEX][14/Feb][Tweaked St… | Samsung Galaxy Note 3 | XDA Forums
Features:
Based on Firmware [LRX21V.N9005XXUGBNL8]
ODEX & DEODEX
ROM SIZE IS ONLY : 872.6 MB
Stock Kernel included
Android 5.0 TouchWiz
Standalone flashable zip (no aroma)
Knox-Free : Removed KNOX COMPLETLEY (apps, container, agent, store, etc....)
Removed Around 650mb of Craps, Bloatware.. (Seriously SAMSUNG??????!!!!!!)
BusyBox
Modem is not included in the ROM Flashable ZIP (Must be flashed Separately)
N9005 Lollipop Build N9005XXUGBNL8 Modem
N9005 Bootloader Lollipop Build is also not included in the ROM Flashable ZIP (Must be flashed Separately)
N9005 Lollipop Build N9005XXUGBNL8 Bootloader
(flashing MODEM & BOOTLOADER is not a MUST if you come from stock ODIN full N9005XXUGBNL8 ROM or Only if you notice any Issue related to them.)
PreRooted with the Latest version
Updated some Samsung Apps
All Languages are supported
Toolbox up to 12 Apps
Quick Settings up to 15 apps
UPSM , Toolbox in Toggles statusbar by default
360° Device Rotation possibility
Pullup to choose any apk u would like to start if u swipe up from home
Launcher Full Theme Support
enabled hide apps option in launcher
modded with all available camera Mods & n4 themed Camera App
5way Restart methods & Flashlight & Screenshot in Power Menu
Replaced Dialpad Video call button in Normal and Easy Mode also in landscape with SMS Button
Removed End Call Screen
no sms in logs
App Ops
Developer Option Enabled by default
Device Animation Speed 0.5 by default
All apps in MW and PW and scale all apps from corner
Enabled many Settings Widgets
Blocked all Ads.
Quicklaunch in Statusbar
enabled 3dots Menu
modded sms app & enabled VIP contacts and Emoticons
Network indicator in statusbar
3minitBatterySettings with Stock Battery Icon by default
Removed Sfinder and Quick Connect
A Ton of CSC & Build.prop Tweaks
Note 4 Weather Widget
Note 4 Splanner Widget
Note 4 Task Manager
Note 4 Side key Toggle
Note 4 Dialpad Style
Note 4 Official Wallpaper
Note 4 Menu Keys
Note 4 My files
Note 4 Clock
Note 4 Video App and player
S5 SecSettings optimized for N3 for now in few Days will release Note 4 Secsettings im work on it!
Note 4 Lockscreen
& MANYYY MANY OTHERS DISCOVER THEM UR SELF
What Works !
ALMOST EVERYTHING , You tell me if u find any ISSUE​
Im XDA-Thread haben aber viele Leute Probleme mit der ROM.
Unter anderem:
- Wifi not working
- nach 30 Sekunden bleiben Videos stehen, nur der Ton läuft weiter (zum Beispiel Youtube)
- Bootloop wenn Kopfhörer angeschlossen sind beim booten
Das habe ich jetzt zumindenst auf die schnelle beim überfliegen gelesen.
Kannst du dazu was sagen?
Reaktionen: boxpeter
Was ist das für ein Port?
Also welcher 5.0 Version?
Mfg
Based on the Official Firmware XEO N9005XXUGBOA5
Ich finde die Rom klasse :)
kann ich die auf eine 4.4.2 rom drüber klatschen mit fullwipe?
Hab eben die Rom über mein altes 4.4.2 geflasht mit fullwipe und funzt einwandfrei:thumbup:
Funktioniert bei euch die Touch Key Beleuchtung unten?
Hey
ne leider bei mir auch nicht und ich konnte nicht die Funktionen ändern des Toch Key.
Genervt hat mich auch die Geschwindigkeitsanzeige des Downloads neben der Uhr.
Naja habe es mal ausprobiert bin aber wieder beim Teamsek 7.8 gelandet
Reaktionen: DeeJayD2011
Die Geschwindigkeitsanzeige ist nicht so wild das mit den nicht leuchtendenTouch Keys nervt mich da eher. Kann ich da ich ja einen neuen Bootloader und Modem geflasht habe einfach wieder ne 4.4.2 Rom flashen oder muss ich die auch wieder erst ändern?
Die Keybeleuchtung ging bei mir auch nicht, und der akku war nach einer Std. etwa knapp 40% runter. Bis jetzt die schlechteste Rom die ich getestet habe.
Keine Einstellmöglichkeit der Statusleiste.
Bin ebenfalls zur Themasek zurück :D
Über den Akku kann ich mich bisher nicht beschweren die Touch Keys sind der einzige fehler den ich bisher habe auch WLAN usw keine Probleme. Auf XDA hat der Rom Koch noch nen Note 4 port den werde ich wohl mal versuchen. Kann ich mit dem Android L Bootloader zurück auf ne KK Rom oder hab ich dann Bootloop oder sonstiges?
Is jz schon etwas her @DeeJayD2011 aber das geht in der Regel problemlos :) hab auch von der offiziellen 5.0 auf miui gedowngradet :D
Danke für die Info :) Aber ich bin jetzt beim Android L Note 4 Port des selben Rom Kochs hängen geblieben und der läuft wirklich Super :biggrin:
Eines muss ich aber noch korrigieren, die Touch Key Beleuchtung funktioniert in dieser Rom hier es hatte nur was mit den Energiespar einstellungen zu tun.
MFG
Ich hab Probleme damit, dass das Internet relativ lahm ist vor allem das mobile... Kann mir jemand verraten wie man das hinbekommt bin vom vd2 note 3 lollipop gekommen... Also wegen dem modem... Und csc hab ich dieses extra Packet gelasht und dbt ausgewählt... Kann auch sein das ich die selbe rom hab wie deejay... Weil ich ne aktuelle version von xda genommen hab...
Ja genau die hab ich auch ;)
Ja hab halt gewiped und die lollipop Vodafone version drauf und gerootet... Und dann wieder wipe und die version drauf und den csc drüber...
Und hab auch das beachtet was der beschrieben hat also beim einrichten die agb bestätigt und unten da das er dieses diagnose dings senden soll verweigert!
Trotzdem kann ich im mobilen Internet im appstore keine app laden weil er den nichtmal läd.
Hast du einen komplett Wipe gemacht? Also CWM Clean to install new rom bzw. bei TWRP Advanced Wipe und alles ausser der extSDCard gewiped?
Aber ich glaube das das nicht wirklich hier hin gehört weil es sich ja faktisch um eine andere Rom handelt mach ma per PM weiter ;)
MFG
Hat jemand einen Mirror für die Rom?Würde sie gerne mal ausprobieren
Leider gab es wohl Unstimmigkeiten zwischen den Mods und dem Entwickler g00h . Nun ist es so, dass alle seine Threads geschlossen wurden. Es ist unklar, ob g00h nun unter einem anderen Account bei Xda oder sogar in einem anderen Forum weitermacht.
Ok Guys after being banned this user mad a new account and requested all of his threads being removed. While we dont remove work completely due to the value of information in the threads these threads are now closed.
Hier habe ich noch Links über die du Dir eine Version von dem Tweaked Note 4 L Rom ziehen kannst.
http://androidaba.altervista.org/tweaked-ported-note-4-l-tw-performance-battery-for-note-3/
https://www.androidfilehost.com/?a=show&w=files&flid=18137
Reaktionen: holzfish
waro
manne49
maxgamer2006
mp3bondie
hagex
hagex
