N5 Port - Phronesis MM 6.0.1 Multi-DPI Rom
ICiP
ICiP
Hallo Android Gemeinde
Da es noch kein Thread für die neue Phronesis 6.0.1 Rom gibt,
hier ist er
:thumbsup:
Ich übersetze hier nichts. Ich kopiere nur das wichtigste von XDA Thread.
Phronesis Rom Series, Here we go again....we are known for our professionalism and excellence because "We Know How"
On the back of the most successful Lollipop N5 firmware Port, we once again bring you the best N5 MM port you will ever experience on your device.
This Port has been in development for over 6 weeks and great effort has been made to bring you once in a life time experience with your Note3. I and the
team have been working hard behind the curtain to make it one of the best ever. It's stable, solid, feature rich and full of customization you will ever want.
Note 5 users will probably want to give away their phone to get Note 3 just to use the Phronesis N5 Port for N3.....not even kidding!
Rom Installation:
1. Download Phronesis rom and save it to your phone memory or sd card
2. Get a good recovery. TWRP recovery recommended, 2.8.7.0. Newer versions are not supported
3. Boot into recovery, factory reset (full wipe, clean install is recommended). Make choices in Aroma.
4. Optional flash kernel of choice if you're
4. Reboot after successful install and wait for best rom in town to build. Allow about 10 - 15 minutes for first boot.
5. Your phone will reboot once after the first boot to complete customizations..
6. Sit back and enjoy
For full wipes Rom Releases:
1. Boot into recovery (say TWRP 2.8.7.0)
2. Select wipe in recovery menu
3. Select Advanced Wipe
4. From the resulting window, select to wipe system, data, cache and dalvik cache (of course after backing up your rom / data)
5. Swipe to wipe the selected partitions.
That's recovery wipe completed.
In Aroma menu when you get to option to wipe, select:
1. Select "Full Wipe" radio button
2. Select "Full wipe 1" radio button
3. Select your CSC as desired
4. Continue making other choices as you like....
Kernel Installations: VERY IMPORTANT
This rom does not come with any kernel. It was tested with darklord 1.9 by @darkera13. It will be expected that you will be find a link for this kernel and
have it ready in your sdcard to flash immediately after flashing the rom. There are two options in aroma to choose from, you can choose to keep your existing
kernel or install a new kernel after rom flash.
Links:
Original XDA Thread:
[Rom][6.0.1][N5 Port][26.06.2016] [Multi-DPI] Phronesis MM Rom v1.1 Feature Rich
Phronesis N5 MM Port Features:
Rom Feature - Post #2
Download:
Download Section - Post #3
http://forum.xda-developers.com/showpost.php?p=67367849&postcount=3
Screenshots:
13.jpeg 1.jpeg 17.jpeg 2.jpeg 3.png 5.jpeg 7.png 8.png 9.png 10.png 11.png 14.png 15.png 16.png 18.jpeg 19.jpeg 20.jpeg 4.jpeg
Reaktionen: mecss
Das ROM ist für mich genauso unbrauchbar wie alle bisherigen MM Custom ROM für unser Note 3. Ich benutze das Handy im Auto als Navigationsgerät. Verwendete Navigationsprogramme iGO Primo 2.4 und Navigon. Bei beiden Programmen gelingt es unter Marshmallows nicht eine Internetverbindung herzustellen. Nicht unter WLAN oder LTE/G3H Das heißt Online TMC ohne Funktion, obwohl beiden Programme alle Rechte haben.
@bernardo65: Echt schade, dass das Dingen bei Dir nicht brauchbar ist. Meines Erachtens eines der besten N5-Ports für unser Betagtes Note 3. Kannt diese Ports von meinem alten Note 2 LTE (Stichwort: "Nemesis" oder zu Beginn "Ditto Note"), die auch funktioniert haben, aber an der ein oder anderen Stelle immer wieder kleine Macken hatten.
Beim Phronesis ROm (egal ob 5.1.1 oder 6.0.1) bisher keinerlei Probleme. ALle Netzwerkverbindungen funktionieren einwandfrei....(sieht man mal von meinem individuellen Anfangsproblem ab, bei dem LTE nicht ging - es aber Dank Lolipop PHE StockROM geklappt hat). Wenn jetzt noch der UPSM irgendwie zum Laufen gebracht wird....eine wirklich gute Basis um mit dem Note 3 die "nächstenb Jahre" weitermachen zu können
TRoss
Hallo an Alle,
weis einer von euch warum bei dem ROM kein Kernel dabei ist?
Ist doch wieder nur "künstlich komplizierter".
Gruß Matzoid
Weil die XDA-Leute da wohl neue Vorschriften haben;Kernel extra und beschreiben wie und woher und wer...usw.
Find ich auch nicht gut aber watt solls.
Bin kurz davor auch zu flashen, aber mein Handy muss funktionieren. Mein Nexus 7 2013 benutze ich da lieber zum ausprobieren....
Aber der Zwang ist da und es juckt ;-)
Ok ein bischen Off-Topic... aber ich hoffe das ist hier ok. ;-)
Ich habe mal die letzte 6.0.1 auf meinem note geflashed.
Läuft soweit ganz gut. Bei mir funktioniert nfc nicht. Kann das jemand bestätigen?
Übrigens war ein Kernel dabei. Man kann im installer wählen ob mit.. oder eigenem Kernel flashen. Hat jemand einen link zu einem alternativen Kernel. Ich habe nichts eindeutiges gefunden. Mein english ist nicht so besonders...
hagex schrieb:
Find ich jetzt noch nicht so toll :(.
Bitte lesen: [TEAM INFO] Vorgaben und Tipps zur Gestaltung von ROM-Threads
Gruß von hagex
oldgeorge78 schrieb:
I Mein english ist nicht so besonders...
Und genau deshalb ist hier jetzt erstmal Schicht :(.
Falls jemand den Thread gemäß den Richtlinien überarbeiten oder übernehmen möchte, bitte PN an mich oder jedes andere Teammitglied.
Danke fürs Verständnis und
Gruß von hagex
mp3bondie
hagex
hagex
waro
Triple_H72
deli99
deli99
