OC-Kernel für 2.1?
geigi
geigi
Abend zusammen,
gibt es auch einen Overclock-Kernel für das standart 2.1? Kann man evtl. den Kernel vom Wildpuzzle nehmen?
Danke :smile:
genau sowas suche ich auch!
Ich kann nämlich NICHT auf die Sozialen Netzwerke verzichten und möchte deshalb nicht die 2.2 aus China aufspielen ... :)
mfG
[ROM][06/10] WildPuzzleROM v8.0.8, Froyo 2.2, Fixed Weather, OC-Kernel, 4in1 Menu - xda-developers
0001_WildPuzzleROM_v7.3.1.zip - base system - apps2sd is included in the rom and starts automatic when found a ext-partition, for changelog click here.
0010_move_dalvik2SD_v1.zip - moved dalvik-cache to ext-partition
Only the latest flashed kernel will be used
0050_kernel_orginal_from_1.28.1107.2_standard.zip - Flash this if you want to go back to the stock kernel from release: 1.28.1107.2
0053_kernel_custom_2.6.29_aufs_overlay.zip - This kernel adds full system read/write access via aufs file system. Compiled by Martin eve
0055_kernel_oc_2.6.32_for_v7_only_test.zip - Overclock kernel 768mhz
0056_kernel_oc_2.6.29_for_v7_only_test.zip - Overclock kernel 768mhz
010x_*.zip changes kernel speed(mhz)!
0100_orginal_cpu_speed.zip - This is not a kernel, its cpu-instructions, sets cpu speed to predefined value, but 0055_oc kernel support upto 768mhz
0106_691mhz_cpu_speed.zip - This is not a kernel, its cpu-instructions, sets cpu speed to predefined value, but 0055_oc kernel support upto 768mhz
0108_710mhz_cpu_speed.zip - This is not a kernel, its cpu-instructions, sets cpu speed to predefined value, but 0055_oc kernel support upto 768mhz
0110_768mhz_cpu_speed.zip - This is not a kernel, its cpu-instructions, sets cpu speed to predefined value, but 0055_oc kernel support upto 768mhz
Werde es am WE mal testen:rolleyes2:
Habs mal "installiert" lief 2-3min super fix:ohmy: aber danach nur noch am ruckeln :blink:
Hoffe da kommt noch wat:thumbsup:
  • hydra2002
hydra2002
hydra2002
  • PsYcHoKaTeR
Dieter1709
Dieter1709
