Problem ClockworkMod Recovery
brennie
Kennt jemand dieses Problem wenn man ein Backup über den ROM Manager Version 5.0.0.8 machen will:
Starting recovery on Fri Jul 27 17:59:17 2012
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (1024 x 768)
CWM-based Recovery v6.0.1.0
recovery filesystem table
0 /tmp ramdisk (null) (null) 0
1 /cache ext4 /dev/block/platform/omap/omap_hsmmc.1/by-name/cache (null) 0
2 /data ext4 /dev/block/platform/omap/omap_hsmmc.1/by-name/userdata (null) 0
3 /system ext4 /dev/block/platform/omap/omap_hsmmc.1/by-name/system (null) 0
4 /ext_sdcard vfat /dev/block/platform/omap/omap_hsmmc.0/mmcblk1p1 (null) 0
5 /sdcard datamedia /dev/null (null) 0
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
W:Unable to get recovery.fstab info for /sd-ext during fstab generation!
I:Completed outputting fstab.
I:processing arguments.
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.sys.usb.config=mtp,mass_storage,adb
ro.build.id=IMM76L
ro.build.display.id=full_s9512-eng 4.0.4 IMM76L eng.grzesiek.20120725.101701 test-keys
ro.build.version.incremental=eng.grzesiek.20120725.101701
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=śro, 25 lip 2012, 10:17:20 CEST
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=grzesiek
ro.build.host=ubuntuvirt
ro.build.tags=test-keys
ro.product.model=Full Android on Emulator
ro.product.brand=Android
ro.product.name=full_s9512
ro.product.device=s9512
ro.product.board=s9512
ro.product.cpu.abi=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=omap4
ro.build.product=s9512
ro.build.description=full_s9512-eng 4.0.4 IMM76L eng.grzesiek.20120725.101701 test-keys
ro.build.fingerprint=XXXXXX
ro.build.characteristics=default
ro.cm.device=s9512
keyguard.no_require_sim=1
ro.com.android.dateformat=MM-dd-yyyy
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.adb.qemud=1
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=XXXXXXXX
ro.bootmode=unknown
ro.baseband=unknown
ro.carrier=wifi-only
ro.bootloader=U-Boot_1.1.4
ro.hardware=omap4430
ro.revision=16
ro.emmc=0
ro.crypto.fs_type=ext4
ro.crypto.fs_real_blkdev=/dev/block/platform/omap/omap_hsmmc.1/by-name/userdata
ro.crypto.fs_mnt_point=/data
ro.crypto.fs_flags=0x00000406
ro.crypto.state=unencrypted
ro.product.cpu.abi2=armeabi
com.ti.omap_enhancement=true
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=256m
ro.sf.lcd_density=160
ro.opengles.version=131072
wifi.interface=wlan0
ro.radio.use-ppp=no
ro.config.nocheckin=yes
omap.audio.mic.main=DMic0L
omap.audio.mic.sub=DMic0R
omap.audio.power=PingPong
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
hwui.render_dirty_regions=false
ro.product.fih_platform=NVIDIA
ro.product.fih_device=GOX
persist.hwc.mirroring.region=0:0:1024:768
ro.config.3g_modem=false
ro.com.google.gmsversion=4.0_r2
ro.com.google.clientidbase=android-fih
ro.com.google.clientidbase.ms=android-fih
ro.com.google.clientidbase.yt=android-fih
ro.com.google.clientidbase.am=android-fih
ro.com.google.clientidbase.gmm=android-fih
dalvik.vm.dexopt-flags=m=y
ro.product.model.num=4118
persist.service.adb.enable=
persist.sys.timezone=Europe/Amsterdam
persist.sys.showfps=0
persist.sys.provisioned=true
persist.sys.cpu=0
persist.sys.playBootSnd=0
persist.sys.localevar=
persist.sys.country=DE
persist.sys.profiler_ms=0
persist.sys.language=de
persist.sys.mfps= 0.0, 1.0, 0.5, 0.5, 0.5, 1.1
persist.dbgcfgtool.enabled=0
init.svc.recovery=running
service.adb.root=1
init.svc.adbd=running
I:Checking for extendedcommand...
I:Running extendedcommand...
Waiting for SD Card to mount (20s)
I:using /data/media for /sdcard.
SD Card mounted...
Verifying SD Card marker...
SD Card marker not found...
I:Running script:
I:
ui_print("ROM Manager Version 5.0.0.8");
ui_print("27. Juli 2012");
assert(backup_rom("/emmc/clockworkmod/backup/2012-07-27-17.58.49"));
parse returned 0; 0 errors encountered
27. Juli 2012
E:unknown volume for path [/emmc/clockworkmod/backup/2012-07-27-17.58.49]
Can't mount backup path.
result was NULL, message is: assert failed: backup_rom("/emmc/clockworkmod/backup/2012-07-27-17.58.49")
Hat jemand ein Backup mit dem Lifetab S9512 schon mal hin bekommen??
What did you try to do? Backups work OK when ordered directly from CWM menu (after reboot to recovery). They are made to internal SD card instead of real SD card, but I do not have time nor am I willing to fix that ;)
Das Backup ist nur 500kb groß und besteht aus 4 Dateien. Es gibt auf der sd karte einen Ordner namens "blobs" in diesem sind lauter unterordner. Gehört das mit zum Backup? Das sind an die 2000 dateien!
Gesendet von meinem LIFETAB_S9512 mit der Android-Hilfe.de App
That's the new format of CWM backup.
ich habe jetzt ein Problem beim Wiederherstellen.
Im CWM kommt das hier:
Checking MD5 sums...
Restoring data...
Error while restoring /data!
ich habe schon versucht Data zu formatieren. Kommt kein Fehler.
Wenn ich dann mit ls nachschaue sieht das so aus:
/data # ls
ls
ls: ./etc: I/O error
ls: ./certificate: I/O error
media
jetzt ein neuer versuch vom Restore. Wieder der Fehler und der Ordner sieht so aus:
root@android:/data # ls
ls
SKU_Backup clean_boot_finish drm misc
anr dalvik-cache last_alog resource-cache
app-private data local system
backup dontpanic media tombstones
Was sind das für I/O Fehler ??? Kann man die löschen. Wenn ja wie ??
Zuvor ist mir das Tab im normalen Modus abgestürzt. Es ging nicht mehr an. Es nach einer langen Weile ging es wieder an.
Alles kommisch........:confused2:
Der ursprüngliche Beitrag von 17:01 Uhr wurde um 17:47 Uhr ergänzt:
HILFE es werden immer mehr:
/data # ls
ls
ls: ./system: I/O error
ls: ./app-private: I/O error
data media
:blushing::confused2::confused2::confused2:
löschen geht auch nicht:
/data # rm etc
rm etc
rm: can't stat 'etc': I/O error
/data #
:cursing::cursing:
Honestly? I have no idea. If I were you, I would just restore system partition from img backup.
die Data Partition (image) ist an die 13 GB Groß ?
Ich wollte sie mit sichern. Aber der interne Speicher (sdcard) ist zu klein.
Jetzt bestelle ich mir eine 16 GB microSD Karte und dann muss der Tab von meiner Frau herhalten. :p
Es sei den jemand kennt einen Ausweg???
You cannot backup /data to /sdcard, because /sdcard is just a shortcut to /data/media folder. So you were trying to backup /data into /data ;)
so nun läuft das lifetab wieder.
Die habe die Partion data und cache einfach mit diesem Befehl gelöscht:
"fastboot -i 0x17ef erase cache"
"fastboot -i 0x17ef erase userdata"
Es gab aber dann Probleme mit der internen SD Card. CWM konnte einfach nicht drauf zugreifen. Obwohl sie gemountet war. Hier hat es geholfen das Tab mit einer leeren Userdata Partion einfach zu starten und dann wieder in CWM Mode zu gehen. Jetzt funktionierte das Mouten.
Aber beim zurückspielen über CWM kommt immer wieder diese Fehlermeldung:
... und ich habe 3 unterschiedliche Backups versucht einzuspielen. Nichts. einfach nicht.
Das Tab ist dann aber trotzdem richtig hoch gefahren. Der Medion Installer hat sein ganzes Zeug wieder installiert. Ich habe meine Apps und Einstellungen einfach mit dem Titanium Backup wiederhergestellt.
Im Titanium Backup kann man auch die CWM Backups extrahieren. Aber auch dort wurden mir die Apps zwar alle angezeigt (120 Stück) aber das zurückspielen ging leider nicht. Das Programm stürtzte dabei ab.
Ist das ewt ein CWM Fehler. Evt. ein Bug???
Reaktionen: tom_wolf
ich habe auch ein problem, ich denke es hängt mit irgendeinem konfigurationsproblem zusammen. so als ob die fstab nicht mehr passen würde. hat sich die fstab geändert bei den updates?
die interne /sdcard verliert daten (wahrscheinlich werden sie irgendwohin gespeichert, wo ich sie nicht finde), was passiert wenn ihr mount adb shell --> su --> df eingebt?
der play store stürzt ab und wenn ich in die systemeinstellungen gehe und app anklicke, stürzen die systemeinstellungen auch ab. kann das mit dem seltsamen verhalten der /sdcard zusammenhängen?
Sooo, ist hoffentlich alles gefixt. Es muss an unvollständig gelöschten user daten gelegen haben. ich hatte sowohl aus dem android als auch aus dem cwm alle nutzerdaten und den cache mehrfach gelöscht.
alle daten? nein, eine kleine gruppe von daten leistete erbitterten widerstand!
brachte auch bei mir die lösung --> danke brennie
(übrigens hatte ich gestern zwei höhepunkte: das erste mal, als ich die fstab mit less sehen konnte und sie beschädigt schien, bekam ich von einem kumpel einen vi geschenkt. als ich den vi startete, war die fstab ganz weg...
das andere mal war, als ich wieder mal die externe microsd card entfernte, um sie bei den mehrfachen userdaten lösch- und formataktionen nicht ausversehen mitzulöschen. nun ja, ich ließ sie fallen und fand sie nicht wieder...)
:D
  • el_fuego
daddle
  • ThomasBe
hävksitol
hävksitol
