Problem USB mounting.
mngt13
Good Day,
Sorry for the question in English.
Lately when i connect SD thru USB mounting is Ok but to un mount i get ( it´s safe to disconnect from USB ) but then does not remount SD automatically but it used to remount automatically now hi have to do it manually.
Any solution ?
To safe unmount your SD card do following: On the PC Save Remove then on our Android Smartphone USB Mount deactivate.
i hope it will help you!
Reaktionen: mngt13
fenie
Sturmhsvhsv
  • Sturmhsvhsv
Sturmhsvhsv
Sturmhsvhsv
U
  • Untot
Time_Bandit
Time_Bandit
