[Recovery][CWM]Custom Recovery basierend auf ClockworkMod mit Touchunterstützung
red-orb
red-orb
Enthusiast
856
Hi
hier gibts ein neues Custom Recovery in der Version 0.3.6.
Es handelt sich um eine Modifikation des normalen ClockworkMod Recovery mit Touchunterstützung.
Man hat eine etwas andere Menüstruktur die aber meiner Meinung nach aufgeräumter wirkt da verschieden Punkte zu Menüs zusammen gefasst wurden.
phiexz schrieb:
PX Custom Recovery - For cooper
I am not responsible for any damage to your phone
Tempoary only for devs.
i dont have cooper device to test it.
please report if u found bugs
NB: This Recovery is still on beta. maybe not all feature working properly. please report me if u found a problem
NB: IF U A NOOB, DONT FLASH IT UNTIL SOME DEVS SAY IT FULLY WORKING ON COOPER
Well, this is only Modification of ClockworkMod Recovevry with many change, support onscreen button touch, Themes & many more
Features:
  • Touchscreen Support thanks to Napstar
  • Reconfigure & Redesign UI
  • More color & Better Image quality
  • Reboot menu
  • Set brightness level
  • Charging on recovery
  • push apk to system (unfinished)
  • Touch Event only if onscreen button touched
  • Timezone Settings
  • auto save & load setting
  • Partition info
  • Themes
  • more (please give me suggesion about new feature)
So sieht momentan die Menüstruktur aus:
Code:
- reboot system now
- reboot menu
   - reboot to system
   - reboot to recovery
   - reboot to download mode
- wipe & factory reset
   - wipe cache
   - wipe data (factory reset)
   - wipe dalvik cache
   - wipe battery stats
- mount menu
   - mount/unmount /cache
   - mount/unmount /data
   - mount/unmount /system
   - mount/unmount /sdcard
   - mount/unmount /sd-ext
   - mount/unmount USB storage
- format menu
   - format /cache
   - format /data
   - format /system
   - format /sdcard
   - format /sd-ext
- Install zip from sdcard
   - choose zip
   - apply /sdcard/update.zip
   - tonggle signature
   - tonggle script assert
- backup & restore
   - backup
   - restore
   - advance restore
- advance menu
   - report error
   - key test
   - show log
   - partition sdcard
   - fix permission
   - info
     - Disk
         - system
         - data
         - cache
         - sdcard
         - sd-ext
         - Memory
- Settings & Interface
   - Enable/Disable Vibrate
       - Enable
       - Disable
- Enable/Disable Onscreen Button
   - Enable
   - Disable
- Brightness Control
   - Low
   - Medium
   - High
- Timezone Setting
   - Set Theme
Hier gehts zum orginal Thread bei XDA
[DEV][WIP][Recovery]PX Custom Recovery 0.3.6[BETA][Last: Mar 16, 2012][Tester Needed] - xda-developers
Man kann es mit dem Touch oder aber auch mit Hardware-Buttons bedienen
Ich finde das Recovery richtig gut und obwohl es noch eine Beta ist funktioniert es richtig gut.:thumbsup:
phiexz schrieb:
Danke, werde ich heute abend mal testen.
Cwm tuts für meine zwecke auch ;)
Nettes design
Das gibts doch in verschiedenen farben, habs mir auch schon auf xda vor einiger zeit angeschaut
Gesendet von meinem GT-S5830 mit der Android-Hilfe.de App
Ice-Only
I
rsboxing
magicw
magicw
Toeb
  • Gesperrt
  • Toeb
Hatshipuh
Hatshipuh
