  1. ChaosWare, 13.06.2011 #1
    ChaosWare
    ChaosWare Threadstarter Android-Experte
    457
    Erhaltene Danke:
    120
    05.05.2011
    Der user PabloPL von den XDA Developers hat eine unofizielle version des ClockworkMod Recovery rausgebracht.
    Link
    Originalbeitrag von PabloPL:
    Hi
    Today i managed to run the newest Clockwork Recovery on my Galaxy Ace. It has some problem with graphics (as you can see on screenshots).
    I've tested following options (and for me they are working):
    - wipe Data/Factory reset
    - wipe cache partition
    - some options under advanced menu (to wipe)
    - install zip from SDCard (tested on some file from UOT kitchen)
    - reboot recovery
    - mount USB storage (and other mount options) Better not try to format partitions from recovery yet - it could format them to ext4 for which we probably not have yet support in kernel.
    Know bugs:
    - poweroff sems to reboot phone
    - problem with graphics (probably framebuffer is set to 24 or 32 bpp mode. There is also missing double buffer support in framebuffer - thats why we have 2 recovery screens)
    I've also managed to create nandroid backup of all partitions (boot,recovery,data and system) but not tried yet to restore them.
    Phone info
    [​IMG]
    In recovery mode (sorry for terrible image quality)
    [​IMG]
    I've attached packed recovery.img. it's based on KPH firmware + root in adb (in both boot and recovery mode) + su binary.
    Remember, I am not reponsible if you brick your phone. You're flashing this on your own risk.Not all options are tested!!!.
    For now don't try to backup/restore!.
    How to flash:
    1. take KPH firmware
    2. extract CODE_S5830XXKPH_CL260130_REV03_user_low_true.tar.m d5
    - tar xvf CODE_S5830XXKPH_CL260130_REV03_user_low_true.tar.m d5
    3. replace recovery.img with attached file
    4. pack it back
    - tar -H ustar -c boot.img recovery.img data.rfs system.rfs >ODIN_FILE.tar
    - md5sum -t ODIN_FILE.tar >>ODIN_FILE.tar
    - mv ODIN_FILE.tar ODIN_FILE.tar.md5
    5. flash it with odin
    To move in recovery:
    - Volume up/down to move.
    - Home (center key) to select item.
    - Back to move back.
    Gruß, Chris
  2. flo-95, 13.06.2011 #2
    flo-95
    flo-95 Ehrenmitglied
    6,653
    Erhaltene Danke:
    1,140
    22.10.2010
    Phone:
    Nexus 5
    Tablet:
    Nexus 7 (2012)
    Ist verschoben. P.S. Es gibt auch die "Beitrag melden"-Funktion ;)
    Ich hab mir auch schon überlegt, das hier zu posten, aber da es noch Bugs hat, habe ich abgewartet.
  3. backylasek, 13.06.2011 #3
    backylasek
    backylasek Android-Guru
    2,260
    Erhaltene Danke:
    266
    17.09.2010
    also das hört sich sehr vielversprechend an...wenns gefixt ist wag ich das flashen...dann können wir hoffentlich bald auf odin verzichten und nur noch die roms via update.zip flashen :)
  4. flo-95, 13.06.2011 #4
    flo-95
    6,653
    Erhaltene Danke:
    1,140
    22.10.2010
    Phone:
    Nexus 5
    Tablet:
    Nexus 7 (2012)
    Endlich nicht mehr den Pc zum flashen anschmeißen müssen :thumbsup:
  5. backylasek, 13.06.2011 #5
    backylasek
    2,260
    Erhaltene Danke:
    266
    17.09.2010
    :thumbsup:mich juckts ja schon in den fingern....aber wenn da was beim flashen verkehrt läuft ...dann hab ich echt nen briefbeschwerer....
    wäre net wenn jemand die tar dateien hier hochlädt und vorher schon die recovery.img datei in die CODE_S5830XXKPH_CL260130_REV03_user_low_true.tar.m d5
    hinzugefügt hat......und bitte einmal vorher getestet hat, damit man nicht so beim flashen schwitzen muss :biggrin:
  6. ChaosWare, 13.06.2011 #6
    ChaosWare
    457
    Erhaltene Danke:
    120
    05.05.2011
    Umpacken kann ich gerne machen ;) , werde allerdings auch erst testen wenn es einigermaßen fehler frei ist
    Download: http://www.megaupload.com/?d=2NKYG8A0
    Gruß, Chris
Diese Seite empfehlen
