[ROM][AOKP+CM] Snap(BlacK) 1.4 | 140 | Battery. Dark.[03.10.12]
mareis1973
mareis1973
Enthusiast
3.070
Guten Morgen. Endlich gibt es ein weiteres Aokp Build für unser S3.
Weder ich noch Android-Hilfe.de übernehmen jedwede Haftung für entstandene Schäden.
DaXmax Snap (Black) Rom
SnapBlack (Based on AOKP Sources)
Credits
CodeNameAndroid
AOKP
CM
TeamBAKED
BrainMaster
Features
Built from AOKP Sources
Whole ROM is Dark Holo Themed
Network Optimizations
Ad-Host Free
Changelog
Available in the Second Post
Downloads
You're at risk by downloading this, it's very alpha and sound doesn't works for now. A newer build will get fix when sources code is up. Sorry
Latest ROM
Latest Inverted Google Apps (by TeamBAKED)
for more kinky updates.
And if you preferred stock theme and white gapps, oh wait, official aokp isn't exist yet, sorry. :o
Press Thanks if you liked my work. And you really love it, maybe consider to buy me a drink. :)
XDA-Thread:
[ROM][AOKP+CM][ALPHA] Snap(BlacK) 1.2.1 | #121 - xda-developers
Reaktionen: beafraid und rudl1220
CHANGELOGS & DOWNLOADS:
http://androtransfer.com/?developer=daxxmax&folder=SnapBlack_i9300
1.4.0
AOKP Changelog:
  • Adds the ability to force dual panel at any dpi
  • SmsUsageMonitor: Increase default # of sms sent in checking period
  • NavBar: Fix Target Selection
  • NavRing: fix layouts
  • Revert “ril: avoid sending null aid string in getIMSI”
  • NavRing: Fixes layouts lastone, Promise
  • Navbar: Fix Custom icons
  • i9300: enable UMS
  • Add option for switching between UMS and MTP/PTP mode
Snap ( Black ) Changes:
  • Tuna: UMS Options (WIP)
  • Tuna: Trinity Colors Preset
  • Tuna: GNexParts Improvements
  • ROMControl: Menu UI Overflow Toggle Option
  • ROMControl: Ability to hide status bar
  • ROMControl: Alternate Default App Picker
  • Mms: Insert Emoji and Smiley at Cursor position
  • Mms: Prevent QuickMessage popup when Mms is active application
  • Mms: Prevent QuickMessage popup force closing when receiveing Mms
  • Phone: Port CM Advanced Phone Settings
  • Frameworks: Fixed 2GToggle longpress action
  • Frameworks: Revert Themed icons because of Theme Choosers conflicts
Cherry-picks from gerrit.sudoservers.com, r.cyanogenmod.com, r.paranoid-rom.com
1.3.0
-Upstream changes in AOKP Gerrit
Full changelog available here.
1.2 Rebased
-Fully Rebased to AOKP Sources
-Fixed stuffs
-Rebase the whole tweaks and holo themes of SnapBlack
Full Changelog here
1.1
-Minimal CNA Wallpapers
-Both CM/AOKP Toggles
-New kernel base
-Reverted old softkeys
-Moar themed?
-Removed CircleMod, bring Gummy.
* Add GPU@OC support change by sysfs
* Services: Fix tethering (softap) startup
1.0.1
-Stock kernel base
-Camcorder FC fixed
-tuna: change USB OTG mount point to new convention
-Give contributions to TeamBaked in About area.
-Some more inverts?
1.0.0
-Inital Release
Mich würde interessieren, wer der Macher (Entwickler) von diesem Mod ist und wo Er sein Port präsentiert (Linkverweis).
Entwickler? DaXmax
Edit: Habe den Port gefunden - Sinnvoll es in Post 1 zu verlinken!
Habe es schon mal wie folgt in meine Liste aufgenommen
Thread By Developer: DaXmax / xda
bei Uns Vorgestellt: [Hier]
Quelle: Ubersicht derzeit bekannter Jelly Bean AOSP Roms
Post 3
Reaktionen: mareis1973
Mach ich alles heute Abend am Pc;)
Edit: Done
Neue Version 1.3 Online. Downloads und Changelog im 1.Post
Neue Version 1.40 online
Changelogs und Downloads im 2ten Post
html6405
Verci
V
html6405
html6405
html6405
BenLue
BenLue
BenLue
