id.goPLAY
CyanogenMod 10 (JB 4.1.2) für Elf II, Aurora II, Crystal & Fire
Features
Installationsanweisungen
Vor dem Flashen der CM10 ROMs, "wipe media partition" mit Stock Recovery ausführen und dann die Anleitung befolgen:
Download
Compatibility zip (Updated 2012-11-10)
Changelog 2012-11-17
Changelog 2012-11-10
Changelog 2012-11-03
Changelog 2012-10-28
Known bugs
FAQs
Screenshot's
Features
- UbiFS (like stock roms)
- Bluetooth USB dongle Unterstützung
- USB GPS Unterstützung (cp210x and pl2303)
- Xbox 360 gamepad Unterstützung (xpad)
- PS3 USB gamepad Unterstützung (hid-sony)
- Generic/Chinese (Pantherlord/GreenAsia) gamepads Unterstützung (hid-pl and hid-gaff)
- OpenVPN Unterstützung (tun)
- Veno Regelalgorithmus
- Entpacke die CWM ZIP datei auf die externe SD card
- Kopiere CM10, GAPPS and A2-compatibility.zip auf deine externe SD card
- Gehe in CWM recovery modus (drücke Power und Volume -)
- Mache einen Wipe Data/Factory reset
- Gehe zu Install zip from SD card und instaliere erst die CM10 ROM datei
- Als zweites die GApps-JB-XXXXXXXX-signed-ubifs.zip
- Und am ende die Compatibility.zip datei
- Restart
Download
- ELF-II v1.4
- Aurora-II v2.5 (if you have troubles you can always use v1.3.1 as fallback)
- Crystal v1.5 (like Aurora's users, if you have troubles use v1.0 as fallback)
- Fire TM v1.2 - CWM v5.5.0.4
- Fire QM v1.3 - CWM v5.5.0.4
- Other minor stuff
- Updated upstream sources
- Added reboot to recovery (you must have flashed CWM to the NAND or it will boot to stock recovery)
- Aurora-II / Elf-II: new compatibility zip (fixes stuck g sensor for people that had problems)
- Other minor stuff
- Fixed Netflix 2.x compatibility
- Potential fix for the few games that were still having a choppy/stuttering audio
- Aurora-II / Elf-II: fixed unresponsive WiFi when the screen was turned off
- Other minor stuff
- Updated compatibility zips for Elf, Aurora and Crystal
- Re-inserted missing file that broke wifi
- Increased amplayer buffer; flash videos using latest apk work decently and in hw mode. Sometimes you may not hear audio but toggling fullscreen mode will fix it.
- Other minor stuff
Known bugs
- Post to report
FAQs
- I suggest you to change Trebuchet's rows/columns number to 4/5 to avoid launcher's FC.
- Install a different launcher like apex, nova etc from google play.
Screenshot's
