[ROM]CyanogenMod 9 - ICS Alpha 13
Baumann
Baumann
Stammgast
262
CyanogenMod 9 - ICS Alpha 13:
Es wird weiter an ICS gewerkelt.
Vielen Dank an wrldsuksgo2mars, jokersax11 und das Photon dev team!
Ich möchte drauf hinweisen, dass es sich hierbei noch um eine Alpha Version handelt. Das flashen geschieht wie immer auf eine Gefahr hin!
Installation:
1. In die Recovery booten.
2. Ins Menü "mount and storage" gehen.
3. "format system" ausführen.
4. Zurück ins Hauptmenü und Data wipen.
5. Dann im "advanced menü", "reboot recovery" ausführen.
6. danach einfach wie immer die .zip flashen.
7. neustarten ;)
DOWNLOAD:
Testbuild:
CM9-Atrix-alpha13-t8.zip
  • Really early camera support (no connection problem to the camera, but still no image from both front and back camera)
  • Fix gallery sync issue with Picasa and Google+
  • Recompile build.prop
  • Recompile boot.img
  • Replace RomManager by RomToolbox
  • Remove PinyinIME.apk from system app
  • Added the latest default launcher version
GoogleAPPS:
gapps-ics-v3.zip
Geht:
  • CDMA/GSM auto switching
  • Calling
  • Data
  • Roaming
  • Roaming data
  • SMS
  • MMS
  • Compass
  • Gyroscope
  • HDMI portrait out
  • Proximity sensor
  • Wifi
  • Bluetooth
  • Calendar sync
  • Maps
  • Google earth
  • YouTube HQ
  • Games (sure I did not test them all)
  • Gallery
  • Movie editor
  • Pic editor
  • Touch screen
  • USB mount
  • Fingerprint sensor
  • GPS (fix in tb4)
  • Sound (fix in tb4)
  • Orientation sensor (fix in tb4)
  • Astro SMB and Bluetooth (added in tb5 Since there's no filemanager in ICS)
Geht Nicht:
  • Adobe Flash (only some part work)
  • Auto brightness
  • Built in video playback
  • HDMI landscape
  • YouTube LQ
  • Car dock
  • Fingerprint unlock
  • Webtop
  • Hardware Acceleration
  • Voice command
  • Camera (obviously... like almost every ICS roms)
Bekannte Bugs:
  • Gallery show a littlle graphic wiggle when changing screens due to the lack of Hardware Acceleration.
  • The wifi does not work after the initial install, trigger the activation and reboot the phone, after that you will have no more problem.
  • The Softkey light turn on after few minutes of use.
  • Media scan not happening on boot.
  • When the battery is full charged, the battery icon on the notification bar disappears. Because of this, it has another amazing function, it shows how much percent you have overcharged
    (thanks to alistair3149)
  • Wallpaper is unscrollable in Trebuchet, use Nova launcher to use this function. It's a bug with the launcher (thanks to wywerny)
  • Getting a random offset number during installation, due to a bug in the installation script (no to worry the install is completed when the offset happens). (thanks to munchkers13)
  • Facebook sync dont work with ICS, you can use friendcaster (thanks to mitchell.23) or HaxSync.
S1ToH0Yu
XDA:
[ICS] CM9 Photon alpha13 build for Atrix
Reaktionen: detlefroeckert, pOOB73, Domingo2010 und 2 andere
Läuft echt Gut *_* , wenn doch nur Flash laufen würde. :p
P.S. Wenns intressiert bei Quadrant kommt so um die 2400 Punkte raus.
MfG
kann mir jemand helfen? Es kommt beim Start bei mir keine PIN-abfrage für die SIMkarte
gruss fritzer
Ich möchte euch die ICS-ROM aus dem xda-developers vorstellen...
SCREENSHOTS:
WAS FUNKTIONIERT:
  • CDMA/GSM
  • Telefonieren
  • Datenpakete / Roaming / Roamingdaten
  • SMS / MMS
  • Kompass
  • Gyroscope
  • Proximity sensor
  • GPS / A-GPS
  • W-LAN (siehe Bugs)
  • Bluetooth
  • USB-Verbindung
  • Google Earth / Maps
  • YouTube (Nur HQ)
  • Gallerie (siehe Bugs)
  • Fotoeditor
  • Töne
  • Kalender - Sync
  • Einige Spiele
  • Dreheffekte (wenn man das Handy neigt, etc.)
WAS FUNKTIONIERT NICHT:
  • Adobe Flash
  • Auto-Helligkeit
  • HDMI Landscape
  • Automodus / Car Dock
  • Kamera
  • Sprachsteuerung
  • WebTop
BUGS:
  • Gallerie hat einen Grafikfehler beim wechseln der Bilder (nur Effekt)
  • W-LAN funktioniert nur, wenn man es einschaltet und Handy neu startet
  • Medienscanner funktioniert nicht (Lösung: App aus Market "SDrescan")
  • SIM-Karte geht nur, wenn PIN-Abfrage ausgeschaltet ist
DOWNLOAD:
ICS - Alpha 13 (Bulid 6)
Ich persönlich hoffe, das die Dev's bald endlich ICS für unser Atrix fertig bekommen, die Alpha geht in die richtige Richtung zum Ziel :) Toll was schon alles klappt ...
Ich möchte ja nicht Meckern, aber Baumann hat doch schon ein Thema auf gemacht. ò.ó
/e Aldi Talk Ftw ?
MfG :p
/e Aldi Talk Ftw ?
MfG :p
Ich packe die beiden Themen mal zusammen. ;)
Reaktionen: Sascha_K1994
Da ich hier noch ein Atrix übrig habe, bin ich mal auf die dunkle Seite gewechselt.:)
Ich muss sagen, dank der Anleitungen hier war das flashen ein Kinderspiel.
Läuft ja schon ganz okay.:)
@poob: Darkside? Verwechselst du da nicht was? Hier gehts um CM9 ;)
Außerdem -darf man das als Moto-Angestellter: sich einfach ein Custom-Rom draufziehen? ;)
Solange ich nix kaputtflashe geht das in Ordnung.;) Nen komplett Brick hab ich bisher noch nicht geschafft. Mit den richtigen Files und Factory-Kabel kann man schon einiges wieder retten.;)
sxg75 schrieb:
@poob:
Mich würde mal interessieren, ob das Atrix-Dev-Team überhaupt noch an CM9 arbeitet oder ist das jetzt auf das Photon-Dev-Team übertragen worden? Was ist mit dem Atrix-Dev-Team passiert?
@Sascha_K1994
Danke habe es schon bei xda gelesen
Gut :)
Hoffentlich wird bald ICS fertig. Alleine wegen den großen Kontaktfotos und die Dreh-Animation :D
Hat eig. Dieses ROM im alltäglichen gebrauch ? (Ich habs nur kurz drauf gehabt).
Hätte da ein paar fragen, da ich echt in versuchung bin :p
1. Wie ist die akkuleistung bzw. laufzeit ?
2. Wie siehts eig. Mit spielen aus laufen auf ics "alle" (bis auf gta 3 ;)) ?
3.Videos laufen noch nicht oder ?
4. Was ist das nervigste an dem RoM (im alltag)
Mfg der Affe
Falls noch nicht bekannt ...
Build 8 von Alpha 13 (CM9-RC0-Atrix) ist herausgekommen, läuft entschiedent flüssiger, Kamera geht immer noch nicht, Medienscan und W-LAN Bugs ebenfalls noch da.
DOWNLOAD
Ist richtig hatte ich schon gestern Abend aktualisiert ;)
Alpha 14 Testbuild 1 ist jetzt die aktuelle testing, wird nacher auch noch aktualisiert.
Meine Antwort ist auf die Alpha 13 - Bulid 8 - ROM!
Dadurch das der Code noch nicht ganz sauber ist, ist die Akkuauslastung, CPU-Usage sowie der Memoryverbrauch etwas hoch, aber auszuhalten.
Spiele kommt je drauf an ob diese für ICS valide sind.
Aufgenommene Videos (MIUI) kann ich mit rucklern abspielen, ruckelt aber sehr, eher wie eine Diashow!
Naja, das wären:
- Keine Kamera
- Kein Medienscan
- ICS Effekte werden wegen dem Code Fehler der Hardware Acceleration nicht flüssig und "toll" dargestellt (merkt man in der Galerie)
- Nicht ganz stabil
Reaktionen: selbaer
Z
Atari060
Atari060
Tinitus
Tinitus
~db~
