UWdus
Dauergast
- 306
Ein weiteres 3.5er ROM mit etlichen Tweaks: [ROM] - [12/24/2011] - MikRunny v1.01 - [ Sense 3.5 | 2.3.5 | Tweaks | Odex/Deodex ] - xda-developers
Features:
Ext 4 (Virtuous kernel - thanks mdjay and rmk)
OC
Odex or Deodex (we personally like Odex better)
Fully Optimized and tweaked
Zipalign on boot
Defrag DB's on boot
Busybox 1.19.3
Native screen capture
Beats audio, Dolby, SRS, and EQ in music player
HTC Quicklaunch widget from bliss also added
Unlocked more settings in Browser
All Gapps and market apps updated to newest versions
All other stock sense 3.5 goodies included
Tweaks:
Settings Tweaks
Statusbar Options
Clock Options
- Style (show/hide/center)
- AM/PM Style (show/small/hide)
- Color
- Hide alarm icon
Battery Options
- Battery bar (like Miui with settings thanks to pvy)
- Show/Hide
- Color
Signal Options
- Show/Hide
- Text
- Color
- Transparency
Notification Menu Options
- Recent apps show/hide
- Date show/hide
- Transparent BG
- Skins (Stock/Inverted)
- Default to quicksettings
- Customize quicksettings (show/hide)
Rosie Options
- Custom button
- Hide navbar label
- Quick scroll (3d/2d/semi)
- Drawer matrix (4x4/4x5/5x4/5x5)
- Transparent BG
- Depagineted app drawer
- Bliss Rosie
Display Options
- Overscroll settings (none/glow/bounce & glow/bounce)
- Window and Transition animations speeds (6 diff speeds + off)
- CRT on/off
- Unlock animation on/off
- 3D home
- Font Sizes (7 different sizes)
- Auto brightness settings
- Softkeys lights (on/off/always on)
Misc Options
- Lockscreen (Honeycomb/Android/HTC - all on the fly)
- SD crad read ahead speeds (128kb - 4096kb | set to 2048 by default)
- Volume key screen on
- SMS screen on
- Snapshot (enable/disable)
- Volume key to take a picture
- HTC_IME Arrow KB (on/off)
- Beats Boost
Phone Information
- Radio etc.
- Battery
- Usage stats
- Wifi
System Tweaks
Boot options
- Reboot
- Hot Restart
- Recovery
- Bootloader
- Power off
GodMode
Mount system RW
Mount system RO
Debloater & Storage space
- Remove system apps (use at your own risk as there is no restore option yet)
- Internal & External Storage summery
Memory settings
- Default
- Free up 50/70 MB
Maintenance
- Clear Dalvik-Cache
- Clear Cache
- Fix Permissions
Enable/Disable commands
- Camera sound (on/off)
- Vibration (default/med/low)
- Ads (hide/show)
Bootanimation
- Disable
- Enable
- Get rid of
Extras for fun
Download Center
- Htc hub widgets/skins/apps (make sure to d/l ones for your sense version)
Sounds
- Bootanimations sounds
- Volume rocker sounds
- Screen lock sounds
Themes
- Bootanimations (make sure to d/l ones for your device resolution)
- Shutdown animations (make sure to d/l ones for your device resolution)
- Fonts (many to choose from...)
These tweaks are a lot like RCTweaks as they are based on their work... but there are more than a few extras that mik and chingy added in.
Changelog:
v1.01
- Fixed FB auth issues
- Fixed Camera issues for myTouch 4G
- Fixed Wifi for Desire S (i hope... no one tested, but should be fine)
- Fixed a few strings in Honeycomb Lockscreen
- Added more fonts and options for multilang support
- non-market apps installation set to TRUE by default
- Rosie,Notifications and StatusBar tweaks no longer requires reboot (changes on the fly, kinda)
- Longpress Volume keys to skip tracks when screen is off mod added (works with most music players, probably all of them | Longpress Vol up is next, and Vol down is Back)
- Over all bug fixes and a few extra features that should have made it to v1.0, but didnt.
- Full wipe might be needed... i always wipe... if u guys have luck without wiping, let everyone know.
Download Links
Features:
OC
Zipalign on boot
Defrag DB's on boot
Busybox 1.19.3
Tweaks:
Settings Tweaks
Statusbar Options
Clock Options
- Color
- Hide alarm icon
Battery Options
- Show/Hide
- Color
Signal Options
- Show/Hide
- Text
- Color
- Transparency
- Date show/hide
- Transparent BG
Rosie Options
- Custom button
- Hide navbar label
- Transparent BG
- Bliss Rosie
Display Options
- CRT on/off
- 3D home
Misc Options
- SMS screen on
- Beats Boost
Phone Information
- Radio etc.
- Battery
- Usage stats
- Wifi
System Tweaks
Boot options
- Reboot
- Hot Restart
- Recovery
- Bootloader
- Power off
GodMode
Mount system RW
Mount system RO
Memory settings
- Default
- Free up 50/70 MB
Maintenance
- Clear Cache
- Fix Permissions
- Ads (hide/show)
Bootanimation
- Disable
- Enable
- Get rid of
Extras for fun
Download Center
Sounds
Themes
Changelog:
v1.01
Download Links
